  3. Browser-based firmware generator
108 Posts 14 Posters 56.3k Views 18 Watching
  • P pjr
    Feature request: support for RS485 network!
    rakeshpaiR
    rakeshpaiR
    rakeshpai
    @pjr Noted. Thanks. Are there a lot of people using RS485? (I have no idea, and I'm constantly surprised by how people use MySensors.) My only concern is that I don't want to add too many features that people won't use, since it would make the UI confusing. But if it's a popular feature, it's definitely on the to-do.
    • P
      P
      pjr
      @user2684 wow, that was fast! Thanks!
      @rakeshpai I can understand that. Not sure about the amount of rs485 users but one at least :)
      • dbemowskD
        dbemowskD
        @rakeshpai I just took a quick look at this, and this will be an awesome tool. I didn't read through all 96 comments, so forgive me if my questions have already been asked and answered.
        First, are all of the libraries for the included devices in the list going to be included in the zip file. These would be needed at compile time when uploading the firmware to the nodes.
        Next, would there be a way to add sensors and their required libraries? If/when adding new devices/sensors, is there going to be something that defines the code structure for the device so when the code is being built it knows how to deal with it?
        I am assuming that all of the sensors/devices in a network will be saved in a list for future reference and updating. Is there going to be any fields to add notes about a device and possibly a field where a location can be identified for a device such as "West wall of the great room" for a light switch or something like that.
        Last, and this is more of a feature suggestion that would kind of tie into the last question, it would be nice if the user could upload floor plan images and be able to place the devices on the floor plan with an icon or something to be able to better identify where nodes are. A feature like this may be a bit of a stretch, but who would I be if I didn't at least suggest it.
        Thanks for the contribution and keep up the good work.
        rakeshpaiR 1 Reply Last reply
        • dbemowskD dbemowsk
          rakeshpaiR
          rakeshpaiR
          rakeshpai
          @dbemowsk Thanks! It's very encouraging to know that this is useful.
          I've been thinking about the libraries problem. The easiest-to-use solution is to put it in the zip, so I'll probably just ultimately choose that. Problem is the way Arduino looks up dependencies. It has to be globally installed, or put in a flat directory structure in the local folder. Both of these are unappealing solutions.
          I'll be adding the ability to compile with PlatformIO soon, which has a built in dependency manager, but that's really just an alternative, not a solution.
          This tool is built on top of NodeManager, so if you need a new sensor, NodeManager is the right place to contribute. There will be a lag between when NodeManager implements something and I make it available here, but I could prioritise based on demand. I haven't considered the ability to add custom sensors by yourself directly into the UI. I'll think about it. I suspect it might make things too complicated though.
          Fields for notes and stuff is a great idea! Thanks for suggesting. I'll add this to the UI soon. Adding an ability to import and export all your data is on the cards. I completely agree that having an archivable dump of everything is very important for backups. (Would things like Dropbox integration be interesting as well?)
          Noted about the floor plan thing. I'll wait for more votes for it. I've always thought it would be cool too, but I've felt that it's a lot of effort to implement, then a lot of effort to configure correctly, and finally too little to gain from it. But then, if there's interest, why not!
          (PS: Speaking of diagramming, I've given some superficial thought to having a feature where it generates a schematic of the circuit, based on your configuration. What do you think?)
          dbemowskD 1 Reply Last reply
          • rakeshpaiR rakeshpai
            dbemowskD
            dbemowskD
            #99
            @rakeshpai You mention about Dropbox, either that or Google Drive would be interesting options.
            I know the floor plan thing is a stretch as it is a bit of coding to make that kind of thing work. I just figured I'd throw the hook out there and see who might bite on the worm.
            I like the schematic thing too, but that, much like the floor plan thing might be hard to do.
            • U
              U
              user2684
              @rakeshpai FYI I'm making some good progress with the new version of NodeManager (https://github.com/mysensors/NodeManager/milestones) thanks also to the many users contributing :-) However, the list of things to do is still pretty long and last thing I want to do is to keep your amazing project on hold depending on mine. So whenever you are almost ready, just let me know so that I can push some of the less critical requests I have on the list to another release and hurry up to finalize the current one I'm working on. Whenever you will tell me "I'm ready", I expect at least a couple of weeks for me to finalize the current code and test the release before will be made available. Thanks
              • U user2684
                rakeshpaiR
                rakeshpaiR
                rakeshpai
                @user2684 Thanks for the update. Much appreciated.
                The thing is, I think it'll be really great if this project can come to a point where I can confidently tell people that they can flash the output code to their devices, at least in a test setup, so that I can start to get some usage-based feedback. So far, I've very vocally said that the output isn't ready, and that's definitely limiting usage.
                So, I wouldn't say it's urgent, but user-feedback is important, so I'd like to start making releases that I can ask people to try.
