  3. Multiple Relays + Motion sketch, fully customizable, optional timer, manual override
24 Posts 11 Posters 10.2k Views 13 Watching
  • A
    AndreD
    How to send the relay to the gateway every 30 seconds?
    HenryWhiteH 1 Reply Last reply
    • A AndreD
      HenryWhiteH
      HenryWhiteH
      HenryWhite
      @AndreD said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
      Why would you need that?
      • A
        AndreD
        Suppose.
        We have a server + gateway + relay module 1 + relay module 2 ..... all relays are on.
        There is a power failure at the relay module ..... the relays turned off.
        The server status is old, not correct.
        The recording of the status of the relay in memory is not acceptable.
        gohanG 1 Reply Last reply
        • A
          AndreD
          person
          Next problem....
          Anybody know how edit sketch for relays to add itrms to send repeate update status to gateway? I want eliminate problem when node start and change status , but gateway is disabled. And after gateway will be enable show in my Domoticz old status/last memory before disable gateway. But after this node has changed status and this status is not show in Domoticz after run. I want to work it as Z-Wave. Z-wave has always actual status. Is any chance to also MySensors Gateway and not has always actual status ?
          • A AndreD
            Suppose.
            @AndreD actually the relay state is restored to last state as the node is rebooted. I don't see where is the problem
            • A
              AndreD
              то gohan
              Example.
              1. The server turned on the relay at 11 hours 00 minutes.
                2.In 11-02 minutes. Alarm with relay module power.
                3.In 11-05 minutes the server sends a command to turn off the relay.
              2. in 11-30 minutes. The power to the relay module resumes. (Relay Enabled)
              3. Server status is off (Relay is on)
              4. The result - the neighbors below are happy to repair: (
              Question. How to request real relay status from the server.
              Boots33B 1 Reply Last reply
              • A AndreD
                то gohan
                Example.
                Boots33B
                Boots33B
                Boots33
                @AndreD have a look here for a bit of info on requesting status.
                • B
                  B
                  Ben Andrewes
                  I'm having trouble getting Domoticz to see any more than 1 relay. I've tried the MySensors example basic relay sketch and no luck. Then I tried this one (which is amazing btw as I want to have a PIR independent of the relays) and the same problem.
                  I've tried to present the sensors individually without the FOR statement, and added a delay between presentation in case that was an issue, also I've tried different output pins on the Arduino, and I've tried multiple boards... Nothing has worked
                  I am very much an enthusiastic amateur, so any advice on what to try next much appreciated
                  Thanks in advance
                  ? 1 Reply Last reply
                  • B Ben Andrewes
                    Thanks in advance
                    A Former User
                    @Ben-Andrewes My domoticz instance behaves weirdly with relay sketches too. Maybe you can find some help here: https://forum.mysensors.org/topic/7101/domoticz-relay-node-doesn-t-show-up-in-devices/21
                    • ? A Former User
                      B
                      B
                      Ben Andrewes
                      wrote on last edited by Ben Andrewes
                      @thierryd Thanks for the reply. In case it helps anyone I ended up individually defining and presenting the relays and their parameters within the sketch rather than using the FOR statement and it worked fine.
                        Did you try to add a small delay in the presentation?
                        • B
                          B
                          Ben Andrewes
                          @gohan - yep added wait(100) between each sensor. To be honest I made a number of small changes without re-uploading and testing between so I'm not sure what solved it... Oh well, at least it works now :)
                          • O
                            O
                            Ostoja
                            Hello! Sorry for my english. This sketch works fine. But I still need to add a temperature sensor ds18b20. If I add a temperature sensor, the sketch stops working. Please help. I'm new to both Arduino and Mysensors. Many thanks!!!
                            rejoe2R 1 Reply Last reply
                            • O Ostoja
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @ostoja Please add your code. Most likely you just transfered the DS18x20-Code into the relay sketch including the sleep() at the end of the loop().
                              If you did it that way: This had been discussed here several times, you have to change the code into a so-called non-bocking loop().
