  3. Minimal design thoughts
299 Posts 34 Posters 278.7k Views 17 Watching
    Haha!.. I have the same problem with the wife over here. The modules and half build sensors I spread all over the house is most irritating.
    pgoP
    pgoP
    pgo
    wrote on last edited by pgo
    #54
    @hek, @tbowmo and rest: ho ho guys, first think WAF, ie Wife Acceptance Factor
    This variable has to be VERY high. Like: Darling, this whole fidling of mine would optimize our home and save on energy bills big time, so You can spend more on shopping craze. etc :)
    Probably when I finish with testing, I start selling it to friends and we will have problem spending all of the money which suddenly comes our way. (Try here not to laugh :) )
    • tbowmoT
      tbowmoT
      tbowmo
      The reason why I am building this, is that I always have been currious about collecting data at regular intervals, back in the days (8-9 years ago) I had a setup with 5 DS18B20's on long wires arround the house. One was in my furnace measuring the temperature of the water, one was outside, etc. Everything connected to my old 486 based linux machine with 20Mb ram, collecting data from all the sensors on a regular interval, and presenting it with digitemp (a php package for displaying temperatures).
      Just want to make something like that again. And I think my wife can see the ideas in it. Will just use it for environmental measurements throughout the house. Maybe some of them coupled to a SMS gateway, letting the teenagers know when to open up a window for 5 minutes, in order to get fresh air in, and the humidity level down. (And another SMS to remind them to shut the windows again).
      And then the fun in collecting data, analyzing it in graphs etc... :)
      • axillentA
        axillentA
        axillent
        @tbowmo I also have some old programmers including jtagice3 and can well understand you)
        and sure, your very small design is best to keep
        The only problem I have to use jtagice3 (which I like a lot to do hardware debugging) is that Arduino is not supported by hardware debugging
        Just an idea - if you have all pins needed for FTDI programming on the corner later you can have a special connector between your board and FTDI programmer. This case you can keep design without extra space needed
        sense and drive
        tbowmoT 1 Reply Last reply
        • axillentA axillent
          tbowmoT
          tbowmoT
          tbowmo
          Wouldn't using jtagice3 for debugging also collide with the radio on a mysensor module?
          There is a full ftdi header on my board now. And I just got information from China that my boards are shipped... so just waiting for them to arrive now :)
          • axillentA
            axillentA
            axillent
            #58
            jtagice3 is using only single pin of atmega328p (RESET pin) to do programming and debugging.
            There is no reason to have conflict with radio.
            The only problem with jtagice3 is that arduino environment is not supporting hardware debugging.
            I'm wondering on having ability to compile Mysensors using regular Atmel Astudio to be able to use debugging.
            Cool! I also like 0603 footprints. But also is fine to use 0402. Sometimes you will probably need it.
            If you need support I can prepare a bootloader for you with needed settings for boards.txt
            sense and drive
              tbowmoT
              tbowmoT
              tbowmo
              Aaahh, yeah, I forgot about their "new" debugWire interface, so thought that a fullblown spi interface was nescessary for the ISP to program the device. Hmm.. With THAT info, I could have used a smaller pinheader, instead of the 6pin ISP header..
              Could become handy for next revision of the board (if there'll be anny)
              I'm used to the small components.. And for a couple of handbuild sensor boards, I thought that I might as well cope with them, in order to keep the layout small :) If this is becomming a success, and others would like similair boards, the boards should be assembled with an pick & place machine, and then it doesn't matter that the components are 0402.
              I'll keep it in mind with the bootloader :)
              axillentA 1 Reply Last reply
              • tbowmoT tbowmo
                axillentA
                axillentA
                axillent
                you cannot remove ISP header because debugWire is activated through ISP )))
                Me and Henrik we have a list of partners for PCB production, If you fine to cooperate more closer with Mysensors we can help you on putting the board unto production. Just let Henrik to know if you have an interest on closer cooperation. I will help with production.
                sense and drive
                  tbowmoT
                  tbowmoT
                  tbowmo
                  I know, I have been talking with Henrik about it. Waiting for the first prototypes, so the design can be validated.
                  • tbowmoT tbowmo
                    And the latest schematic, and layout (After I scratched the old routing, and started all over, again, for the 5th time I think :))
                    Actually I enjoy this fiddling with placing components, and routing tracks.. Only problem is that the wife thinks it takes too much time, and I should do other more usefull stuff, than playing with my computer, making noncense drawings :)
                    Schematics
                    full layout
                    top layer
                    bottom layer
                    Think I am ready to press the GO button for first spin in china.. This is gonna be exciting :)
                    blaceyB
                    blaceyB
                    blacey
                    @tbowmo Nice design exciting to see it come together so well. Good luck with the first board bring-up and I look forward to hearing/seeing the results as the unfold.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      #63
                      I have been looking at prices (Using mouser, as they appear to have local european storage, so I can avoid import taxes in Denmark).
                      for a temperature / humidity sensor pcb, fully mounted, the price comes up to arround 13$ per unit. The most expensive part is the Si7021, which accounts for 4.5$ per unit (even in larger quantities).
                      for BMP180 on board, it's another 4.5$ added.
                      The above prices are material only...
                      • tbowmoT tbowmo
                        bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        @tbowmo Too bad the Si7021 is still too new to show up on AliExpress. The BMP180 is like $1.5 ... ironically the complete soldered module is also $1.5 ... Chinese economy ...
