  3. Bluetooth Proximity Sensor
bluetoothpresence
33 Posts 9 Posters 36.4k Views 7 Watching
  • N
    N
    NotYetRated
    I think something similar can be achieved with Tasker(android) and wifi.
    Tasker detects when it connects to your home network, initiates command telling Vera "Honey, I'm Home!". My home WiFi is much more robust/extensive than any blutooth connection radius would be.
    Thoughts?
    hekH K 2 Replies Last reply
    • N NotYetRated
      Thoughts?
      @NotYetRated
      Probably easier but not as fun :)
      N 1 Reply Last reply
        @NotYetRated
        N
        N
        NotYetRated
        @hek haha ohh no denying that :)
        The blutooth sensor could definitely come in useful for any number of situations, so it would definitely be good to have! I just think, specifically for "getting home" detection, WiFi may be more robust. Then again, so long as this sensor is placed at entrance to the driveway, or in the garage, distance should be a non-issue. :)
        • Z
          Z
          Zeph
          The main advantage of BlueTooth would be its shorter range - if you have multiple of them and wanted to detect roughly where the phone was - especially if the modules had RSSI.
          • Z Zeph
            N
            N
            NotYetRated
            @Zeph Ahh, shorter range as a benefit, guess I had not considered it like that!
            • N NotYetRated
              Thoughts?
              K
              K
              Konrad Walsh
              wrote on last edited by Konrad Walsh
              @NotYetRated On one side I agree as this is what I have done for the passed few years
              The problem is, this is unreliable..
              but this along with that will make a more robust system..
              See imagine.. I have one at each door...
              I know when I am in the sitting vs the kitchen vs the bedroom..
              now my squeezelite music system follows me.. the lights follow me... and more..- EG - click vol up on my phone adjusts the volume in that room alone....
              • K
                K
                Konrad Walsh
                @hek
                I have to wait for you to figure this one out... I have tried many methods but not making progress at all...
                Your code does work by the way.. It sends and receives the data without issue.. but getting it all repackaged for a MySensors plugin isn't happening for me..
                I have taken the binary switch recipe and I am using that so that it will turn on on/off based on the BT id it sees ..
                I might start a fresh tonight.. Ill post any updates if I make progress on it..
                  I was thinking of just emulating a door-sensor. When BT detects someone in proximity it sends 1 and 0 when no-one is in range. Just like the binary switch you proposed..
                  If you want to send in which device in range you could use VAR1-5 with the BT device identifier as payload (at some interval).
                  • K
                    K
                    Konrad Walsh
                    I have given up.. I cant get anywhere with this but I think its cause I bought hc-06.. Are you closer?
                    P 1 Reply Last reply
                      Last time I tested with the new HC-05 I couldn't get it to enter AT mode. Will probably make another test when I have some time.
                      • K
                        K
                        Konrad Walsh
                        ok.. mine enters AT mode.. and I can get it to send and receive data.. I may as well keep plugging at it so
                        • K Konrad Walsh
                          P
                          P
                          PedroC88
                          @Konrad-Walsh For what I know, the HC-06 is automatically configured to take in AT commands, so that shouldn't be a problem, although mine (that I got today) seems to be defective as I send it the AT command, but I'm getting no answer.
                            I accidentally feed the first module with reversed polarity. It did not like that very much. :(
                            The second module arrived this week, but I haven't hooked it up yet. Planned on using software serial and had a test sketch going something like this:
                            /* $Id$
                            Serial terminal for the HC-05 bluetooth module.
                            Sets up BT module and allow user interaction with the device via the Arduino Serial Monitor.
                            Wiring of BT HC-05 device to the Arduino
                            RX -> 11
                            TX -> 10
                            KEY -> 9
                            #include <SoftwareSerial.h>
                            // Bluetooth to Arduino pins.
                            #define BTkey 9
                            #define BTrxPin 10
                            #define BTtxPin 11
                            enum { SYNC, ASYNC };
                            SoftwareSerial BTSerial(BTrxPin, BTtxPin);
                            // Send a command to the bluetooth device.
