  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
  • d00616D d00616
    @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
    What exactly do I need to do to get it work? I tried it from Windows, and failed. I seem to recall you said you got it to work from Linux after changing a definition. Would you mind showing the steps, or providing a link on how to do that?
    I have updates my documentation: https://www.openhardware.io/view/376
    I have tested all three programmer types with Windows 10. It looks like Zadig installs the correct drivers for J-Link and ST-Link adapters. The CMSIS-DAP requires the serial driver from mbed.
    #167
    @d00616
    Thanks! I had been using a computer running Windows 7, and I got no joy with Zadig and st-link v2 on that. However, you just now mentioned Windows 10, so I'll give that a try.
    d00616D 1 Reply Last reply
      @Terrence
      Maybe you'd like this one (or similar) a little better, as it has some additional sensors already built into it:
      https://www.aliexpress.com/item/Free-Ship-Bluetooth-4-0-temperature-sensor-pressure-sensor-acceleration-sensor-gyroscope-light-nRF51822-bluetooth-4/32705653095.html?spm=2114.10010108.1000013.6.5TTgVd&traffic_analysisId=recommend_2088_3_82199_new&scm=1007.13339.82199.0&pvid=71d80c46-bd50-4ed5-bdc6-1d6253d9e038&tpp=1
      d00616D
      d00616D
      d00616
      This is the discussion to this board: https://forum.mysensors.org/topic/6951/nrf5-multi-sensor-board-12-14/1
        @d00616
        d00616D
        d00616D
        d00616
        I think the best option for beginners is to use an CMSIS-DAP/DAPLink adapter. Firmware and drivers are open source and there is an integrated serial port.
        The ST-Link adapter is initialized with an ST-Link driver by libwdi. If you have luck you can find an old variant.
        NeverDieN 3 Replies Last reply
          Lastly, I'm quite intrigued by this one, which is an nRF51832, because it is only 11.4mmx9.5mm in size:
          https://www.aliexpress.com/store/product/PTR5528-Fingertip-size-nRF51822-Module-Ultra-Low-Power-Bluetooth-4-0-Low-Energy-RF-Module-Free/130096_1705429590.html?spm=2114.12010108.0.0.TRBTKq
          Has anyone seen anything else which is that small or even smaller?
          d00616D
          d00616D
          d00616
          wrote on last edited by d00616
          #170
          Yes. 9x9mm with antenna: https://de.aliexpress.com/store/product/PTR5628-Nordic-nRF52832-Module-BLE-4-0-Module-Free-shipping/130096_32760971926.html but photo and product description are different. I had a discussion with the manufacterer end of 2016 at this time the module was shown as 9*9mm module. The PTR5628 has no 32kHz oscillator, you have to use the unprecise RC oscillator.
          • d00616D d00616
            #171
            @d00616
            9mmx9mm would be great. However, are you certain? Product description says 15.4mmx15.4mm.
            Pitty the lack of 32khz crystal, but for a lot of sensor nodes perhaps it won't matter much.
            I did find this after making my prior post:
            https://www.aliexpress.com/item/nRF51-M0-Ultra-small-Bluetooth-BLE-Module-4-0-Module-LIS3DH-Support-10-GPIOs/32697055436.html?spm=a2g0s.13010208.99999999.295.t9NHvJ
            which is allegedly 8.5mmx10.5mm and allegedly does have a 32Khz crystal, but the trade-off is that it's an nRF51832, not an nRF52832.
            • d00616D d00616
              #172
              @d00616 said in Minimalist SAMD21 TQFP32 Pro Mini:
              Thanks for the tip! Based on your recommendation, I ordered this:
              http://www.adafruit.com/product/2764
              because I could expedite the shipping.
              Hopefully it works.
              • d00616D d00616
                #173
                @d00616
                The smallest size I found was this:
                https://www.aliexpress.com/item/Bluetooth-UART-Wireless-Data-Transceiver-DA14580-Module-for-Arduino/32666222427.html?spm=a2g0s.13010208.99999999.284.fiUAYv
                It's just 5mmx6.2mm! So, at least the size is very much awesome. It does have an M0 Cortex core, but it's not a Nordic Semi chip: http://www.dialog-semiconductor.com/sites/default/files/da14580_ds_3v4.pdf
                so I have no idea if, or to what degree, it can be easily programmed from within the familiar Arduino IDE the way the Nordic chips apparently can. Do you happen to know if it would be trivially easy? Or would getting it to work be a project unto itself?
                Nca78N 1 Reply Last reply
                  what would you use those connectors for?
                  #174
                  @gohan said in Minimalist SAMD21 TQFP32 Pro Mini:
                  Once outfitted with the connectors, the modules should then fit quite easily into these for prototyping:
                  https://www.aliexpress.com/item/6-X-8CM-spacing-1-27-universal-board-thickness-1-6mm-sided-HASL-PCB-test-board/32774106087.html?spm=a2g0s.13010208.99999999.288.lLgJVv
                  Not sure if there exist 1.27mm pitch breadboards, but I haven't found any on Aliexpress.
