  3. TSM:FPAR:No Reply
TSM:FPAR:No Reply
42 Posts 7 Posters 16.1k Views 8 Watching
    wrote on last edited by gohan
    #30
    I probably missed that because I never seen the caps being specified
    If they work, good find
      Tommas
      @gohan
      On ebay, i cant find the bypass capacitor in the specs. I have written to a seller asked about it. I will report to you about the answer.
      I have tried once again the two high power nrf24 pa+lna (I put foil onto these) but these dont work. I think these are broken or very very bad ones.
      Could you suggest to me a seller who sells High power nrf24 which ones you have got good experinces?
      rejoe2R 1 Reply Last reply
      • T Tommas
        @gohan
        rejoe2R
        rejoe2R
        rejoe2
        @Tommas
        The caps are small SMD parts, explicitely mentioned you may find them on ebay here. (This is a 10PIN-Version, but as you see, despite the number of PINs, it's similar to the 8-PIN version you find everywhere.
        But to be honest: I never saw the necessity to make measurements on this topic...
        • rejoe2R rejoe2
          @Tommas
          Tommas
          @rejoe2
          Hi rejoe2!
          What kind of nrf24 do you use, and where did you buy these?
          I think that you use capacitor as well, and stable 3.3V dont you?
          Do you think that this shield is good for my node? It would be very good if i didnt have to use cables for nrf24....
          https://www.itead.cc/wiki/Arduino_Nano_IO_shield
          Best regards
            Get some easy pcb instead or other similar solution 😀
            • T Tommas
              @rejoe2
              Hi rejoe2!
              Best regards
              rejoe2R
              rejoe2R
              rejoe2
              @Tommas
              I use nRF-Modules in the "normal" format and several pa+nla-Variants,. The first ones I probably bought from the ebay source mentionned on the mysensors-site (build-page), but by now, I may have used parts from around 4-5 different ebay-sellers as source. They look different, but until now, I only got "non-blob"-modules which all seemed to work reliably in the end. One time, I really was convinced to have bought fake and bad ones, but in the end it turned out these problems where mainly sw-related.
              For powering, I initially used AMS1117-only-Modules and additional caps, but using the above adaptor-modules made things much easier, as they have all relevant parts on-board (3.3V+caps, space is no problem in my personal use-cases).
              Fyi: As I now prefer wires over rf, I'm about to replace most of my nodes by RS485-variants.
              • rejoe2R rejoe2
                @Tommas
                Tommas
                @rejoe2
                Thanks for the suggestions.
                Had you got problems with nrf24?
                Tomorrow i will try to configure openhab. I have tried to find a quick up to date guide for openhab 2 + mqtt mysensors but font find one.
                Mysensors said that their bindigs support only ethernet or serial gateway officially.
                I dont understand what is the diff (or why mqtt used mostly) the ethernet and mqtt solution but i have started the mqtt already.
                Best regards
                • T Tommas
                  @rejoe2
                  Best regards
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @Tommas
                  I indeed had some troubles with nRF nodes, but related to this.
                  FHEM is used as a controller and two serial GW's, so: no experience with the MQTT stuff.
                  • rejoe2R rejoe2
                    @Tommas
                    Tommas
                    wrote on last edited by Tommas
                    #38
                    @rejoe2
                    I see. I hope, i can use it for a while:).
                    I think im closed this topic. The solution was to change the nrf24 modules, because i could not pair them.
                    The anoother problem was that i use two power source, and i didnt common the GND.
                    Thank you everyone who helped to me!
                    (I run into another problem, if you had some free time:) openhab-mysensors-ethernet-gateway-value-missing
                    • T
                      trasrik
                      wrote on last edited by trasrik
                      #39
                      Reading through your posts: am I right in assuming that these NRF24L01 are rubbish and I should buy some proper ones with a chip instead of a blob?
                      Or has anybody a pair of them up and running?
                      Thanks and best regards,
                      Joachim
                      • T trasrik
                        Joachim
                        Tommas
                        @trasrik
                        I havent had got blob one yet so i havent got experience with it. But i red about the blob version and it should work....
                        But I suggest to you that you should buy these from reliable brand/shop. I think Itead or keyestudio are reliable brands. And i bought a pair nrf24 from ebyte, but it hasnt arrived yet.
                          Yes, those are rubbish. I lost countless hours trying to get them working but without success
                          • N
                            N
                            Newzwaver
                            Ok, spent half the day trying to figure out what I was doing wrong and all I had to do was read the forum. The radios I purchase were junk. Not one of the 10 worked. Had everything placed on a board figured my workmanship was a little off or something. The radio was last to be checked.
                            WOOOOOOWWWWO
                            Thanks Everyone this post saved me a lot more time.
