  3. [SOLVED] ADAFRUIT rfm69hcw breakout - doesnt respond
27 Posts 8 Posters 16.3k Views 5 Watching
  • A abrasha
    @tboha
    The picture you referred to shows the rfm69HW from my sensors page and the adafruit is rfm69Hcw that's why they're don't identical.
    And I've tried also without capacitor.
    Tomorrow I'll check the EN. Maybe I'll wire it and write it high or whatever needed.
    Thanks a lot
    abrasha
    wrote on last edited by abrasha
    @tboha
    stripped the CAP
    tried this with EN pin: (connected to D7)
      pinMode(7, OUTPUT);
      digitalWrite(7, LOW);
      delay(500);
      digitalWrite(7, HIGH);
    nothing..
    and ther is a steady 4.4v on EN (checking from EN to GND
    what does the steady 13 led light means?
    • A abrasha
      @tboha
      stripped the CAP
        pinMode(7, OUTPUT);
        delay(500);
      nothing..
      tboha
      @abrasha
      I tested Vin behavior under load on my "original" UNO which displays 4.5V at Vin when powered through USB.
      No Load = 4.5V, load 10mA results in 4.2V, load 150mA (which is required by RFM69HCW-breakout board so far I remember) results in 3.8V. Maybe transient load response is much worse than this, but my Multimeter does only 2 measurements per second.
      I think it is safe to stay away from Vin on your Arduino (which you apparently are doing already).
      According to schematics, "EN" is tied to Vin via 100k. Supplying Vin with 4.99V and measuring 4.4V on Pin "EN" could indicate your multimeter having a relatively low input impedance (about 1M ?). But either way - EN shuts off only below 0.4V, and 4V seem to be a reasonable margin (transients excluded). So this is not the reason for strange behavior.
      D13 may be a good point. D13 is tied to Pin 13 (SCK) and via 1k and a (blue?) LED to GND. In my setup (NRF24L01+) there is only a dim flashing when data transmissions occur. So "bright" light on D13 could indicate a permanent data transmission (which your measurements on MISO/MOSI don't support) or there is a noticeable DC component -- which shouldn't be there. Measuring DC on Pin 13 may give a hint.
      It is not likely that Pin 13 is our "lost" GND - in theory impedance (especially with a blue LED) is way to high.
      To save some time - you got a spare Arduino? Consider building a second sensor (you wrote you got some more Adafruit breakout boards). Take the Adafruit wiring instructions mentioned above and do a close copy of that setup.
      Another option would be to exchange the RFM69 module from your GW with the Adafruit breakout boards. If this would be functional - the board(s) are ok.
      If you could afford, keep your current setup for further examinations. Although your basic question is quite interesting and unique (my setup works - but it shouldn't) don't get distracted from your way which is probably doing some measurements of your home environment and not of some hardware ( though it is still interesting anyway).
      A 2 Replies Last reply
      • T tboha
        @abrasha
        abrasha
        @tboha
        checked now.
        D13 shows 0v (measuring on the uno itself) and after some seconds, when it lits up forever it shows 0.3v and the serial output prints these two new lines:
        0;255;3;0;9;TSM:FAIL:RE-INIT
        0;255;3;0;9;TSM:INIT
        also , about the VIN discussion, why does mysensors advice to connect 5v to 3,3v regulator to VIN? on the connect the radio page
        about more boards - i only have these 5 adafruit breakouts. all other nodes and GW are working on nrf24. so nothing to compare. and all 5 do the same error
        • T tboha
          @abrasha
          abrasha
          @tboha
          Maybe library issue.?
          I checked the same sketch with nrf24 and it was fine
          • A abrasha
            @tboha
            checked now.
            tboha
            @abrasha
            Sorry about the delay - I ran out of ideas, and your new measurements are confusing to me.
            About Vin:
            Could it be possible we talk at cross-purposes?
            From the MySensors wiring advice I conclude to connect Arduino-5V to Adafruit-Vin (just the way NRF24L01 with power adapter board).
            From your picture (which I misinterpreted firstly due to bad sight) you said
            Well, no, the Vin on the adafruit (brown wire) is connected to the vin pin on the uno. I've tried also connecting it to the 5v pin with no success. Also tried switching gnd sockets on the uno.
            Im close to sign this issue with recall to adafruit - i ordered 4 boards and they're all with the same behavior. Or maybe i shorted out the ground when i soldered the antenna?
            Connecting Arduino-Vin to Adafruit-Vin would not exactly be according to the rules - but it might work - more likely it would result in unforced errors due to insufficient stabilisation of 5V.
            From your measurement 4.99V on Adafruit-Vin I conclude you switched to a 5V Arduino socket - have you?
            D13 at 0.2V (or 0.3V) shouldn't light up the LED at all unless its really continuous SCK with predominantly low phases.
            To solve this you would need an oscilloscope - and this would be inappropriate in my opinion.
            No, I don't think it is a library malfunction. I experienced MySensors library as stable and library malfunctions are mostly detected by community at once. For special cases there maybe a lack of functionality but I don't think your setup is very special (besides the breakout-board). And 5 defective boards in a row - not very likely (and Adafruit has a good reputation for engeneering as well as for production).
