  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
  • scalzS scalz
    all you have to do is set your defines for mysensors and this should work out of the box :)
    about the usb, weird, i've no problem here. what problem do you have? here it works smoothly (with custom board, but i have also an adafruit m0 proto, worked well too)
    #85
    @scalz said in Minimalist SAMD21 TQFP32 Pro Mini:
    I just now noticed that @Sweeman already did: https://forum.mysensors.org/topic/6908/adafruit-feather-m0-rfm69hcw-with-mysensors/6
      #86
      I hadn't noticed it before, but it looks like even Arduino will have an NRF52 board: http://www.arduino.org/products/boards/arduino-primo
      Of course, that's a very good thing! Unfortunately, they don't seem to be in stock anywhere, even though they were first released in March, 2016. What's up with that?
      So, I've ordered a couple of these to try out:
      https://www.amazon.com/Adafruit-Feather-nRF52-Bluefruit-nRF52832/dp/B06XXSVYLC/ref=sr_1_1?ie=UTF8&qid=1498743679&sr=8-1&keywords=nrf52
      The good news is that NRF52 modules don't seem to require many external parts, and for self-assembly that's a real advantage.
      TerrenceT 1 Reply Last reply
        Looks like a fully integrated board can be had for <$9, including e-packet delivery:
        https://www.aliexpress.com/item/nRF52832-Bluetooth-4-1-BLE-Module-M4-Transparent-Transmission-SMA-512K-FLASH-64K-RAM-pass-through/32798522093.html?spm=2114.01010208.3.17.YON8eD&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_5210015_10136_10137_10060_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_5290015_10096_5320015_10052_10053_10107_10050_10142_10051_5280015_10084_10083_5250016_10119_10080_10082_10081_10178_10110_519_10111_10112_10113_5240015_10114_5230016_10182_10078_10079_5260014_10073_10123_10120_10189_5270015_142-10120,searchweb201603_49,ppcSwitch_4&btsid=02e4720e-a974-4d92-a890-0cd0f6510022&algo_expid=87b18aca-7c4a-43a5-8995-4d45694a7044-2&algo_pvid=87b18aca-7c4a-43a5-8995-4d45694a7044
          TerrenceT
          TerrenceT
          Terrence
          @NeverDie I was about to pull the trigger on some of those, but I can't seem to get my mind off of the potential long distance of the 840. I wonder when the world will be blessed with those modules?
          Looking forward to your experience with the Adafruit BLE boards.
          YveauxY NeverDieN 2 Replies Last reply
          • TerrenceT Terrence
            I wouldn't wait for them. Will probably take at least half a year or so (according to Nordic)
            • YveauxY Yveaux
              TerrenceT
              TerrenceT
              Terrence
              @Yveaux You are correct, use what is available, not what will be in the future.
                Same here, but hopefully (?) most of what I learn with the 832 will be applicable to the 840. The 840 is clearly more desirable, and I probably wouldn't have pulled the trigger on the 832 if I didn't know the 840 was coming.
                  TerrenceT
                  TerrenceT
                  Terrence
                  @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                  Right. I have been trying to get my head around the BT communication pattern. It is a different beast indeed.
                    Looks as though the 52 Thingy might be a good starting point for some people:
                    http://www.mouser.com/new/nordicsemiconductor/nordic-thingy-52/
                      #94
                      What I'm not sure about is whether the NRF52832 will have truly adequate indoor range. Max tx power is 4db, which is better than the 0db of the NRF24L01. Will that be enough? I can only guess. That's why I ordered two of the Adafruit NRF52832 feathers: to see for myself. If they disappoint, then I may shelve them until the 840 becomes more available, and then try again using the 840. On the other hand, if the 832 turns out to be "good enough", then the 840 may not matter so much.
                      I do like that it apparently is programmable from within the Arduino IDE. That will make trying it out a lot easier. If the OTA uploads are easy to do, then I'll be really happy. :)
                        nrf52832 is definitely better than nrf24l01. if i'm not wrong, 4db can double range in theory.
                        For range, an important point is the antenna, as you already know.
                        Chip antenna can be ok, depending on the environment and usecase, but can't compete with a rfm69. These antennas are not for long range, so the adafruit board. How to miniaturize antennas without loosing performance..
                        NeverDieN JokgiJ 2 Replies Last reply
                        • scalzS scalz
                          #96
                          Good point. Looks as though the aliexpress module I referenced above, though, does have some kind of antenna connector on it:
                          So, maybe plugging something (?) into that would give better range?
                          Also, I just now read that these 832 modules can communicate with the older NRF24L01's. Is that true? That would be nice.
                            #97
                            yes these one looks better. looks like you can also tune ant (there are some footprints).
                            note the "meandered" antenna. it reduces antenna size, needs some tuning, a bit less efficient vs others type. but maybe better than chip antenna i think. and you have the ipex in case, cool!
                            Not so cheap (not fcc) but interesting i agree.
                            Yes, indeed! it's compatible with nrf24 thx to @d00616
                            You should try, i'm using my nrf52 board (aeos) with my esp32 gw (halo) :)
                            And the cherry, with VS Micro, and multiple serial monitors in same ide ;)
                            • scalzS scalz
                              TerrenceT
                              TerrenceT
                              Terrence
                              Guys I have been developing with VS Code (free) for Arduino type coding. been very happy with it. It does not have multi serial monitors (not that I know of).
                              Anyone else using VS Code?
                                What are its advantages that are the reason for your preferring it?
                                  TerrenceT
                                  TerrenceT
                                  Terrence
                                  @NeverDie I prefer it over the Arduino platform, not VS Micro.
                                  It is a super lightweight editor, but really powerful with added extensions.
                                  In Windows Explorer, right click a folder and click on "Open with Code' and the folder and all code files are there.
                                  I have been using Visual Studio for work for a decade. It is a very heavy capable environment, but too heavy for simple ino projects.
                                  I used VS Micro 3 years ago or so, but I can't compare the two.
                                  https://code.visualstudio.com/
                                  Here is a snip showing the Arduino extension.
                                  0_1498766540886_upload-255eee95-5c42-464a-9769-e4795a8a3d73
                                    I received the adafruit nrf52 feathers today, and I'm really quite shocked: adafruit doesn't supply any demo code (at least none that I can find) which would allow two nrf52 feathers to talk to one another. In fact, most of the demo code has nothing to do with bluetooth at all! This is very disappointing.
                                      @NeverDie I guess they just rely on mySensors for the communication :-)
                                      • YveauxY Yveaux
                                        #103
                                        @Yveaux said in Minimalist SAMD21 TQFP32 Pro Mini:
                                        Wait, does mysensors demo code already work using the nrf52832?
                                        If not, does anyone know of some demo code somewhere that demos two 832's communicating (like there's plenty of demo code already for the NRF24L01)? I really don't want to figure this out from scratch using just the datasheet. Been there and done that already with the RFM69, and I don't want to have to do it again with the NRF52832. If there is not already a good "load and go" demo somewhere, then I'm going to return these modules to Amazon.
                                          Adafruit only provides examples for Bluetooth.
                                          regarding mysensors, i have answered here https://forum.mysensors.org/post/70297 ;)
