  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • ikkeTI
    ikkeTI
    ikkeT
    wrote on last edited by ikkeT
    #33
    My sample is here, unfortunately I didn't see this thread before starting it :)
    It works for temp, humidity, door and motion, and interrupts for door and motion, otherwise sleeps the intervals:
    https://github.com/ikke-t/sensebender
    There is also pro-mini to code to monitor only door and motion.
    This is also for 2.0 MySensors.
    • McPostalM
      McPostalM
      McPostal
      wrote on last edited by McPostal
      #34
      I combined Motion and Air Humidity and Sleep works. This is my first one and I'm pretty sure I have some unnecessary code in it.
       * Motion: Version 1.0 - Henrik Ekblad
       * Humidity: Version 1.0: Henrik EKblad
       * Combination of Motion Sensor example and Air Humidity example
       * https://www.mysensors.org/build/humidity
      // Enable debug prints
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
      #define MOTION_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
      #define DHT_INPUT_SENSOR 4     // The digital input of attached DHT sensor
      #define SENSOR_TEMP_OFFSET 0
      static const uint64_t UPDATE_INTERVAL = 60000;
      #define CHILD_ID_HUMID 0        // ID of the Humidity child
      #define CHILD_ID_TEMP 1         // ID of the Tempurature child
      #define CHILD_ID_MOTION1 2   // Id of the Motion sensor child
      // Initialize motion message
      MyMessage msgMotion(CHILD_ID_MOTION1, V_TRIPPED);
      MyMessage msgHum(CHILD_ID_HUMID, V_HUM);
      DHT dht;
        sendSketchInfo("Motion Temp Humidity", "1.0");
        present(CHILD_ID_MOTION1, S_MOTION);
        present(CHILD_ID_TEMP, V_TEMP);
        present(CHILD_ID_HUMID, V_HUM);
      	pinMode(MOTION_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
        dht.setup(DHT_INPUT_SENSOR); // set data pin of DHT sensor
      	// Read digital motion value
      	bool tripped = digitalRead(MOTION_INPUT_SENSOR) == HIGH;
      	Serial.println(tripped);
      	send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
        #ifdef MY_DEBUG
             Serial.print("Motion: ");
      // DHT ****************************************************************************
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
          nNoUpdatesHum++;
      	// Sleep until interrupt comes in on motion sensor. Send update after (SLEEP_TIME) milliseconds has passed.
      	sleep(digitalPinToInterrupt(MOTION_INPUT_SENSOR), CHANGE, SLEEP_TIME);
        A Former User
        I did some work today getting this temp / humidity / motion combo sensor running. The main issue I ran into was that though the temp and humidity did not report their values to the GW unless there was a change in values or the max no update trigger was reached, the motion sensor would report it's state value each cycle. @McPostal you also should be seeing this in your code. While this is not an issue if you are powering with a AC adaptor, I am planning on using batteries down the road for these sensors so I do not want it to broadcast unless required.
        I added some code to resolve this. I am still testing this out but in theory this code should allows the Motion sensor to sleep and only report on a state change or when the max no update trigger is reached.
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        //#define MY_RS485
        #define DHT_DATA_PIN 4
        #define MOTION_DATA_PIN 3
        #define CHILD_ID_HUM 0
        #define CHILD_ID_MOTION 2
        float lastTemp;
        float lastHum;
        bool lastMotion = false;
        uint8_t nNoUpdatesMotion;
        bool metric = true;
        MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
        DHT dht;
          sendSketchInfo("Temp Humidity Motion", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          present(CHILD_ID_MOTION, S_MOTION);
          pinMode(MOTION_DATA_PIN, INPUT);
          sleep(5000);
          presentation();
          bool tripped = digitalRead(MOTION_DATA_PIN) == HIGH;
          if (tripped || nNoUpdatesMotion == FORCE_UPDATE_N_READS) {
            lastMotion = tripped;
            nNoUpdatesMotion = 0;
          else if (lastMotion) {
          else {
            nNoUpdatesMotion++;
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            nNoUpdatesHum++;
          sleep(digitalPinToInterrupt(MOTION_DATA_PIN), CHANGE, UPDATE_INTERVAL);
        Morkin.
        • McPostalM
          McPostalM
          McPostal
          Nice! I realized the motion was being updated every cycle after I posted my code. I also left out references to metric temperature readings. I fixed the motion part in my code but didn't post it yet because I had already added a second motion sensor. What I did different was not forcing the motion update. I want the time stamp to reflect the last time someone was in the room.
