  3. Nothing on serial monitor on MySensor sketches
18 Posts 3 Posters 9.2k Views 1 Watching
  • H
    H
    hooraysimpsons
    Further update:
    When connecting the monitoring gateway to the serial monitor I see "Started" and if I send a message from MyMQTT on Android I see the message. So the gateway portion and the ethernet portion are working. Cannot confirm radio is working yet.
    On my light sensor I can build a sketch that doesn't use MySensors and I can read the light level on the serial monitor. When I use MySensors, I get nothing on the serial monitor. Debug is enabled on myconfig. I'm not sure at which point in the process the failure occurs since nothing prints to the serial monitor.
    I haven't added any capacitors to the radios. I saw that this could help with signal but I'm not sure this is the issue since the two device are 2-4 feet from each other.
    Is it safe to assume that if the radio connection was the problem, that I would received some kind of feedback about not being able to connect on the serial monitor?
      Which light sketch are you using? BH1750FVI or LM393?
      Have you confirmed communication with just a serial gateway/IDE serial monitor?
      • H
        H
        hooraysimpsons
        The sensor is like the LM 393 and it is the analog output sketch.
        When using the Arduino IDE serial monitor:
        If I make my own sketch from scratch or use the Arduino example sketch to read analog output, I get a reading from the sensor. If I use the example MySensors sketch and disable all the commands with gw in them, I can get a reading as well. However, when I use the MySensors related commands including gw.begin, I get nothing on the serial monitor.
        I am having similar issue with a soil moisture monitor.
        hekH 1 Reply Last reply
        • H hooraysimpsons
          @hooraysimpsons
          Strange.. IDE version?
          Serial should be set to 115200 by default.
          Maybe you could try to lower it in gw.setup() if your USB cable is junk.
          • H
            H
            hooraysimpsons
            Ardunio 1.0.6
            This code works:
            #define CHILD_ID_LIGHT 0
            int lastLightLevel;
            Serial.begin(9600);
            // gw.begin();
            // gw.sendSketchInfo("Light Sensor", "1.0");
            // gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
            int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
            Serial.println(lightLevel);
            // gw.send(msg.set(lightLevel));
            lastLightLevel = lightLevel;
            delay(1000);
            // gw.sleep(SLEEP_TIME);
            • H
              H
              hooraysimpsons
              with gw.setup I get:
              LightSensor:18: error: 'class MySensor' has no member named 'setup'
              • H
                H
                hooraysimpsons
                If the issue was a bad radio would there still be some kind of output on the serial monitor or would the failure to connect to the gateway cause an issue that prevents the remainder of the code from executing and giving an output?
                • H
                  H
                  hooraysimpsons
                  If I replace gw.begin() with the below line of code and continue to comment out the remainder of the gw lines I can get the light output on the serial monitor.
                  void begin(void (* msgCallback)(const MyMessage &)=NULL, uint8_t nodeId=AUTO, boolean repeaterMode=false, uint8_t parentNodeId=AUTO, rf24_pa_dbm_e paLevel=RF24_PA_LEVEL, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE);
                  My understanding is the gw.begin() and that line of code should be equivalent. I've coded in the past with Fortran but not for years so I may be missing something obvious here.
                    wrote on last edited by hek
                    Sorry meant you could edit begin() (not setup) in MySensor.cpp to lower the serial baudrate above if you have problem with the serial line at high speeds.
                    You should at least get a startup message if you have DEBUG enabled in MyConfig.h.
                    Remve Serial.begin(9600); from your sketch and use the baudrate you use /set in begin().
                    • H
                      H
                      hooraysimpsons
                      #define BAUD_RATE 9600 is already placed in mysensors.h.
                      I don't see any reference to baud rate or starting the serial output in the begin function in mysensors.h
                      That is why I added serial.begin(9600) to the sketch to see if that helped. It didn't but I left it in so that it would be started when I commented out the gw.begin
                        Set it here:
                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L38
                        Which affects this line:
                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L36
                        • H
                          H
                          hooraysimpsons
                          I forgot about the .cpp files. Did I tell you I was new to this?
                          So by placing serial.println commands in my mysensors.cpp file I have identified where things seem to get stuck:
                          Within the findparentnode routine:
                          Serial.println("FPN1");
                          sendWrite(BROADCAST_ADDRESS, msg, true);
                          I'll keep investigating when I get time. Thanks for your help
                          • H
                            H
                            hooraysimpsons
                            I turned on failure_handling within the rf24 config. Now I get the following messageon my serial output:
                            send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
                            as well as:
                            sensor started, id 255
                            req node id
                            This happens three times before it appears to give up and runs the rest of the parent sketch which starts a serial output of A0.
                            • daulagariD
                              daulagariD
                              daulagari
                              Seems like your node is requesting a id from a controller, see for example http://forum.mysensors.org/topic/531/using-an-uno-for-sensor-with-negative-results
                              • H
                                H
                                hooraysimpsons
                                I added capacitors to my radios to see if that would help. I'm also testing with a serial gateway without much difference. I tried assigning a node id of 1. Didn't seem to change much.
                                The debug output goes to the serial monitor correct? I'm wondering why I'm not getting any debug messages.
                                • H
                                  H
                                  hooraysimpsons
                                  Ok. My primary problem was the radios I purchased form Ebay weren't the correct type. I've purchased new ones. Still got some problems to work through but I'll put in a seperate thread.
                                  For others reading later:
                                  Other references to these radios:
                                  http://forum.mysensors.org/topic/878/no-debug-data-from-sensors-or-gateway-bad-radios
                                  http://forum.mysensors.org/topic/728/radio-setup-give-check-wires/17
                                  And specifically mentioned on the troubleshooting page as well.
