  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
    what would you use those connectors for?
    #157
    @gohan said in Minimalist SAMD21 TQFP32 Pro Mini:
    The J-Tag ones for connecting a J-tag programmer to an nRF5 board (e.g. the adafruit one has holes for such a 2x5 connector already on its PCB).
    The 1.27mm headers I think I might use for connecting some of the small nRF5 boards which have 1.27mm pitch through-holes onto some prototypes rather than just soldering them down. That way I can easily move them to the next version of the prototype without creating a lot of desoldering work.
    I've ordered all of the above earlier today. I'm just providing the links in case others may want to do the same.
      This module is interesting because it looks as though it would be relatively easy to attach to most simple sensor projects:
      https://www.aliexpress.com/store/product/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/1383441_32818791344.html
      TerrenceT
      TerrenceT
      Terrence
      @NeverDie Thanks for the nrf link, but I liked the units with coin cell better. I purchased 2.
      https://www.aliexpress.com/item/NRF52832-5-Bluetooth-module-PCBA-Bluetooth-indoor-positioning-to-undertake-the-project-Adult-supplies/32818011255.html?spm=2114.12010108.1000013.1.jSrF4y&traffic_analysisId=recommend_2088_1_82199_new&scm=1007.13339.82199.0&pvid=d299b2c3-7d8c-4704-8765-59c82338fbb8&tpp=1
      NeverDieN d00616D 2 Replies Last reply
      • TerrenceT Terrence
        #159
        @Terrence
        Attractive form factor, but I believe that it's just a beacon. If not, how do you connect it to anything?
        TerrenceT 1 Reply Last reply
          d00616D
          d00616D
          d00616
          This module looks great. Both oscillators and the inductor is placed ob board. But the SWDIO and SDCLK are not connected. You can only flash via OTA update. Don't flash MySensors until you have moved the used Flash by NVM driver. The NVM would overwrite the DFU bootloader. It's possible that the nRF5 code needs changes to support running on an nRF5 with Softdevice.
          @scalz is playing/plans to play with Nordics OTA update.
            #161
            A couple more interesting finds.
            1. This one is small but includes a PA, so you can allegedly get 20dBm+ in TX:
              https://www.aliexpress.com/item/PTR5618PA-Nordic-nRF52832-Module-PA-module-BLE-4-0-Module-Free-shipping/32761051086.html?spm=2114.search0104.3.9.W4RMn3&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_9947_10084_10083_10119_10080_10082_10081_10136_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10120_5360020_10189_10052_10053_10142_10107_10050_10051-9947,searchweb201603_5,ppcSwitch_4&btsid=66711830-6dac-41e4-9674-fe24475ac9f5&algo_expid=4a176404-eb42-4313-9eae-531e59e60ccf-1&algo_pvid=4a176404-eb42-4313-9eae-531e59e60ccf
            2. This one allegedly includes not only a PA, but an LNA too:
              https://www.aliexpress.com/item/nRF52832-LNA-PA-Range-Extension-EV-Board-best-sol-for-the-coming-Bluetooth-5-0-and/32778491443.html?spm=2114.search0104.3.2.W4RMn3&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10068_10130_9947_10084_10083_10119_10080_10082_10081_10136_10110_10178_10137_10111_10060_10112_10113_10155_10114_10154_438_10056_10055_10054_10182_10059_100031_10099_10078_10079_10103_10073_10102_10120_5360020_10189_10052_10053_10142_10107_10050_10051-9947,searchweb201603_5,ppcSwitch_4&btsid=66711830-6dac-41e4-9674-fe24475ac9f5&algo_expid=4a176404-eb42-4313-9eae-531e59e60ccf-0&algo_pvid=4a176404-eb42-4313-9eae-531e59e60ccf
              Awfully expensive though.
              @Terrence
              TerrenceT
              TerrenceT
              Terrence
              @NeverDie Yes, I got to thinking about that after I pulled the trigger.
              • d00616D d00616
                TerrenceT
                TerrenceT
                Terrence
                @d00616 Thanks.
                  Lastly, I'm quite intrigued by this one, which is an nRF51832, because it is only 11.4mmx9.5mm in size:
                  https://www.aliexpress.com/store/product/PTR5528-Fingertip-size-nRF51822-Module-Ultra-Low-Power-Bluetooth-4-0-Low-Energy-RF-Module-Free/130096_1705429590.html?spm=2114.12010108.0.0.TRBTKq
                  Has anyone seen anything else which is that small or even smaller?
                  d00616D 1 Reply Last reply
                    @Terrence
                    Maybe you'd like this one (or similar) a little better, as it has some additional sensors already built into it:
                    https://www.aliexpress.com/item/Free-Ship-Bluetooth-4-0-temperature-sensor-pressure-sensor-acceleration-sensor-gyroscope-light-nRF51822-bluetooth-4/32705653095.html?spm=2114.10010108.1000013.6.5TTgVd&traffic_analysisId=recommend_2088_3_82199_new&scm=1007.13339.82199.0&pvid=71d80c46-bd50-4ed5-bdc6-1d6253d9e038&tpp=1
                    d00616D NeverDieN 2 Replies Last reply
                      @d00616 said in Minimalist SAMD21 TQFP32 Pro Mini:
                      I think it's simpler to use one of the ST-LINK v2 clones. The DK board should be good for development, debugging and current measurement.
