  3. 3-in-1 Humidity Temp and Motion
motion3 in 1temphumidity
47 Posts 28 Posters 49.1k Views 22 Watching
  • V
    V
    viableoption
    Looks pretty sweet. How is it working comparing to existing products with the same features?
    • Łukasz KostrzewaŁ
      Łukasz KostrzewaŁ
      Łukasz Kostrzewa
      Hi Konrad
      Thx for great code. It works like charm but...
      I have a question... It is possible to add to Your code one more (Door/Window) sensor?
      Mayby You can post that code on this forum?
      Best regards
      • Łukasz KostrzewaŁ
        Łukasz KostrzewaŁ
        Łukasz Kostrzewa
        wrote on last edited by Łukasz Kostrzewa
        #29
        Hi to all
        I changed a little Konrad sketch and add to 3in1 Humidity Temp and Motion one more sensor (Door\Window)
        Here is my code:
        #define CHILD_ID_DOOR 3
        #define BUTTON_PIN_DOOR 2
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_MOT 2 // Id of the sensor child
        #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
        Bounce debouncer = Bounce();
        int oldValue=-1;
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = true;
        MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
        MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
        gw.begin();
        pinMode(BUTTON_PIN_DOOR,INPUT);
        digitalWrite(BUTTON_PIN_DOOR,HIGH);
        debouncer.attach(BUTTON_PIN_DOOR);
        debouncer.interval(5);
        gw.sendSketchInfo("4in1", "1.0");
        pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input
        gw.present(CHILD_ID_MOT, S_MOTION);
        gw.present(CHILD_ID_DOOR, S_DOOR);
        // Read digital motion value
        Serial.println(tripped);
        gw.send(msgMot.set(tripped?"1":"0")); // Send tripped value to gw
        if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        if (isnan(humidity)) {
        lastHum = humidity;
        Serial.print("H: ");
        Serial.println(humidity);
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue) {
        // Send in the new value
        gw.send(msgDoor.set(value==HIGH ? 1 : 0));
        oldValue = value;
        //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
        Now it is 4in1 :)
        • Łukasz KostrzewaŁ
          Łukasz KostrzewaŁ
          Łukasz Kostrzewa
          • kurniawan77K
            kurniawan77K
            kurniawan77
            wrote on last edited by kurniawan77
            #31
            Has the 3in1 sketch been updated to 2.0 yet? I need some help with it, im not tot keen with coding...
            R 1 Reply Last reply
            • kurniawan77K kurniawan77
              R
              R
              r-nox
              @kurniawan77
              This is HUM TEMP and PIR
              This is what I'm using and it runs in mysensors 2.0
              None battery powered. NO sleep mode and dirty code but it runs well enough for me right now.
              If you add or fix anything please post it for everyone.
              #define CHILD_ID_MOT 2 //me
              #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              DHT dht;
              float lastTemp;
              float lastHum;
              boolean metric = false;
              unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
              unsigned long previousMillis=0; // millis() returns an unsigned long.
              MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED); //me
               // metric = getConfig().isMetric;
                sendSketchInfo("3-1 Sensor", "1.0");
                present(CHILD_ID_MOT, V_TRIPPED); //me
              // only run loop if time has passed.
              unsigned long currentMillis = millis(); // grab current time
               // check if "interval" time has passed
               if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                    #ifdef MY_DEBUG
                     Serial.print("Motion: ");
                  if (!metric) {
                  #ifdef MY_DEBUG
                    lastHum = humidity;
                    #ifdef MY_DEBUG
                 // save the "current" time
                 previousMillis = millis();
                //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
              • ikkeTI
                ikkeTI
                ikkeT
                wrote on last edited by ikkeT
                #33
                My sample is here, unfortunately I didn't see this thread before starting it :)
                It works for temp, humidity, door and motion, and interrupts for door and motion, otherwise sleeps the intervals:
                https://github.com/ikke-t/sensebender
                There is also pro-mini to code to monitor only door and motion.
                This is also for 2.0 MySensors.
