  3. nRF5 action!
nRF5 action!
    #291
    I added the two caps that Scalz suggested for DEC1 and DEC2, but I'm still getting the same error message as before when I try to program it using the DK. Unless someone has further ideas, I may have to wait two weeks for my breakout board to arrive before I do more, as right now I'm just deadbugging this by soldering wires directly to the module.
    • M Mike_Lemo
      @NeverDie I can't see the Generic nrf52 board setting
      #292
      That's all I know, so hopefully someone who knows more can chime in and offer you guidance.
        BTW, here's a picture of how the silkscreen looks and which shows DEC1 in the "DEC5" location:
          #294
          Oh, I see now that @d00616 already has. Sorry, my browser didn't refresh, so I missed seeing his post.
            Mike_Lemo
            Yeah he did I just preformed a local search for that arduino15 on my PC
              Mike_Lemo
              Also If I want to change the UART pins to other pins would it work without errors or If I want to use 2 or more UARTS? same with I2C
              Also what are the debugging options available sins the RS232 is not connected to the MCU like in an arduino how would I set stop points or peek at variables values to see if the code runs as expected?
              d00616D 1 Reply Last reply
              • M Mike_Lemo
                you should follow this schematic design if you want to get this module working.
                #297
                There's a bunch of similar looking schematics in the nRF52832 datasheet for the nRF52832 chip itself, but I'm not sure which of them, if any, is applicable to the Ebyte module. I guess maybe Ebyte needs a demo board schematic like Raytac has. Either that, or we need a schematic of what's on the Ebyte module itself. As it stands, I think maybe there's no enough info with which to move ahead on wiring up the Ebyte module. Am I wrong? Come to think of it, I think some of the other Chinese modules I ordered from Aliexpress may also be similar "mystery" modules. :(
                • M Mike_Lemo
                  d00616D
                  d00616D
                  d00616
                  The Chip has a lot of periphery on it. You can connect most components to pins. There is only one hardware UART, which can be connected. Please look at the Infocenter The arduino-nrf5 port is limited to things are implemented with arduino-samd by the author. This is the reason I have implemented an extension for hwPinMode() in MySensors.
                  Another fine thing is the implementation of Shortcuts and the PPI. You can do a lot without using the CPU.
                  Debugging depends on your programmer and flashing tool. I think you can start by search for "openocd gdb". OpenOCD is the flashing tool in arduino-nrf5 for all supported programmers.
                    #299
                    It looks as though raytec does make two modules for the nRF52832 that has a PCB antenna rather than a chip antenna: the MDBT42Q-P and the MDBT-42V-P:
                    http://statics3.seeedstudio.com/assets/file/bazaar/product/MDBT42Q-Version_B.pdf
                    The MDBT-42V-P looks nice because of its small size. Anyone know where it can be purchased? All of a sudden, buying a module that comes with a proper datasheet seems appealing.
                      Mike_Lemo
                      @NeverDie I had mine from seeed studio
                      • M Mike_Lemo
                        This one? https://www.seeedstudio.com/MDBT42Q-nRF52832-based-BLE-module-p-2736.html
                          I was just now noticing that Nordic has a very convenient list of third party modules (and their dimensions) that use the Nordic nRF52832 chips: https://www.nordicsemi.com/eng/Products/3rd-Party-Bluetooth-low-energy-Modules
                            #303
                            FWIW, I just now sent an email to support@cdebyte.com requesting either a schematic of their E73-2G4M04S module itself or a schematic for a demo circuit, so that I may be certain about adding the appropriate hardware needed to get their module to work. I'll post if I hear anything back from them.
                            By the way, in the case of Raytac, they even have their own demo board: https://raytac.blog/2017/01/24/how-to-use-raytac-mdbt42q-nordic-nrf52832-demo-board/
                            mtiutiuM 1 Reply Last reply
                              I saw this in the MDBT42Q module datasheet, and perhaps it explains the relatively poor performance of the nRF52832 Adafruit Feather which uses the MDBT42Q.:
                              I believe the Adafruit may have a much smaller ground plane than what is being recommended here by Raytac.
                                mtiutiuM
                                mtiutiuM
                                mtiutiu
                                #305
                                I requested the schematic for the cdebyte module too...but they replied: it's confidential - LOL.
                                NeverDieN scalzS 2 Replies Last reply
                                • mtiutiuM mtiutiu
                                  #306
                                  @mtiutiu
                                  How long did it take them to reply to you?
                                  I guess we may have to reverse engineer what they did then--at least roughly--in order to use it. I'll see if I can pry the cover off and photograph what's inside. If I'm successful, then I'll post the photos so we can all look at it together.
                                    @mtiutiu
                                    mtiutiuM
                                    mtiutiuM
                                    mtiutiu
                                    #307
                                    About 6 hours. I asked them too if the Nordic datasheet recommendations were followed or not and if they can provide an example of how to use the module.
                                    • mtiutiuM mtiutiu
                                      What was their answer to that, or is it still pending? I don't mind them being a black box, provided they show how to use it.
                                      • mtiutiuM mtiutiu
                                        this one is funny, like if there was something special in their module :laughing:
                                          mtiutiuM
                                          mtiutiuM
                                          mtiutiu
                                          Didn't replied yet. When I get an answer I'll post it here so no worries.