                              O 1 Reply Last reply
                              • rejoe2R rejoe2
                                O
                                O
                                Ostoja
                                wrote on last edited by Ostoja
                                @rejoe2, MANY thanks for answer! Relay don't work in Domoticz :white_frowning_face:
                                // Enable and uncomment attached radio type
                                //#define MY_TRANSPORT_WAIT_READY_MS 1      // uncomment this to enter the loop() and setup()-function even when the node cannot be registered to gw
                                //----------------------- Relay and Motion Sensor Configuration -----------------------
                                #define MOTION                                                    // un-comment to enable motion sensing
                                #define NUMBER_OF_RELAYS  1                                       // Total number of attached relays. Must be equal to total number of elements in array below!
                                const int RELAYS[]                  =     {4};                    // digital pins of attached relays
                                const int MOTION_ACTIVATED_RELAYS[] =     {1,  0};                // 1 to trigger the relay through motion, 0 to not trigger. Array length must correspond to RELAYS[] array.
                                const long ON_TIMES[]               =     {300, 0};               // Specify for each element in MOTION_ACTIVATED_RELAYS, how long the specified relay should be active in seconds.
                                #define RELAY_ON          1                                       // GPIO value to write to turn on attached relay
                                #define RELAY_OFF         0                                       // GPIO value to write to turn off attached relay
                                #define MOTION_PIN        3                                       // The digital input pin of the motion sensor
                                #define MOTION_CHILD_ID   10                                      // Set the child id of the motion sensor
                                bool ack = 1;                                                     // set this to 1 if you want destination node to send ack back to this node
                                //----------------------- DO NOT CHANGE -----------------------------
                                MyMessage motion_msg(MOTION_CHILD_ID, V_TRIPPED);                 // Initialize motion message
                                unsigned long trigger_millis[NUMBER_OF_RELAYS];                   // Used for the timer
                                bool lastTripped = 0;                                             // Used to store last motion sensor value
                                bool manual_override = 1;                                         // if this gets set to 1 (e.g. by a switch or a command from the gateway), motion triggering of relays is deactivated
                                MyMessage relay_msg;                                              // Initialize relay message
                                #include <OneWire.h>
                                #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
                                int numSensors=0;
                                bool receivedConfig = false;
                                bool metric = true;
                                MyMessage msg(0,V_TEMP);
                                void before()
                                  sensors.begin();
                                  int i;
                                  for (int sensor = 1, i = 0; sensor <= NUMBER_OF_RELAYS; sensor++, i++) {
                                    // set relay pins to output mode
                                    pinMode(RELAYS[i], OUTPUT);
                                    // Restore relay to last known state (using eeprom storage)
                                    digitalWrite(RELAYS[i], loadState(sensor) ? RELAY_ON : RELAY_OFF);
                                  // set motion pin to output mode, if MOTION is defined
                                #ifdef MOTION
                                  pinMode(MOTION_PIN, INPUT);
                                #ifdef MOTION
                                  // give the motion sensor some time to settle
                                  Serial.println("Starting up. Please wait 8 seconds...");
                                  delay(8000);
                                  sendSketchInfo("Relay/Motion", "1.0");
                                     present(i, S_TEMP);
                                  for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) {
                                    present(sensor, S_BINARY, "Relay", ack);
                                #ifdef MOTION
                                  present(MOTION_CHILD_ID, S_MOTION, "Motion Sensor", ack);
                                  sleep(conversionTime);
                                    #if COMPARE_TEMP == 1
                                  sleep(SLEEP_TIME);
                                #ifdef MOTION
                                  if (!manual_override) {
                                    // Read digital motion value
                                    bool tripped = digitalRead(MOTION_PIN) == HIGH;
                                    if (lastTripped != tripped) {
                                      Serial.print("New Motion State: ");
                                      Serial.println(tripped);
                                      // Send tripped value to gw
                                      send(motion_msg.set(tripped ? "1" : "0"));
                                      lastTripped = tripped;
                                      // Change relay states, send new state to gw and store state in eeprom
                                      if (tripped == 1) {
                                        for (int i = 0; i < NUMBER_OF_RELAYS; i++) {
                                          if (MOTION_ACTIVATED_RELAYS[i] == 1) {
                                            digitalWrite(RELAYS[i], RELAY_ON);
                                            relay_msg_constructor(i + 1, V_STATUS);
