  3. Minimal design thoughts
299 Posts 34 Posters 278.7k Views 17 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    And the latest schematic, and layout (After I scratched the old routing, and started all over, again, for the 5th time I think :))
    Actually I enjoy this fiddling with placing components, and routing tracks.. Only problem is that the wife thinks it takes too much time, and I should do other more usefull stuff, than playing with my computer, making noncense drawings :)
    Schematics
    full layout
    top layer
    bottom layer
    Think I am ready to press the GO button for first spin in china.. This is gonna be exciting :)
    blaceyB 1 Reply Last reply
      Haha!.. I have the same problem with the wife over here. The modules and half build sensors I spread all over the house is most irritating.
      pgoP 1 Reply Last reply
      • tbowmoT
        tbowmoT
        tbowmo
        And off they go to China.. Have ordered the first batch of prototypes.. (10 pcb's, panelized with 2 sensor boards per panel)
        Now there is only the waiting time...
        N 1 Reply Last reply
        • tbowmoT tbowmo
          N
          N
          NotYetRated
          @tbowmo Amaons 2-day shipping has killed me. When I started with MySensors projects, and the China waiting time of sometimes 2-3 weeks.... Difficult haha.
          • tbowmoT
            tbowmoT
            tbowmo
            Here it's more like 3-6 weeks waiting time, for stuff to come back from China.. So maybe it arrives in time for Christmas.. And then I can't get components sourced from mouser at that time (waiting until I have seen the quality of the boards, before I order components)
              pgoP
              pgoP
              pgo
              wrote on last edited by pgo
              #54
              @hek, @tbowmo and rest: ho ho guys, first think WAF, ie Wife Acceptance Factor
              This variable has to be VERY high. Like: Darling, this whole fidling of mine would optimize our home and save on energy bills big time, so You can spend more on shopping craze. etc :)
              Probably when I finish with testing, I start selling it to friends and we will have problem spending all of the money which suddenly comes our way. (Try here not to laugh :) )
              • tbowmoT
                tbowmoT
                tbowmo
                The reason why I am building this, is that I always have been currious about collecting data at regular intervals, back in the days (8-9 years ago) I had a setup with 5 DS18B20's on long wires arround the house. One was in my furnace measuring the temperature of the water, one was outside, etc. Everything connected to my old 486 based linux machine with 20Mb ram, collecting data from all the sensors on a regular interval, and presenting it with digitemp (a php package for displaying temperatures).
                Just want to make something like that again. And I think my wife can see the ideas in it. Will just use it for environmental measurements throughout the house. Maybe some of them coupled to a SMS gateway, letting the teenagers know when to open up a window for 5 minutes, in order to get fresh air in, and the humidity level down. (And another SMS to remind them to shut the windows again).
                And then the fun in collecting data, analyzing it in graphs etc... :)
                • axillentA
                  axillentA
                  axillent
                  @tbowmo I also have some old programmers including jtagice3 and can well understand you)
                  and sure, your very small design is best to keep
                  The only problem I have to use jtagice3 (which I like a lot to do hardware debugging) is that Arduino is not supported by hardware debugging
                  Just an idea - if you have all pins needed for FTDI programming on the corner later you can have a special connector between your board and FTDI programmer. This case you can keep design without extra space needed
                  sense and drive
                  tbowmoT 1 Reply Last reply
                  • axillentA axillent
                    tbowmoT
                    tbowmoT
                    tbowmo
                    Wouldn't using jtagice3 for debugging also collide with the radio on a mysensor module?
                    There is a full ftdi header on my board now. And I just got information from China that my boards are shipped... so just waiting for them to arrive now :)
                    • axillentA
                      axillentA
                      axillent
                      #58
                      jtagice3 is using only single pin of atmega328p (RESET pin) to do programming and debugging.
                      There is no reason to have conflict with radio.
                      The only problem with jtagice3 is that arduino environment is not supporting hardware debugging.
                      I'm wondering on having ability to compile Mysensors using regular Atmel Astudio to be able to use debugging.
                      Cool! I also like 0603 footprints. But also is fine to use 0402. Sometimes you will probably need it.