                    @d00616
                    Didn't check in detail but Nordic uses "soft devices", and that's what is compatible with the Arduino platform. That's also why it can work on both NRF51 and NRF52.
                    • Nca78N Nca78
                      @Nca78
                      Unfortunately, I don't think the da14580 will work with the current mysensors library: it appears to be bluetooth only. I only did a quick speed read of its datasheet, but I didn't see any mention of the Nordic proprietary modes (or anything like them) that the mysensors library relies on.
                      • Nca78N
                        I have ordered one like this. It's pretty small already, less than 2*1cm :
                        https://www.aliexpress.com/item/nRF51822-04-BLE4-0-WIFI-Wireless-Bluetooth-Module-TTL-Low-Power-Consumption/32682158906.html
                        It has very limited I/O and is made to be used in addition to a MCU using UART to communicate, but the SWDIO and SWDCLK pins are broken out so I will see if I can reprogram it.
                        It has a datasheet to at least get a valid footprint (as I don't plan to use the serial protocol) :
                        https://4tronix.co.uk/picobot2/WT51822-S4AT.pdf
                        And it has been featured on Nordic's website where they say it's supposed to have FCC certification (and CE too, but that's just declarative...).
                        http://www.nordicsemi.com/node_206/node_305/Product-Related-News/Nordic-powered-Bluetooth-Smart-module-simplifies-development-of-wireless-wearables-toys-and-smart-home-solutions
                        They also claim a 50m range which is way better than the 10m of the da14580 you link above.
                        So if it can be reprogrammed without problem it looks like a perfect candidate for basic nodes like door, I2C etc
                        • Nca78N Nca78
                          #178
                          @Nca78
                          Both the price and size are certainly nice. I think d00616 would probably point out that it lacks a 32Khz crystal, but since I lack experience with the nRF5's, I don't know how significant that is or isn't. Anyone know?
                          BTW, it would also be nice to know whether or not the OTA sketch upload capability will work on an nRF51, or only an nRF52 (and also whether it will work on an nRF52832 or only the future nRF52840). Anyone know?
                            @Nca78
                            wrote on last edited by Nca78
                            #179
                            @Nca78
                            Right, it sucks for low power at it needs recalibration every 4 seconds to stay accurate enough, generating 10uA extra consumption. But I'm not sure if this is needed for bluetooth only (because it has to wake up regularly and listen during a precise time window), or also for "nrf24" mode because in that mode we don't need to be precise or regular listenin.
                            • Nca78N Nca78
                              @Nca78
                              d00616D
                              d00616D
                              d00616
                              Nordic's DFU bootloader is also working with nRF51 chips. https://devzone.nordicsemi.com/documentation/nrf51/4.4.1/html/group__bootloader__dfu__description.html
                              At the moment the MySensors implementation is not compatible with a SoftDevice. This requires to change interrupts, use some SoftDevice system calls and move the NVM driver Flash area out of the DFU bootloader area.
                              I have started a new thread for OTA update discussion: https://forum.mysensors.org/topic/7146/nrf5-ota-updates
                              @Nca78 said in Minimalist SAMD21 TQFP32 Pro Mini:
                              That's correct. If required, the calibration task must be implemented or is part of the SoftDevice. At the moment the radio doesn't require a precise RTC for nRF24 compatibility. For battery powered sensors listening for commands a time slotted protocol is required. Then this protocol relies on a precise RTC.
                                I'm leaning more toward the nRF52 platform over the nRF51, in part for its superior range but also because I'm guessing it will be a little easier for the person who is implementing the OTA sketch uploads to implement it first on an nRF52 (more resources, less constrained).
                                  So, is the speed of the Cortex on an nRF5 already good enough that one can simply emulate an atsha signing component, and thus that part now completely disappears from the BOM?
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @NeverDie you can run soft signing on any device. It emulates the atsha204a equally well. The performance of the MCU only affects the speed of the calculations, not the quality of the result.
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @NeverDie but remember that if you use soft signing it is your own responsibility to protect the hmac key from readout by an attacker with physical access to the device.
                                      • AnticimexA Anticimex
                                        #185
                                        @Anticimex said in Minimalist SAMD21 TQFP32 Pro Mini:
                                        Thanks! Good to know. Speaking only for myself, I don't think I'll be losing any sleep over the prospect of an attacker gaining physical access to one of my home devices with the intent of extracting the hmac key. I'm more likely to win a lottery than have that happen--and I don't even play lotteries.
                                        AnticimexA 1 Reply Last reply
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @NeverDie that is probably correct, I just feel a responsibility to inform everyone of any known weaknesses in the security infrastructure ;)
