  3. nRF5 action!
nRF5 action!
    BTW, here's a picture of how the silkscreen looks and which shows DEC1 in the "DEC5" location:
      @NeverDie I can't see the Generic nrf52 board setting
      That's all I know, so hopefully someone who knows more can chime in and offer you guidance.
      #294
      Oh, I see now that @d00616 already has. Sorry, my browser didn't refresh, so I missed seeing his post.
        Mike_Lemo
        Yeah he did I just preformed a local search for that arduino15 on my PC
          Mike_Lemo
          Also If I want to change the UART pins to other pins would it work without errors or If I want to use 2 or more UARTS? same with I2C
          Also what are the debugging options available sins the RS232 is not connected to the MCU like in an arduino how would I set stop points or peek at variables values to see if the code runs as expected?
          d00616D 1 Reply Last reply
          • M Mike_Lemo
            you should follow this schematic design if you want to get this module working.
            #297
            There's a bunch of similar looking schematics in the nRF52832 datasheet for the nRF52832 chip itself, but I'm not sure which of them, if any, is applicable to the Ebyte module. I guess maybe Ebyte needs a demo board schematic like Raytac has. Either that, or we need a schematic of what's on the Ebyte module itself. As it stands, I think maybe there's no enough info with which to move ahead on wiring up the Ebyte module. Am I wrong? Come to think of it, I think some of the other Chinese modules I ordered from Aliexpress may also be similar "mystery" modules. :(
            • M Mike_Lemo
              d00616D
              d00616D
              d00616
              The Chip has a lot of periphery on it. You can connect most components to pins. There is only one hardware UART, which can be connected. Please look at the Infocenter The arduino-nrf5 port is limited to things are implemented with arduino-samd by the author. This is the reason I have implemented an extension for hwPinMode() in MySensors.
              Another fine thing is the implementation of Shortcuts and the PPI. You can do a lot without using the CPU.
              Debugging depends on your programmer and flashing tool. I think you can start by search for "openocd gdb". OpenOCD is the flashing tool in arduino-nrf5 for all supported programmers.
                #299
                It looks as though raytec does make two modules for the nRF52832 that has a PCB antenna rather than a chip antenna: the MDBT42Q-P and the MDBT-42V-P:
                http://statics3.seeedstudio.com/assets/file/bazaar/product/MDBT42Q-Version_B.pdf
                The MDBT-42V-P looks nice because of its small size. Anyone know where it can be purchased? All of a sudden, buying a module that comes with a proper datasheet seems appealing.
                  Mike_Lemo
                  @NeverDie I had mine from seeed studio
                  • M Mike_Lemo
                    This one? https://www.seeedstudio.com/MDBT42Q-nRF52832-based-BLE-module-p-2736.html
                      I was just now noticing that Nordic has a very convenient list of third party modules (and their dimensions) that use the Nordic nRF52832 chips: https://www.nordicsemi.com/eng/Products/3rd-Party-Bluetooth-low-energy-Modules
                        #303
                        FWIW, I just now sent an email to support@cdebyte.com requesting either a schematic of their E73-2G4M04S module itself or a schematic for a demo circuit, so that I may be certain about adding the appropriate hardware needed to get their module to work. I'll post if I hear anything back from them.
                        By the way, in the case of Raytac, they even have their own demo board: https://raytac.blog/2017/01/24/how-to-use-raytac-mdbt42q-nordic-nrf52832-demo-board/
                        mtiutiuM 1 Reply Last reply
                          I saw this in the MDBT42Q module datasheet, and perhaps it explains the relatively poor performance of the nRF52832 Adafruit Feather which uses the MDBT42Q.:
                          I believe the Adafruit may have a much smaller ground plane than what is being recommended here by Raytac.
                            mtiutiuM
                            mtiutiuM
                            mtiutiu
                            #305
                            I requested the schematic for the cdebyte module too...but they replied: it's confidential - LOL.
                            NeverDieN scalzS 2 Replies Last reply
                            • mtiutiuM mtiutiu
                              #306
                              @mtiutiu
                              How long did it take them to reply to you?
                              I guess we may have to reverse engineer what they did then--at least roughly--in order to use it. I'll see if I can pry the cover off and photograph what's inside. If I'm successful, then I'll post the photos so we can all look at it together.
                                @mtiutiu
                                mtiutiuM
                                mtiutiuM
                                mtiutiu
                                #307
                                About 6 hours. I asked them too if the Nordic datasheet recommendations were followed or not and if they can provide an example of how to use the module.
                                • mtiutiuM mtiutiu
                                  What was their answer to that, or is it still pending? I don't mind them being a black box, provided they show how to use it.
                                  • mtiutiuM mtiutiu
                                    this one is funny, like if there was something special in their module :laughing:
                                      mtiutiuM
                                      mtiutiuM
                                      mtiutiu
                                      Didn't replied yet. When I get an answer I'll post it here so no worries.
                                        Here's a photo with the lid pried off:
                                        Maybe we can reconstruct what's going on just from looking at the components and the trace lines? At least for now, I'm not so concerned with the RF part.
                                        JokgiJ 1 Reply Last reply
                                          Here's a photo taken from the opposite angle:
                                          Any other photos anyone wants to see?