                      If you need support I can prepare a bootloader for you with needed settings for boards.txt
                      sense and drive
                        tbowmoT
                        tbowmoT
                        tbowmo
                        Aaahh, yeah, I forgot about their "new" debugWire interface, so thought that a fullblown spi interface was nescessary for the ISP to program the device. Hmm.. With THAT info, I could have used a smaller pinheader, instead of the 6pin ISP header..
                        Could become handy for next revision of the board (if there'll be anny)
                        I'm used to the small components.. And for a couple of handbuild sensor boards, I thought that I might as well cope with them, in order to keep the layout small :) If this is becomming a success, and others would like similair boards, the boards should be assembled with an pick & place machine, and then it doesn't matter that the components are 0402.
                        I'll keep it in mind with the bootloader :)
                        axillentA 1 Reply Last reply
                        • tbowmoT tbowmo
                          axillentA
                          axillentA
                          axillent
                          you cannot remove ISP header because debugWire is activated through ISP )))
                          Me and Henrik we have a list of partners for PCB production, If you fine to cooperate more closer with Mysensors we can help you on putting the board unto production. Just let Henrik to know if you have an interest on closer cooperation. I will help with production.
                          sense and drive
                            tbowmoT
                            tbowmoT
                            tbowmo
                            I know, I have been talking with Henrik about it. Waiting for the first prototypes, so the design can be validated.
                            • tbowmoT tbowmo
                              Schematics
                              full layout
                              top layer
                              bottom layer
                              blaceyB
                              blaceyB
                              blacey
                              @tbowmo Nice design exciting to see it come together so well. Good luck with the first board bring-up and I look forward to hearing/seeing the results as the unfold.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #63
                                I have been looking at prices (Using mouser, as they appear to have local european storage, so I can avoid import taxes in Denmark).
                                for a temperature / humidity sensor pcb, fully mounted, the price comes up to arround 13$ per unit. The most expensive part is the Si7021, which accounts for 4.5$ per unit (even in larger quantities).
                                for BMP180 on board, it's another 4.5$ added.
                                The above prices are material only...
                                • tbowmoT tbowmo
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @tbowmo Too bad the Si7021 is still too new to show up on AliExpress. The BMP180 is like $1.5 ... ironically the complete soldered module is also $1.5 ... Chinese economy ...
                                  Component sourcing is the killer of fun things.
                                  Hmmm. Am I correct to assume then that Mouser has free shipping over €65, and that they add country taxes on top? When I check out I seem to get a 25% VAT charge for instance. Ugh. Still better than paying an extra €10+ to the Swedish Post or UPS or whoever.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @bjornhallberg
                                    Hmm.. I don't trust aliexpress that much, for example is the BMP180 you get there a counterfeit?
                                    Take the bmp180, I only need 1 of those, for the whole installation, so I don't mind paying 4-5$ more for a single unit. However, for the rest of the units, all needs the Si7021 (which is pin compatible with HTU21x device, if I remember correctly? However, the specs for the Si7021 is way better)
                                    I don't know about the taxes from mouser, as I haven't actually bought anything there yet, only set up my project, and added the components needed, so I could get a price indicator on it. But their website says that they pays import duties etc..
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      And the first prototypes have just arrived
                                      Next step is ordering components. so I can get the thing up and running..
                                      It's going to be a fun christmas :)
                                      • tbowmoT tbowmo
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        on a side note.. this IS a prototype.. probably only 1 or 2 will be assembled, as version 2 is almost ready to hit the press..
                                        Next version will have more pins available on pinheaders along each side of the board, and power input to the board is placed a more central place (electrical wise).
                                        So this prototype will be verification of schematics, and check that radio etc. is wired correctly.
                                        • bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          wrote on last edited by bjornhallberg
                                          #68
                                          Great progress!
                                          If you still use dirtypcbs (what did you think of their work btw?) and have the ability to pretty much create any sort of routing and tabs, you could look into the upcoming Gerber Panelizer:
                                          http://blog.thisisnotrocketscience.nl/projects/pcb-design-tools/
                                          Might be more cost effective to order 10x10 pcbs and panelize the hell out of that space. You could fit a ton of different layouts. Tried the tool myself and it saves a ton of time. It can load and rotate gerbers any way you want.
                                          Only snag is they haven't released the tool yet. You have to request it from from their twitter account. And it is still beta.
                                          12.5k
