  3. nRF5 action!
nRF5 action!
    Here's the really good news. I tried a very quick range test with the above configuration, and it seems to be noticeably better than with two nRF24L01's. I check the datasheets, and, indeed:
    nRF24L01: -85dBm sensitivity at 1Mbps
    nRF52832: -93 dBm sensitivity, 1Msps nRF mode
    So, for an nRF52832, that's an 8dBm improvement in link budget just from improved sensitivity alone. i.e. more than twice the range. Nice. :)
      Looks as though the nRF52840 will have the same nRF mode receive sensitivity. However, it will have a receive sensitivity of -103dBm in 125ksps BLE mode. which is huge.
        #139
        It's somewhat strange that the F-antenna never caught on with the nRF24L01, which typically used some kind of meandering antenna.
        However, as proven by the ESP8266's evolution, the F-antenna is superior.
        So, its presence in at least some of the nRF52832 implementations (such as that pictured below) should help as well.
          I found it on some modules from Sunfounder on red PCB but they have fake nrf24 chip and still performed bad but a little better than the other chinese clones (range 7 meters indoor instead of 5)
            Presently the parts cost is higher for an nRF52832 (and surely for an nRF52840) than for an RFM69 plus an atmega328p. So, I'm struggling to justify it.
            Nca78N 1 Reply Last reply
              @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
              With only 5$ for the EBytes modules there's not much difference I think ? And for that you have a smaller size, easier soldering (compared to SMD atmega), incredibly more capable hardware that's really future proof for both MCU and radio module, lower power consumption for TX and even more for RX, ...
              • Nca78N Nca78
                #143
                @Nca78
                You're right. Especially after outfitting the atmega328p with an RTC, the cost is more of a wash. I think the RFM still wins on range, but maybe the 832 will be "good enough"...
                d00616D 1 Reply Last reply
                  I'm guessing that if I were to desolder the rFM52832 from the DK, then I could use the DK to program other chips using the SW pins by using the J-link that's part of the board.
                    @gohan said in Minimalist SAMD21 TQFP32 Pro Mini:
                    Interestingly, the antenna on the DK is sort-of hockey stick shaped. I guess they didn't need to compress it, since the board is so large anyway.
                    • TerrenceT
                      TerrenceT
                      Terrence
                      am reading your findings with great interest. Thanks for the updates.
                        @Nca78
                        d00616D
                        d00616D
                        d00616
                        The question is, when 832 modules are available. After announcing the nRF52832 with its preview DK, I have waited from 06/2015 to 08/2016 until modules are available for an acceptable price at aliexpress or ebay.
                        I think the atmega is a slow 8-bit MCU with less RAM. The limited RAM requires to transmit additional nonce packages, when signing is enabled. SoftSigning hashing is 76 times faster. A faster CPU allows to shorten the active time:
                        • atmega328 14000µs
                        • nRF51 1739µS
                        • ESP8266 380µS
                        • nRF52 183µS
                        The NRF24 has problems with clones, range and the limitation of packages to 32 bytes. The nRF52 allows to change the packet format to support >32 bytes packages.
                        At the moment sleep modes are only implemented for 328 and nRF5.
                        OTA updates are available for 328 and ESP8266. For nRF5 it requires to implement a boot loader. The internal flash should have enough capacity to store a simple bootloader and a firmware update.
                        If you plan to do a lot of writes into EEPROM the 328 has a real EEPROM. The SAMD requires an external EEPROM, the nRF5/Teensy/STM32F emulating the eeprom in Flash. The nRF5 is using the NVM driver, which allows much more writes to the emulated EEPROM. The price for NVM is some time for log cleaning after some hundreds writes.
                        IMHO the best MCU for creating new battery powered sensors is the nRF5 stating with a ~3€ board, if required in combination with RFM modules.
                        I think it's simpler to use one of the ST-LINK v2 clones. The DK board should be good for development, debugging and current measurement.