                      What exactly do I need to do to get it work? I tried it from Windows, and failed. I seem to recall you said you got it to work from Linux after changing a definition. Would you mind showing the steps, or providing a link on how to do that?
                      d00616D
                      d00616D
                      d00616
                      @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                      I have updates my documentation: https://www.openhardware.io/view/376
                      I have tested all three programmer types with Windows 10. It looks like Zadig installs the correct drivers for J-Link and ST-Link adapters. The CMSIS-DAP requires the serial driver from mbed.
                      • d00616D d00616
                        #167
                        @d00616
                        Thanks! I had been using a computer running Windows 7, and I got no joy with Zadig and st-link v2 on that. However, you just now mentioned Windows 10, so I'll give that a try.
                          @Terrence
                          d00616D
                          d00616D
                          d00616
                          This is the discussion to this board: https://forum.mysensors.org/topic/6951/nrf5-multi-sensor-board-12-14/1
                            @d00616
                            d00616D
                            d00616D
                            d00616
                            I think the best option for beginners is to use an CMSIS-DAP/DAPLink adapter. Firmware and drivers are open source and there is an integrated serial port.
                            The ST-Link adapter is initialized with an ST-Link driver by libwdi. If you have luck you can find an old variant.
                            NeverDieN 3 Replies Last reply
                              d00616D
                              d00616D
                              d00616
                              wrote on last edited by d00616
                              #170
                              Yes. 9x9mm with antenna: https://de.aliexpress.com/store/product/PTR5628-Nordic-nRF52832-Module-BLE-4-0-Module-Free-shipping/130096_32760971926.html but photo and product description are different. I had a discussion with the manufacterer end of 2016 at this time the module was shown as 9*9mm module. The PTR5628 has no 32kHz oscillator, you have to use the unprecise RC oscillator.
                              • d00616D d00616
                                #171
                                @d00616
                                9mmx9mm would be great. However, are you certain? Product description says 15.4mmx15.4mm.
                                Pitty the lack of 32khz crystal, but for a lot of sensor nodes perhaps it won't matter much.
                                I did find this after making my prior post:
                                https://www.aliexpress.com/item/nRF51-M0-Ultra-small-Bluetooth-BLE-Module-4-0-Module-LIS3DH-Support-10-GPIOs/32697055436.html?spm=a2g0s.13010208.99999999.295.t9NHvJ
                                which is allegedly 8.5mmx10.5mm and allegedly does have a 32Khz crystal, but the trade-off is that it's an nRF51832, not an nRF52832.
                                • d00616D d00616
                                  #172
                                  Thanks for the tip! Based on your recommendation, I ordered this:
                                  http://www.adafruit.com/product/2764
                                  because I could expedite the shipping.
                                  Hopefully it works.
                                  • d00616D d00616
                                    #173
                                    @d00616
                                    The smallest size I found was this:
                                    https://www.aliexpress.com/item/Bluetooth-UART-Wireless-Data-Transceiver-DA14580-Module-for-Arduino/32666222427.html?spm=a2g0s.13010208.99999999.284.fiUAYv
                                    It's just 5mmx6.2mm! So, at least the size is very much awesome. It does have an M0 Cortex core, but it's not a Nordic Semi chip: http://www.dialog-semiconductor.com/sites/default/files/da14580_ds_3v4.pdf
                                    so I have no idea if, or to what degree, it can be easily programmed from within the familiar Arduino IDE the way the Nordic chips apparently can. Do you happen to know if it would be trivially easy? Or would getting it to work be a project unto itself?
                                    Nca78N 1 Reply Last reply
                                      #174
                                      Once outfitted with the connectors, the modules should then fit quite easily into these for prototyping:
                                      https://www.aliexpress.com/item/6-X-8CM-spacing-1-27-universal-board-thickness-1-6mm-sided-HASL-PCB-test-board/32774106087.html?spm=a2g0s.13010208.99999999.288.lLgJVv
                                      Not sure if there exist 1.27mm pitch breadboards, but I haven't found any on Aliexpress.
                                        @d00616
                                        Didn't check in detail but Nordic uses "soft devices", and that's what is compatible with the Arduino platform. That's also why it can work on both NRF51 and NRF52.
                                        • Nca78N Nca78
                                          @Nca78
                                          Unfortunately, I don't think the da14580 will work with the current mysensors library: it appears to be bluetooth only. I only did a quick speed read of its datasheet, but I didn't see any mention of the Nordic proprietary modes (or anything like them) that the mysensors library relies on.