                • McPostalM
                  McPostalM
                  McPostal
                  wrote on last edited by McPostal
                  #34
                  I combined Motion and Air Humidity and Sleep works. This is my first one and I'm pretty sure I have some unnecessary code in it.
                   * Motion: Version 1.0 - Henrik Ekblad
                   * Humidity: Version 1.0: Henrik EKblad
                   * Combination of Motion Sensor example and Air Humidity example
                   * https://www.mysensors.org/build/humidity
                  // Enable debug prints
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
                  #define MOTION_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                  #define DHT_INPUT_SENSOR 4     // The digital input of attached DHT sensor
                  #define SENSOR_TEMP_OFFSET 0
                  static const uint64_t UPDATE_INTERVAL = 60000;
                  #define CHILD_ID_HUMID 0        // ID of the Humidity child
                  #define CHILD_ID_TEMP 1         // ID of the Tempurature child
                  #define CHILD_ID_MOTION1 2   // Id of the Motion sensor child
                  // Initialize motion message
                  MyMessage msgMotion(CHILD_ID_MOTION1, V_TRIPPED);
                  MyMessage msgHum(CHILD_ID_HUMID, V_HUM);
                  DHT dht;
                    sendSketchInfo("Motion Temp Humidity", "1.0");
                    present(CHILD_ID_MOTION1, S_MOTION);
                    present(CHILD_ID_TEMP, V_TEMP);
                    present(CHILD_ID_HUMID, V_HUM);
                  	pinMode(MOTION_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                    dht.setup(DHT_INPUT_SENSOR); // set data pin of DHT sensor
                  	bool tripped = digitalRead(MOTION_INPUT_SENSOR) == HIGH;
                  	send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
                    #ifdef MY_DEBUG
                  // DHT ****************************************************************************
                    dht.readSensor(true);
                      // Reset no updates counter
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesHum++;
                  	// Sleep until interrupt comes in on motion sensor. Send update after (SLEEP_TIME) milliseconds has passed.
                  	sleep(digitalPinToInterrupt(MOTION_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                    A Former User
                    I did some work today getting this temp / humidity / motion combo sensor running. The main issue I ran into was that though the temp and humidity did not report their values to the GW unless there was a change in values or the max no update trigger was reached, the motion sensor would report it's state value each cycle. @McPostal you also should be seeing this in your code. While this is not an issue if you are powering with a AC adaptor, I am planning on using batteries down the road for these sensors so I do not want it to broadcast unless required.
                    I added some code to resolve this. I am still testing this out but in theory this code should allows the Motion sensor to sleep and only report on a state change or when the max no update trigger is reached.
                     * Version 1.0: Henrik EKblad
                     * sensor using a DHT11/DHT-22.
                    //#define MY_RS485
                    #define DHT_DATA_PIN 4
                    #define MOTION_DATA_PIN 3
                    #define CHILD_ID_MOTION 2
                    float lastTemp;
                    float lastHum;
                    bool lastMotion = false;
                    uint8_t nNoUpdatesMotion;
                    bool metric = true;
                    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                    DHT dht;
                      sendSketchInfo("Temp Humidity Motion", "1.1");
                      present(CHILD_ID_MOTION, S_MOTION);
                      pinMode(MOTION_DATA_PIN, INPUT);
                      sleep(5000);
                      presentation();
                      bool tripped = digitalRead(MOTION_DATA_PIN) == HIGH;
                      if (tripped || nNoUpdatesMotion == FORCE_UPDATE_N_READS) {
                        lastMotion = tripped;
                        nNoUpdatesMotion = 0;
                      else if (lastMotion) {
                      else {
                        nNoUpdatesMotion++;
                        if (!metric) {
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesTemp++;
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesHum++;
                      sleep(digitalPinToInterrupt(MOTION_DATA_PIN), CHANGE, UPDATE_INTERVAL);
                    Morkin.
                    • McPostalM
                      McPostalM
                      McPostal
                      Nice! I realized the motion was being updated every cycle after I posted my code. I also left out references to metric temperature readings. I fixed the motion part in my code but didn't post it yet because I had already added a second motion sensor. What I did different was not forcing the motion update. I want the time stamp to reflect the last time someone was in the room.
