  3. Vera MySensors plugin : Cannot send command - communications error
10 Posts 3 Posters 4.1k Views 3 Watching
  • B Offline
    B Offline
    BulldogLowell
    After a couple year hiatus I'm trying to update my MySensors network to the latest version. My Vera controller crapped out, otherwise I'd still be very happy with my older version... now I have to re-learn (fun).
    Starting with the Ethernet Gateway, after using this code:
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    //#define MY_IP_ADDRESS 10,0,1,5
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    and Vera version 1.7.855, I am able to see the connection in the plugin:
    but I am getting this nasty error after the Luup loads:
    the Serial debug from the gateway displays only this:
    anyone seen anything like this?
    • B Offline
      B Offline
      BulldogLowell
      I've tried removing and reloading the plugin, but no worky...
      Anyone have suggestions? I'm using the Arduino W5100 Arduino Shield...
      • B Offline
        B Offline
        BulldogLowell
        So, keeping with the communication with myself...
        I was able to properly connect the gateway switching some pins around, I guess that happened sometime in the last couple of major upgrades. The ethernet gateway (I was using for mire than two years( I'd assumed was wired properly.
        Gateway is now on v1.5, my Vera UI7 can see it with no communication issues.
        However, I now have the problem of Can't Press start for inclusion on Gateway which folks advised to downgrade the Arduino IDE and compile the Gateway using Arduino IDE 1.6.11.
        I tried that but it will not compile.
        Can someone (anyone) tell me how to compile the Ethernet Gateway for Version 1.5 such that it will not suffer from the IDE bug and reset when I press the include button in my connected Vera?
        The instructions just tell you to download the latest version of the IDE...
        K peterjacksonP 2 Replies Last reply
        • B BulldogLowell
          K Offline
          K Offline
          korttoma
          Hi Jim,
          What MySensors library version are you using now?
          What kind of compile error are you getting? I think I remember there was some issue with new versions of avr board deffinitions, please chech what version you are using.
          All so try uncommenting the following for the inclusion issue:
          I'll see if I can find something more helpful to share when I find some time.
          Br,
          Tomas
          • Tomas
          B 1 Reply Last reply
          • B BulldogLowell
            peterjacksonP Offline
            peterjackson
            @BulldogLowell,
            I have been having the exact same issues. However, I have finally got inclusion to start working. The trick for me was not down grading the whole IDE, but only downgrading the Boards.
            Tools | Board | Board Manager and Searching for AVR. The "Arduino AVT Boards" was at version 1.6.19. which did not work. I downgraded to 1.6.11 and now my GW does not reset and inclusion works.
            Give that a try.
            PDJ
            • B Offline
              B Offline
              BulldogLowell
              @peterjackson said in MySensors plugin : Cannot send command - communications error:
              Arduino AVT Boards
              Thank you, I did exactly as you said and it now works, I can toggle inclusion mode on my controller.
              Must I now use the 1.6.11 Board Manager for all my nodes?
              peterjacksonP 1 Reply Last reply
              • K korttoma
                Hi Jim,
                Br,
                Tomas
                B Offline
                B Offline
                BulldogLowell
                @korttoma
                Hey Tomas! It has been a while. I didn't notice your post at first glance.
                Thanks for the response. As I mentioned above, compiling under the older version Board Manager worked well (and as I mentioned, I had to rewire the device!).
                I'm now on version 1.5 for the Vera plugin, but Arduino IDE is 2.0.0 which was the default when I added it with the Arduino IDE's library manager. Would you recommend another version?
                Switching all of my sketches over to the new library version went well, and I am up and running. I really like the way the latest version is structured. MySensors has come a long way since its genesis. I also like that it is part of the Arduino IDE's Library toolset; very nice @hek .
                It is great to hear from you!
                Jim
                • B BulldogLowell
                  Arduino AVT Boards
                  peterjackson
                  I don't think so. The bug sounds like it is with the Ethernet module somehow. A temp/humidity sensor is working ok and it was compiled with the newer version.
                  • K Offline
                    K Offline
                    korttoma
                    @BulldogLowell
                    Yeah, it has been a while. Glad to see that you are back.
                    Were you able to get your GW working with Vera?
                    Anyhow here are the versions I'm using now.
                    Arduino IDE tool 1.6.11
                    Arduino AVR Boards 1.6.11 (Like already mentioned check this from the Board Manager in Ardiono IDE some newer versions had issues with the Ethernet GW causing it to reboot when sending the inclusion mode command).
                    MySensors Library version 2.1.1 (This is the most recent "stable" version and I recommend using it, I still have some nodes using 2.0.0 and 2.0.1 but the GW needs to be the latest to be able to communicate with both latest and older nodes).
                    The Vera MySensors Plugin version is still 1.5 and have not received any major changes in a loong time.
                    If you get some kind of compilation error please post the error also.
                    Regards,
                    Tomas
                    • Tomas
                    • K korttoma
                      @BulldogLowell
                      Regards,
                      Tomas
                      B Offline
                      B Offline
                      BulldogLowell
                      @korttoma
                      I'm using MySensors 2.0.0, which was the default when I downloaded using the Arduino IDE's library manager. I'll probably linger here a while until i learn all of the MySensors abstractions. It is nice and easy now.
                      I'm using Arduino 1.8.2, which is almost C++ 11. I really like the latest version, I'll just keep using the AVR Boards 1.6.11 for my MySensors projects.
                      @peterjackson set me straight, and all is working well. I'm up and running with all of the MySensors nodes I've built. It is a drag updating some of my devices; many were not built for easy access to the USB serial connectors. I have only myself to blame for that.
                      I'd been working mainly with WiFi devices lately, but they get expensive if all you want is basic functionality, the MySensors backbone is perfect.
                      Built any cool projects lately?
                      12.1k