                U 1 Reply Last reply
                  U
                  U
                  user2684
                  @rakeshpai fully agree with you. I'll start working in order to push those changes which are not a priority or too complex to implement to a future release in order to finalize v1.6 asap and give you the time to start working with something stable. Mean while I'll let you know once the development code will be good enough to start working on it. I can probably target a final v1.6 by end of August and a stable version in a couple of weeks if it fits your plans. I've also created a specific thread we can use to discuss about the integration (https://forum.mysensors.org/topic/7212/integrating-nodemanager-with-sketch-generator) so to keep this as clean as possible from implementation details. Thanks!
                  • rakeshpaiR
                    rakeshpaiR
                    rakeshpai
                    Sorry for the long silence. it might look like I've been slacking off (and that's mostly true), but I've also been rolling out some updates:
                    • Code can now either be downloaded for the Arduino IDE or for the PlatformIO IDE. The PlatformIO code generates additional config files to use their dependency manager automatically. This means, you don't have to download and install libraries manually. Just open in PlatformIO and build the project. It's magical.
                    • Also, you can now download a backup zip of everything. It contains code for the entire network and all it's nodes, and a network.json file. I haven't implemented a 'restore' functionality yet (coming soon), but the network.json file contains everything needed for a restore. The network.json is the internal state data-structure used by the app.
                    • Couple of minor performance improvements, especially to help with the first-ever-visit scenario. (All subsequent user actions are blazing fast anyway.)
                    To clarify, while backups are a great idea, you don't need to save anything. Stuff is still automatically saved in the browser's storage anyway during regular use, and is persisted even if you close the browser. Backups are for the assurance of having a neat little zip containing everything on your hard drive, just in case things go horribly wrong.
                    Very little has changed visually. To find these new features, launch the app, and click the 'hamburger menu' at the top right of the page.
                    https://rakeshpai.github.io/mysensors-network-manager/
                    • rakeshpaiR
                      rakeshpaiR
                      rakeshpai
                      wrote on last edited by rakeshpai
                      #104
                      Pretty big update: Added the ability to select the board that the node/gateway is based on. Supported boards are: Pro Mini (5v and 3.3v), Nano and Uno for the atmega328 boards, and NodeMCU and D1 Mini for the esp8266 boards. Please let me know if your favourite board isn't listed here.
                      The selection of the board effects the list of available pins for sensors. The sense pin dropdown for sensors now shows the appropriate pins (analog/digital/interrupt pins) based on the board selected for the node and the type of sensor being configured.
                      The selected board also affects the platformio.ini file generated, which makes PlatformIO integration even more enjoyable to use. No need to specify the board during the build.
                      This was a pretty big update, including changes to the underlying internal datastructure itself, so it's also an acid test for the data migration and versioning system implemented before. If you don't see any errors when you refresh after the update, it means everything worked transparently, and that's great news! (The migration mechanism hasn't been tested so far, so please let me know if you see errors when you get the update.)
                      Also implemented a reporting interval setting for analog sensors, to bring it in line with the latest changes in NodeManager.
                      We're getting closer to being release-ready!
                      EDIT: Also, this project crossed 100 commits in GitHub already! Wow!
                      • alowhumA
                        alowhumA
                        alowhum
                        @rakeshpai , is this project still being developed? The Github page seems to indicate the last development was a year ago. Is there more development in secret? I really like it.
                        My dream solution for beginners usability would be a web interface where you can manage the network and the Arduino code. Users then connect an Arduino Nano or Micro:bit to the Raspberry Pi, and press the 'upload code' button for a specific device.
                        That way they don't need to install the Arduino IDE on their own laptops, but it can be incorporated into a smart home disk image instead.
                        *dreams on
                        bjacobseB 1 Reply Last reply
                        • alowhumA alowhum
                          *dreams on
                          bjacobseB
                          bjacobseB
                          bjacobse
                          @alowhum
                          If you take a look at the gitpage:
                          Quote: "mysensors-network-manager
                          A web-based tool to generate firmware for MySensors nodes.
                          It buggy, incomplete, it doesn't even work. Don't use this for anything important."
                          https://github.com/rakeshpai/mysensors-network-manager
                          alowhumA 1 Reply Last reply
                          • bjacobseB bjacobse
                            @alowhum
                            alowhumA
                            alowhumA
                            alowhum
                            @bjacobse Yes I know, but I was hoping that the latest code hadn't reached Github. And that there could be some explanation of that claim. It seemed to work ok when I tried it, and the interface looks really good.
                            • alowhumA alowhum
                              rakeshpaiR
                              rakeshpaiR
                              rakeshpai
                              @alowhum Sorry, I have abandoned this project. It didn't garner the interest I hoped it would, and I’ve moved on to other microcontrollers/radios/networks since then. This is hosted on GitHub’s free static hosting, so it should continue to work as long as they are in business, and it should work on devices as it was 5-6 years ago. But I won’t be supporting it and won’t continue to build on it. Glad to hear that you like it!