          • stockenS
            stockenS
            stocken
            I took your updated code for 2.0 and tried to add a relay.
            The code looks like this:
            #define CHILD_ID_HUM 10
            #define CHILD_ID_TEMP 11
            #define CHILD_ID_MOT 12 //motion sensor
            #define RELAY_1  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define CHILD_ID 5
            DHT dht;
            float lastTemp;
            float lastHum;
            boolean metric = true;
            unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
            unsigned long previousMillis=0; // millis() returns an unsigned long.
            MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED); //me
            void before()
            		pinMode(pin, OUTPUT);
             // metric = getConfig().isMetric;
              sendSketchInfo("4-1 Sensor", "1.0");
              present(CHILD_ID_MOT, V_TRIPPED); //me
            	present(sensor, S_BINARY);
            // only run loop if time has passed.
            unsigned long currentMillis = millis(); // grab current time
             // check if "interval" time has passed
             if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                   send(msgMot.set(tripped?"1":"0"));
                  #ifdef MY_DEBUG
                if (!metric) {
                #ifdef MY_DEBUG
                  lastHum = humidity;
                  #ifdef MY_DEBUG
               // save the "current" time
               previousMillis = millis();
              //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
            	if (message.type==V_STATUS) {
            		// Change relay state
            		// Store state in eeprom
            However, when i look in domoticz the relay isnt presented as a child.
            Plus, the motion sensor is called "S_LIGHT_LEVEL" and not "S_MOTION" as it does in my other device (that only have temp, hum motion and not a relay in the sketch).
            temp/hum sensor and motion sensor works as intended in domoticz.
            My first though is that the motion and relay somehow is a bit mixed up by the sketch, but im kinda new to this so im not sure.
            Would really appreciate if someone can look at the sketch and see if there is any obvious problem :)
            McPostalM 1 Reply Last reply
            • stockenS stocken
              #define CHILD_ID 5
              DHT dht;
              float lastTemp;
              float lastHum;
              void before()
                    #ifdef MY_DEBUG
                  if (!metric) {
                  #ifdef MY_DEBUG
                    lastHum = humidity;
                    #ifdef MY_DEBUG
              McPostalM
              McPostalM
              McPostal
              #38
              @stocken
              Under "void presentation()" , present(CHILD_ID_MOT, V_TRIPPED); //me should be
              present(CHILD_ID_MOT, S_MOTION); //me
              that should fix the light level problem.
              I haven't done a relay yet. If no one else responds I look at it later tonight. I also have a relay but haven't had time to try and implement it yet.
              • K
                K
                Komaandy
                wrote on last edited by Komaandy
                #39
                Hello everybody,
                first off all a big thank you for creating this awsome sketch. It works perfect for me !!
                But, as you might already have guessed I have a little problem.
                I built 2 exact same nodes and flashed the exact same sketch ( only thing I changed is the child ID´s) but one node works just like a charm ( MSPIRAndy) but the other one (MYSENSOR_106) doesnt transmit its readings (?)
                Via the serial monitor the readings do exist and work perfect.
                Thanks a lot, all help is appreciated
                KOmaandy
                  Have you tried swapping radio between the 2 sensors? Just to exclude any radio issue
                  • K
                    K
                    Komaandy
                    Yes i did swap the radios, but what seems to be the problem is the arduino itself.
                    When swapping the arduinos ( both arduino pro mini 3,3 volt) both flashed with the same sketch one works and the other just doesnt.
                    I just swapped the arduinos on the breadboard and left everything else in place...
                    Thats really strange, given the fact that BOTH transmit good readings when connected to the arduino-serial-monitor ...
                    • R
                      R
                      ryanbrown204
                      Do you have a schematic that you could post?
                      • R ryanbrown204
                        #43
                        @ryanbrown204 welcome to the MySensors community!
                        This is a long thread with a lot of different people posting, so it is a bit hard to guess which schematic you are looking for. Could you clarify?
                        R 1 Reply Last reply
                          R
                          R
                          ryanbrown204
                          @mfalkvidd the schematic for the original 3-in-1 Humidity Temp and Motion. I would like to try me hand at building the first version and then adding the additions.
                          • R ryanbrown204
                            @ryanbrown204 temperature: https://www.mysensors.org/build/temp
                            Motion: https://www.mysensors.org/build/motion
                            See the first post in this thread for the modifications Konrad did.
                            • F
                              F
                              fulljionslly
                              • F
                                F
                                fulljionslly