                        Component sourcing is the killer of fun things.
                        Hmmm. Am I correct to assume then that Mouser has free shipping over €65, and that they add country taxes on top? When I check out I seem to get a 25% VAT charge for instance. Ugh. Still better than paying an extra €10+ to the Swedish Post or UPS or whoever.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @bjornhallberg
                          Hmm.. I don't trust aliexpress that much, for example is the BMP180 you get there a counterfeit?
                          Take the bmp180, I only need 1 of those, for the whole installation, so I don't mind paying 4-5$ more for a single unit. However, for the rest of the units, all needs the Si7021 (which is pin compatible with HTU21x device, if I remember correctly? However, the specs for the Si7021 is way better)
                          I don't know about the taxes from mouser, as I haven't actually bought anything there yet, only set up my project, and added the components needed, so I could get a price indicator on it. But their website says that they pays import duties etc..
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            And the first prototypes have just arrived
                            Next step is ordering components. so I can get the thing up and running..
                            It's going to be a fun christmas :)
                            • tbowmoT tbowmo
                              tbowmoT
                              tbowmoT
                              tbowmo
                              on a side note.. this IS a prototype.. probably only 1 or 2 will be assembled, as version 2 is almost ready to hit the press..
                              Next version will have more pins available on pinheaders along each side of the board, and power input to the board is placed a more central place (electrical wise).
                              So this prototype will be verification of schematics, and check that radio etc. is wired correctly.
                              • bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                wrote on last edited by bjornhallberg
                                #68
                                Great progress!
                                If you still use dirtypcbs (what did you think of their work btw?) and have the ability to pretty much create any sort of routing and tabs, you could look into the upcoming Gerber Panelizer:
                                http://blog.thisisnotrocketscience.nl/projects/pcb-design-tools/
                                Might be more cost effective to order 10x10 pcbs and panelize the hell out of that space. You could fit a ton of different layouts. Tried the tool myself and it saves a ton of time. It can load and rotate gerbers any way you want.
                                Only snag is they haven't released the tool yet. You have to request it from from their twitter account. And it is still beta.
                                  Great progress!
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @bjornhallberg said:
                                  Great progress!
                                  Seems like dirty pcb is doing a great job, compared to the price, only have experience with prinline.dk from previous jobs, but they are expensive like hell (just looked at their prices earlier today, together with Hek, They want 314$ (plus taxes) for the same job, that I pay 14$ for at dirtypcb, only advantage is that they have a turn arround time of 8 days, instead of 4-5 weeks from dirtypcbs.
                                  It like a nice tool, Have to look at it :) Only problem is, that I have to generate gerbers myself then, instead of just uploading the eagle file, which dirtypcb turns into gerber files for me. (Remember a project 10 years ago, where it was a lot of work in creating gerbers in eagle).
                                  • tbowmoT tbowmo
                                    Great progress!
                                    bjornhallbergB
                                    bjornhallbergB
                                    bjornhallberg
                                    #70
                                    Ouch, that seems a bit steep. Never heard of any cheap board houses outside of China. OSHPark may be the exception? I thinks they have fabrication in the US right? I heard they were planning to set up a factory in Europe ... don't know if anything ever happened.
                                    I don't know how CAM exports have changed over the years but compared to how backwards everything else works in Eagle, exporting Gerbers is easy. DirtyPCBs have a CAM-file listed on their about page. I sent them Gerbers of Meanpenguin's PCB designs and that seemed to have worked out. Knock on wood. Hopefully I'll have the boards back before xmas. The reason I didn't send the Eagle file was their new warning on the front page regarding Eagle v7+ files. Some unspecified problem with their Eagle 6.x installation. Only iffy thing I've run into so far (on some exports) is the drill file showing the holes all over the place because of the wrong precision settings. Now I'm sure the board house would have fixed this for me (their Gerber tools are bound to a great deal more advanced than mine and can probably detect Excellon formats automatically), but choosing EXCELLON_24 as output solved that problem. It's enough to send them impossible routing and endless stop mask errors ;-)
                                    Oh and btw, that Gerber Panelizer also helps to circumvent the 5x5cm limit on freeware Eagle since you can take your Gerbers and join them any way you please as a greater whole. Just to point out the obvious.
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      Hhm.. don't tell my boards that dirtypcbs have problems with eagle v7 files :) Haven't seen that warning before now.. So cross my fingers, that everything is ok.
                                      I remember the trouble with excellon format, and getting drill files alligned, but got some files made for printline back then, and they are still making the pcb, so must have done something right :)
                                      Think that the free eagle is 10x8cm board space, isn't it?
                                      • tbowmoT tbowmo
                                        bjornhallbergB
                                        bjornhallbergB
                                        bjornhallberg
                                        #72
                                        @tbowmo Yes you're right, the Eagle board size is 10x8! Don't know where I got the 5x5 from. Nevertheless, since DirtyPCBs can do pretty mindblowing routing at no extra cost and have a pretty good price on 10x10 also ... you could probably save a great deal by doing what the Not Rocket Science guys did and create a heavily panelized board that covers a handful of different PCBs.
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          It will be interesting to see if that radio causes any interference for the MCU. Looks like it will be right over the MCU.?
                                          RJ_Make
                                          12.5k
