  3. nRF24L01+PA
nRF24L01+PA
22 Posts 5 Posters 18.1k Views 3 Watching
    wrote on last edited by hek
    What is your PA-level in MyConfig.h?
    • D
      dzairo
      Hi.
      I use standard setting :
      #define RF_24_PA_LEVEL RF_PA_MAX
      #define RF24_PA_LEVEL_GW RF24_PA_LOW
      I thinks that is not problem.. ask other user if test nRF24L01+ with PA + LNA .. and what distance have ..
      this version is +20db signal power , manufacturer say 1km .. I have same range like standard module..
      regards.
        Set this to RF24_PA_MAX also.
        • D
          dzairo
          hmmm. this is not problem I thinks. but I try it of course
          rebards
          • daulagariD
            daulagariD
            daulagari
            wrote on last edited by daulagari
            I assume you have an antenna connected, right?
            With an antenna[*] comes directivity so if things are not pointed correctly you can indeed get less range than using a normal board.
            [*] Unless you use invented an isotropic radiator ;-)
            • D
              dzairo
              ....antenna problem ?..
              hmmm. must find someone who use this module and have real experience..
              • daulagariD
                daulagariD
                daulagari
                I have the module in use but did not directly compare the range with an normal module.
                That is also almost impossible because the antennas are different and with things working on 2.4 GHz, moving an unit just 5 centimeter can make a huge difference.
                • D
                  dzairo
                  hmmmm... on e-shop write 1km .. but I have same distance like standard module with PCB antenna..
                  • daulagariD
                    daulagariD
                    daulagari
                    Can you provide the link?
                    Like I wrote, I am not 100% surprised. What is the range you get?
                    Have also a look at http://forum.mysensors.org/topic/182/standard-versus-lna-pa-radio-modules
                    • D dzairo
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      Unless you are comparing in an open field, line-of-sight, then comparing distance is somewhat nebulous.
                      What you likely want is better performance throughout your home. The radio's (despite your increased power output antenna) performance is to a much greater extent affected by the position of the two transceivers and the objects between them.
                      I too have struggled with trying to glean some improvements in my network with higher power antennas , with not much success. The only one I have working (and it sucks up batteries) is the mailbox sensor which is line of sight with my gateway through a window.
                      • D
                        dzairo
                        for example : http://www.ebay.com/itm/2PCS-2-4G-NRF24L01-PA-LNA-SMA-Antenna-Wireless-Transceiver-communication-module-/400673455926
                        U know this ,that external antenna with external amplifier must make twice more distance..
                        • D dzairo
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @dzairo
                          Twice the distance through air, perhaps.
                          But, through a wall constructed of concrete reinforced with steel... well, it may penetrate the paint twice as deep, I guess.
                          • daulagariD
                            daulagariD
                            daulagari
                            Guys, please have a look at http://forum.mysensors.org/topic/182/standard-versus-lna-pa-radio-modules
                            Ignoring antenna effects, if only one side has a ePA + LNA your link budget is only 2.6 dB better. In open air 6 dB means doubling the distance, in other environments you need often 10 dB extra to double distance.
                            • D
                              dzairo
                              no ,I tested it on free space.. I can compare ..
                              • daulagariD
                                daulagariD
                                daulagari
                                Free space is a good start but like indicated there are still numerous gotchas:
                                • How is the powering/decoupling of the radio's
                                • Are the antennas pointed to each other
                                • How high are the antenna placed above ground
                                Some photo would be nice.
                                • D
                                  dzairo
                                  today is late .. tomorrow .. where are you from?
                                  regards
                                  • D
                                    dzairo
                                    ...ehm... today I make some test..
                                    I test standard module (PCB antenna ) and module with external antenna..
                                    same result .. if use standard module then 30m is distance +- few meter .. with external antenna also same distance ..
                                    I solder big capacitor to mule 2200uF , 6.3V .. and power 3V for node and 3.3V for gateway ..
                                    I make test with all antenna what I have .. must find beter antenna and will make testing again.. ..
                                    in osme forum I read that user have with 1Mb speed 540m distance..
                                    regards..
                                    • daulagariD
                                      daulagariD
                                      daulagari
                                      30 meter is less than I would expect for two antennas seeing each other and enough clearance but to give some meaningful feedback a photo would help.
                                      A big capacitor is not better, what counts is ESR (or the "Freq. measured" in the table) and the capacitor being big enough. The higher the frequency the better the capacitor can "reject" high frequency noise on the power supply.
                                      • EasyIoTE
                                        EasyIoTE
                                        EasyIoT
                                        @dzairo I'm using nRF24L01+ with PA on my server side and normal NRF24L+ on node side. At beginning I have norlam NRF24L+ on server side. I dint't see big improvement in range/reliability when I change to PA module. But I notice something strange. PA module works better with PA_HIGH than with PA_MAX.
                                        EasyIoT framework http://iot-playground.com
                                        • D
                                          dzairo
                                          interesting..
                                          write more .. or make more test..
                                          thanks..