                                            send(relay_msg.set(RELAY_ON));
                                            trigger_millis[i] = millis();
                                            Serial.print("Relay ");
                                            Serial.print(RELAYS[i]);
                                            Serial.println(" turned on");
                                            saveState(i, 1);
                                      if (tripped == 1 and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) {
                                      if ((trigger_millis[i] + ON_TIMES[i] * 1000 < millis()) and MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) {
                                        digitalWrite(RELAYS[i], RELAY_OFF);
                                        send(relay_msg.set(RELAY_OFF));
                                        Serial.println(" turned off");
                                        saveState(i, 0);
                                        trigger_millis[i] = 0;
                                  else {
                                      if (MOTION_ACTIVATED_RELAYS[i] == 1 and trigger_millis[i] != 0) {
                                        trigger_millis[i] = 0;                            // reset running timers
                                  // Handle incoming relay commands
                                    if (RELAYS[message.sensor - 1]) {
                                      digitalWrite(RELAYS[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF);
                                      // Store state in eeprom
                                      saveState(message.sensor - 1, message.getBool());
                                  // Handle incoming manual override/bypass of motion sensor
                                  if (message.type == V_ARMED and message.sensor == 0) {
                                    manual_override = message.getBool();
                                    Serial.print("Manual Override: ");
                                    Serial.println(manual_override);
                                void relay_msg_constructor(int sensor, uint8_t type)
                                  relay_msg.setSensor(sensor);
                                  relay_msg.setType(type);
                                dirkcD 1 Reply Last reply
                                • O
                                  O
                                  Ostoja
                                  I commented out the "sleep", but when I press the relay switch in Domoticz, it does not work:white_frowning_face:
                                  • O Ostoja
                                    int numSensors=0;
                                    bool metric = true;
                                    void before()
                                      sensors.begin();
                                      int i;
                                    #ifdef MOTION
                                    #ifdef MOTION
                                      delay(8000);
                                         present(i, S_TEMP);
                                    #ifdef MOTION
                                      sleep(SLEEP_TIME);
                                    #ifdef MOTION
                                          if (tripped == 1) {
                                                saveState(i, 1);
                                            saveState(i, 0);
                                      else {
                                    dirkcD
                                    dirkcD
                                    dirkc
                                    wrote on last edited by dirkc
                                    #21
                                    @ostoja said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
                                         present(i, S_TEMP);
                                    With this two "for" loops you set present(n) multiple times. in the first for() you start with 0 until MAX_ATTACHED_DS18B20-1, in the second for() you start with 1 until NUMBER_OF_RELAYS-1, so this will assign the sensors with identical IDs as the relays.
                                    I have not checked the internal code of this method, but I would think that you should better user a different range in the second for() loop starting at least with MAX_ATTACHED_DS18B20+1.
                                    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                                    • rejoe2R
                                      rejoe2R
                                      rejoe2
                                      wrote on last edited by rejoe2
                                      #22
                                      @dirkc said in Multiple Relays + Motion sketch, fully customizable, optional timer, manual override:
                                           present(i, S_TEMP);
                                      Additional remarks:
                                      For the relays better start with 1.
                                      Shift the Temp values to higer range (use e.g. a variable like FRIST_DS_SENSOR_ID).
                                      Check, if the receive()-part and the ID you get really fits together with the relay you want to switch.
                                      Don't try to read the temperature values every few parts of a second. Use a millis()-routine.
                                      Please search the forum, there have to be at least 2 threads with exactly the same problems in which I posted how to solve this. You are "trying to reinvent the wheel". :grin:
                                      • O Ostoja
                                        dirkcD
                                        dirkcD
                                        dirkc
                                        @ostoja look at this video with an explanation of this topic and how to handle the IDs
                                        https://forum.mysensors.org/post/26597
                                        • B
                                          B
                                          bereska
                                          @HenryWhite thank you for the excellent sketch. It works like a charm in my HA configuration!