                      • stockenS
                        stockenS
                        stocken
                        I took your updated code for 2.0 and tried to add a relay.
                        The code looks like this:
                        #define CHILD_ID_HUM 10
                        #define CHILD_ID_TEMP 11
                        #define CHILD_ID_MOT 12 //motion sensor
                        #define RELAY_1  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                        #define CHILD_ID 5
                        DHT dht;
                        float lastTemp;
                        float lastHum;
                        void before()
                        		pinMode(pin, OUTPUT);
                          sendSketchInfo("4-1 Sensor", "1.0");
                        	present(sensor, S_BINARY);
                              #ifdef MY_DEBUG
                            if (!metric) {
                            #ifdef MY_DEBUG
                              lastHum = humidity;
                              #ifdef MY_DEBUG
                        	if (message.type==V_STATUS) {
                        		// Change relay state
                        		// Store state in eeprom
                        However, when i look in domoticz the relay isnt presented as a child.
                        Plus, the motion sensor is called "S_LIGHT_LEVEL" and not "S_MOTION" as it does in my other device (that only have temp, hum motion and not a relay in the sketch).
                        temp/hum sensor and motion sensor works as intended in domoticz.
                        My first though is that the motion and relay somehow is a bit mixed up by the sketch, but im kinda new to this so im not sure.
                        Would really appreciate if someone can look at the sketch and see if there is any obvious problem :)
                        McPostalM 1 Reply Last reply
                        • stockenS stocken
                          #define CHILD_ID 5
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                          void before()
                                #ifdef MY_DEBUG
                              if (!metric) {
                              #ifdef MY_DEBUG
                                lastHum = humidity;
                                #ifdef MY_DEBUG
                          McPostalM
                          McPostalM
                          McPostal
                          #38
                          @stocken
                          Under "void presentation()" , present(CHILD_ID_MOT, V_TRIPPED); //me should be
                          present(CHILD_ID_MOT, S_MOTION); //me
                          that should fix the light level problem.
                          I haven't done a relay yet. If no one else responds I look at it later tonight. I also have a relay but haven't had time to try and implement it yet.
                          • K
                            K
                            Komaandy
                            wrote on last edited by Komaandy
                            #39
                            Hello everybody,
                            first off all a big thank you for creating this awsome sketch. It works perfect for me !!
                            But, as you might already have guessed I have a little problem.
                            I built 2 exact same nodes and flashed the exact same sketch ( only thing I changed is the child ID´s) but one node works just like a charm ( MSPIRAndy) but the other one (MYSENSOR_106) doesnt transmit its readings (?)
                            Via the serial monitor the readings do exist and work perfect.
                            Thanks a lot, all help is appreciated
                            KOmaandy
                              Have you tried swapping radio between the 2 sensors? Just to exclude any radio issue
                              • K
                                K
                                Komaandy
                                Yes i did swap the radios, but what seems to be the problem is the arduino itself.
                                When swapping the arduinos ( both arduino pro mini 3,3 volt) both flashed with the same sketch one works and the other just doesnt.
                                I just swapped the arduinos on the breadboard and left everything else in place...
                                Thats really strange, given the fact that BOTH transmit good readings when connected to the arduino-serial-monitor ...
                                • R
                                  R
                                  ryanbrown204
                                  Do you have a schematic that you could post?
                                  • R ryanbrown204
                                    #43
                                    @ryanbrown204 welcome to the MySensors community!
                                    This is a long thread with a lot of different people posting, so it is a bit hard to guess which schematic you are looking for. Could you clarify?
                                      R
                                      R
                                      ryanbrown204
                                      @mfalkvidd the schematic for the original 3-in-1 Humidity Temp and Motion. I would like to try me hand at building the first version and then adding the additions.
                                      • R ryanbrown204
                                        @ryanbrown204 temperature: https://www.mysensors.org/build/temp
                                        Motion: https://www.mysensors.org/build/motion
                                        See the first post in this thread for the modifications Konrad did.
                                        • F
                                          F
                                          fulljionslly