                        • d00616D d00616
                          • atmega328 14000µs
                          • nRF51 1739µS
                          • ESP8266 380µS
                          • nRF52 183µS
                          @d00616 said in Minimalist SAMD21 TQFP32 Pro Mini:
                          What exactly do I need to do to get it work? I tried it from Windows, and failed. I seem to recall you said you got it to work from Linux after changing a definition. Would you mind showing the steps, or providing a link on how to do that?
                          • d00616D d00616
                            • atmega328 14000µs
                            • nRF51 1739µS
                            • ESP8266 380µS
                            • nRF52 183µS
                            The board you linked to is an nRF51. Which do you prefer? nRF51 or nRF52?
                            NeverDieN d00616D 2 Replies Last reply
                              Looks as though the nRF52832 beats the nRF51832 on Rx sensitivity at 1mbps. The nRF51832 is:
                              • -90 dBm at 1 Mbps
                              versus -93dBm at 1Mbps for the nRF52832.
                              On the other hand, the nRF51832 has -96dBm receive sensitivity at 250kbps, and the nRF52832 appears to lack that mode altogether. So, in a way, that make sthe nRF51832 seem a bit more attractive on range, even if one has to pay a price on bitrate.
                                #151
                                @d00616 Now that you mention it, that board you linked to ( https://www.aliexpress.com/item/BLE4-0-Bluetooth-2-4GHz-Wireless-Module-NRF51822-Board-Core51822-B/32633417101.html?spm=2114.search0104.3.18.Q9naea&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_10084_10083_10119_10080_10082_10081_10110_10178_10136_10137_10111_10060_10112_10113_10155_10114_5360016_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10120_10189_10052_10053_10142_10107_10050_10051,searchweb201603_5,ppcSwitch_4&btsid=f45d662b-6a09-4449-9bee-1ea58d9beab8&algo_expid=53f99b5d-bb10-4b34-a548-2a3e4c0cd96e-2&algo_pvid=53f99b5d-bb10-4b34-a548-2a3e4c0cd96e ) would be an interesting way to control an RFM69, especially if it could do an OTA sketch uploade. Can it?
                                  d00616D
                                  d00616D
                                  d00616
                                  I prefer to use nRF52 controllers when the price doesn't matter.
                                  Now that you mention it, that board you linked to would be an interesting way to control an RFM69, especially if it could do an OTA sketch uploade. Can it?
                                  OTA sketch upload is on my todo list, but not at the first position ;-)
                                    • -90 dBm at 1 Mbps
                                    d00616D
                                    d00616D
                                    d00616
                                    The 250kbps mode is working with the nRF5232 but this was the last chip supporting this mode.
                                      This module is interesting because it looks as though it would be relatively easy to attach to most simple sensor projects:
                                      https://www.aliexpress.com/store/product/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/1383441_32818791344.html
                                      TerrenceT 1 Reply Last reply
                                        #155
                                        I found some useful connectors:
                                        https://www.aliexpress.com/item/20Pcs-0-050-1-27-mm-2x5-Pin-10-Positions-IDC-Male-Box-Header-Dual-Row/32813323776.html?spm=2114.13010608.0.0.dhOAzn
                                        https://www.aliexpress.com/item/10pcs-15Cm-10-Pin-1-27mm-Pitch-IDC-Socket-Extension-Flat-Ribbon-Cable-Wire-for-ISP/32699295021.html?spm=2114.13010608.0.0.dhOAzn
                                        https://www.aliexpress.com/item/50PCS-1-27MM-pitch-Female-Header-Connector-SMT-socket-Plastic-high-4-6mm-1x10p-1x20p-1x30p/32748567947.html?spm=2114.13010608.0.0.dhOAzn
                                        https://www.aliexpress.com/item/X132-Free-Shipping-10pcs-1-27mm-40-Pin-Male-Single-Row-Pin-Header-Strip-1x40P/32785126666.html?spm=2114.13010608.0.0.dhOAzn
                                        1.27mm pitch seems to be what's most common with nRF52 stuff.
                                          what would you use those connectors for?