            I am not familiar with RFM69 (altough I was thinking of adding some RFM69 to my setup, but level converters scared me, so I was interested in your type of setup). So far I read about RFM69 you did the approriate #defines. Maybe someone who is working often with RFM69 could check the above sketch?
            None of the above explains why your sketch works without GND connection. It's still a miracle.
            And as I said before - I ran out of practicable ideas. Next I would try to get a functional two Arduino system according to Adafruit instructions (as well hardware as software). Ok - it's a little like giving up (only a little) - but maybe a practical approach.
            • A abrasha
              im starting my movement toward replacing my nrf24 to rfm69-433mhz, and on the same time upgrade to 2.1 library,
              i have adafruit rfm69hcw conneced to arduino uno: 0_1484485217885_20170115_145327.jpg
              by this pinout:
              **the word אנטנה!! in the right side of the pcb means antenna...
              now i uploaded the serial gateway sketch and added all the neccesarry rows:
              #define MY_RADIO_RFM69
              #define MY_IS_RFM69HW
              now all i got is this serial output:
              0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.0
              0;255;3;0;9;TSF:WUR:MS=0
              0;255;3;0;9;TSM:FAIL:CNT=1
              0;255;3;0;9;TSM:FAIL:PDT
              both happens with serial gateway sketch and ethernet gateway sketch.
              maybe my antenna isnt good? its an ordinary dupont cable with the male connector soldered inside the ANT hole
              uno powered by PC usb, and the rfm69 vin connected to VIN (5V also didnt do anything)
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #23
              @abrasha I didn't read the whole conversation, but RST is not connected? Leaving RST floating could cause a problem.
              A 1 Reply Last reply
              • tekkaT tekka
                abrasha
                #24
                @tekka
                Tried this on d9 inside the void setup:
                pinMode(9, OUTPUT);
                  digitalWrite(9, HIGH);
                  delay(100);
                  digitalWrite(9, LOW);
                  delay(100);
                The adafruit test sketch put this in order to reset the board in the setup phase.
                Didn't work
                • A abrasha
                  @tekka
                  pinMode(9, OUTPUT);
                    delay(100);
                    delay(100);
                  Didn't work
                  abrasha
                  ok. case solved. my mistake from the beginning...
                  i ran the adafruit test sketch without the reset lines, and after the guy in their forum reminded me, i tried this inside void setup, and than i realized that the rfm69 initializes before void setup, so i inserted these lines inside MyTransport.cpp:
                  void stInitTransition(void)
                  	pinMode(9, OUTPUT); //adafruit rfm69hcw board fix
                       delay(100);
                       delay(100);
                       TRANSPORT_DEBUG(PSTR("TSM:INIT\n"));
                  	// initialise status variables
                  	_transportSM.pingActive = false;
                  	_transportSM.transportActive = false;
                  	_transportSM.lastUplinkCheck = 0ul;
                  and everything is fine.
                  now i have a running serial-gw and 3 nodes that one of them talks to the gateway directly from a distance which a similar nrf node needed 2 repeaters to do so. exciting! its about 117 meters of direct line, with one plastic transperant door between and only simple standing wire antenna without dipole.
                  thanks everyone,
                  and a letter to the honorable @Admin (s):
                  may i propose a sticky thread dedicated to all compatible hardwares which need special configuration in order to work with mysensors. some examples:
                  this thread :blush:
                  adafruit feather
                  w5100 with rfm69
                  i think many members will benefit from such thread for saving time sweat and unnecessary effort for something that should be written somewhere in some dust covered manual
                  W 1 Reply Last reply
                  • A abrasha
                         delay(100);
                         delay(100);
                    thanks everyone,
                    this thread :blush:
                    adafruit feather
                    w5100 with rfm69
                    W
                    W
                    webzter30
                    @abrasha ,
                    I know this is a old post. Glad to see someone else had this problem with these breakout boards. Thanks for the hard work hashing this out. I am new to mysensors. I have been pulling my hair out to get the RFM69HW radios to work with the ESP8266 mqtt gateway. I want to use this with openhab. I was able to back track and get the nRF modules to work, but really would like to get the RFM69HW radios to work. I had several RFM chips and hooked them up to pro min 3.3V 8mhz boards but could only sporadically get one to initialize, but then stop. I broke down and bought the adafruit breakout boards thinking that maybe I could get them to work, but ran into your problem.
                    I am glad I found your topic on the forum. To clarify, What did you attach to pin 9? Is this the only thing you did fix the problem?
                    Do the breakout boards have to be used with a 5v arduino?
                      Sweeman
                      wrote on last edited by Sweeman
                      #27
                      Hi, I am also trying to get them to work and stumbled upon this. I will try that and let you know if it works.
                      @webzter30 I guess he connected it to RST on the Adafruit-board. He mentioned that before. And the breakout does work with 3-5V, so it should work with almost anything. But Adafruit stated that you should use the same power on VIN as on the logic circuits. So for a Nano that would be 5V
                      EDIT: Works for me! Thanks.