                            // mode ASYNC - don't want for the response
                            // mode SYNC - wait for the response
                            void sendBluetoothCommand(String cmd, uint8_t mode) {
                              Serial.print(mode == SYNC ? "SYNC> " : "ASYNC> ");
                              Serial.println(cmd);
                              BTSerial.println(cmd);
                              if (mode == ASYNC) return;
                              char ch = 0;
                              while (ch != '\n') {
                                if (BTSerial.available()) {
                                  ch = BTSerial.read();
                                   Serial.write(ch);
                               Serial.begin(57600);
                              // SETUP BLUETOOTH
                              // define pin modes for tx, rx:
                              pinMode(BTrxPin, INPUT);
                              pinMode(BTtxPin, OUTPUT);
                              // Switch module to AT mode
                              pinMode(BTkey, OUTPUT);
                              digitalWrite(BTkey, HIGH);
                              BTSerial.begin(38400);
                              sendBluetoothCommand("AT", SYNC);
                              sendBluetoothCommand("AT+NAME=blueNode", SYNC);
                              // AT+ROLE=p1
                              // p1 - 0 Slave Role, 1 Master Role, 2 Slave-Loop role.
                              sendBluetoothCommand("AT+ROLE=1", SYNC);
                              // AT+INQM=p1,p2,p3
                              // p1 - 0 inquire_mode_standad, 1 inquire_mode_rssi
                              // p2 - maximum number of bluetooth devices response
                              // p3 - the maximum of limited inquiring time. 1~48 (1.28s ~ 61.44s)
                              //      15*1.28 = 19sec
                              sendBluetoothCommand("AT+INQM=0,5,15", SYNC);
                              // Keep reading from HC-05 and send to Arduino Serial Monitor
                                Serial.write(BTSerial.read());
                              // Keep reading from Arduino Serial Monitor and send to HC-05
                              if (Serial.available())
                                BTSerial.write(Serial.read());
                            And.. the first module was of the wrong type (I think). Must support master-mode if I understand it correctly. The second one I bought was this type.
                            P
                            P
                            PedroC88
                            @hek When you say you inverted the polarity... are you talking about VCC and GRD? or Rx and TX?
                            hekH 1 Reply Last reply
                            • P PedroC88
                              @PedroC88
                              vcc/gnd
                              • K
                                K
                                Konrad Walsh
                                i am "semi" abandoned it.. I couldn't get it work at all...
                                • K
                                  K
                                  Konrad Walsh
                                  i am "semi" abandoned it.. I couldn't get it work at all... but I cant say I fully grasp the syntax yet. Hopefully @HEK gets the notion...
                                  • K Konrad Walsh
                                    P
                                    P
                                    PedroC88
                                    @Konrad-Walsh At the end I got the HC06 to work, I'm finally understanding all of this, if you tell me what you're trying to accomplish and the code u have I might be able to help. Also the module you're using.
                                    • Ø
                                      Ø
                                      Øyvind A. Espnes
                                      I really like this idea, but for it to be effective we need to measure the decibel level of the connection and not just connected/disconnected state. Is this possible?
                                      • Ø Øyvind A. Espnes
                                        P
                                        P
                                        PedroC88
                                        @Øyvind-A.-Espnes I haven't tried it, but with the AT+INQM command you can specify wether you want the RSSI of the device when issuing the AT+INQ command. This document can better explain it.
                                        After that it should just be a matter of parsing the resulting string and extract the signal strength.
                                        • D
                                          Dean
                                          I was thinking about going this route, but until last weekend I was using Tasker and having it tell Vera that I am here when my phone connects to my Wifi. I bought a new phone and I can't get it to stay connected when it hasn't been used in a while, so I have to rethink...
                                          While a Mysensors option could be good, what I am going to do is use my many Android tablets that I have throughout my home and have them always searching my my mobile. With them all throughout my home, I won't have to worry about bluetooth range.
                                          Sorry it isn't a Mysensors option, but I thought I would share what I am going to do :-)
