  3. Where to get legit nRF24L01+ modules?
counterfeitnrf24l01+nrf24l01+pa+lna
85 Posts 9 Posters 35.4k Views 12 Watching
    I think consistency probably matters more than genuine vs. fake. In other words, if you end up with fakes, try to make sure that all your radios are all the same fake. It gets confusing when you start to mix different kinds together, because different variants can have different idiosyncrasies, and then you start to wonder whether a problem you might be having is due to a chip difference, or mix of differences, or something else. Very quickly the combinatoric complexity rises and troubleshooting becomes more time consuming.
    gohanG 1 Reply Last reply
      @NeverDie the problem is to be able to find good and fake one so that you could mark them with different colors. Not everyone have the tools 😀
        #28
        @gohan
        So what? Some people live in rural Africa without electricity or running water, and they don't have soldering irons or even solder or even any money. Are we going to worry about whether they can do this as well? I mean, where do you draw the line? The way I see it: if a hobbyist really wants to know if a particular chip is fake or genuine, then they can either buy or borrow or rent an o-scope for long enough to figure it out. The other thread tells how to figure it out using an o-scope. Prior to that thread, I had never even used an o-scope. So, the required skill level isn't very high at all.
        Nca78N 1 Reply Last reply
          @gohan
          @NeverDie but even low end oscilloscope is over 200$/€, it's expensive for a hobby.
          I don't have one, because it's too much money for the use I would have of it at the moment, and I wouldn't even have a place to store it :D
          And I don't know who I could borrow an oscilloscope from, so the quest to find a reliable supplier is worth it for me. Even if I think it will only end with buying NRF5.
          • Nca78N Nca78
            #30
            @Nca78
            In that case you could get the job done using one of the ARM chips that comes with a fast sampling AD converter and, preferably, lots of RAM. You could get it on one of the cheap demo boards to make the project easier. Fortunately, the fake nrf24's are different enough from the genuine in their Tx and Rx current draws that you won't need to split hairs on your measurements to tell them apart.
            I did something similar once for capturing and decoding RF signals using an Arduino Due, so I'm sure it can be done. In fact, you could probably use a Due for this if you wanted to, but no doubt there are better options available now.
              @Nca78
              @NeverDie said in Where to get legit nRF24L01+ modules?:
              Nope. Some of them might be, but certainly not all of them...
              • YveauxY Yveaux
                #32
                @Yveaux said in Where to get legit nRF24L01+ modules?:
                Which ones? Even the fakes have names and datasheets. The datasheet tells the tale. The ones I tested (see other thread for the details) were pretty noticeably different.
                  I've ordered many nameless modules (regular black ones) through Ali express the past years, which didn't come with a datasheet or any specs. A number of them are proven fakes (some even x-rayed by Nordic), but I've not seen any of them having a current consumption significantly different from original Nordic modules.
                  I just want to stress again that although some fake modules have a higher current consumption, this certainly isn't true for all fake modules.
                  A module with regular consumption still could be fake. X-ray is the only way to be 100% certain.
                  • YveauxY Yveaux
                    #34
                    @Yveaux
                    What was it about the chips (the ones that had identical current draws to the real thing) that you sent to Nordic for x-ray that motivated you to send them?
                    If your requirement is 100% certainty, then you may just have to make your own modules with chips procured either direct from Nordic or from a trusted supplier, like Digikey.
                      @Yveaux
                      That's not my requirement; I didn't start this thread :laughing:
                      I only have (presumably) fakes deployed around the house and they've never failed me. I won't bother getting 100% genuine ones.
                      • d00616D
                        d00616D
                        d00616
                        I have received two of the red modules. This is an X-Ray image of the chip (montage)
                        0_1500731806314_upload-666b869a-0a72-4e85-9575-5e96bf143cee
                        NeverDieN YveauxY Bogus ExceptionB 3 Replies Last reply
                        • d00616D d00616
                          @d00616 said in Where to get legit nRF24L01+ modules?:
                          Meaning?
                          d00616D 1 Reply Last reply
                            Meaning?
                            d00616D
                            d00616D
                            d00616
                            @NeverDie @Yveaux said in Where to get legit nRF24L01+ modules?:
                            Could be that different clones of the nRF exist of which some have an increased power consumption, but currently the only way to know for sure (also for Nordic ) is to x-ray them.
                            I hope somebody can say if this looks like an original.
                            • d00616D d00616
                              @d00616 the xray is rather vague.
                              Here are die shots of the original and a fake: https://zeptobars.com/en/read/Nordic-NRF24L01P-SI24R1-real-fake-copy
                              Maybe you can match them.
                              • YveauxY Yveaux
                                d00616D
                                d00616D
                                d00616
                                @Yveaux Thank you for the X-Ray images. I can't get images in that resolution.
                                • d00616D d00616
                                  @d00616 they aren't xray images. The die shots were obtained by eating away the chip package with acid.
                                    Itead or some other legit company like mouser should stock the real thing.
                                    Bogus ExceptionB
                                    Bogus ExceptionB
                                    Bogus Exception
                                    @hek Thanks for writing. I got 4 from itead the other day (2 each of 2 types), and they are in the boxes in front of me. FOr one thing-they have a box! I am making a video for my blog comparing them to the clones (as best I can), and I'm going to test out that current statement I found online...
                                    Thanks for the tip!
                                    "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                                    -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                                    -ATTiny, ATMega, STM32
                                    -Geek Channel: https://www.youtube.com/TheSalesEngineer
                                    • tbowmoT tbowmo
                                      I think that Itead studio promised me that it was genuine NRF that they used for their modules.
                                      But it's a couple of years since I purchased any from them, and I'm not sure which ones of the different NRF modules that I have, that actually came from Itead.. :)
                                      Bogus ExceptionB
                                      Bogus ExceptionB
                                      Bogus Exception
                                      @tbowmo Thanks for the tip. I have some in front of me, still in box. Will post results.
                                      • Nca78N
                                        I received my Ebyte modules, not a warranty of authenticity but the nrf chip has a square instead of a dot like all the fakes I have been using until now. I have a few standard SMD modules and a PA LNA version, I will try to make some basic range tests soon compared to the SMD clones.
                                        Bogus ExceptionB gohanG 3 Replies Last reply
                                        • Nca78N Nca78
                                          Bogus ExceptionB
                                          Bogus ExceptionB
                                          Bogus Exception
                                          OK! I followed your suggestions and tried itead. These are the pics of what I got 4 of (sorry no pro rig-just a loupe & module in one hand & mouse in the other!
                                          (all are hosted on one of my servers, not here locally)
