  3. Vera
  4. MySensors and Vera UI7
22 Posts 11 Posters 18.2k Views 5 Watching
  • clippermiamiC
    clippermiamiC
    clippermiami
    I did set up my Vera Lite with UI7 RC. Frankly I'm underwhelmed.
    For day to day usage I use ImperiHome and I'm very happy with that. I occasionally resort to Authomation but less and less as I improve my ImperiHome configuration. I . Played with UI7 and frankly I think compared to UI5 it's a step backwards for setup and configuring things. For a new user who will use UI7 as their standard window into the system it's probably better this UI5 but to set up devices, configure them, etc I find the constant back and forth movement irritating compared to TABs in the current UI5
    Clearly there are still some major holes in the RC yet, most obviously there doesn't appear to be a way to create multiple instances of an App. I've installed DSC (although haven't configured it to my alarm system yet), PLEG, Virtual Switch, Day and Night, Blue Iris.
    When it becomes production and we all end up having to move I just hope that it installs clean and preserves the configuration, I really don't want to reenter my LEGS, cameras, and what have you :-)
    • C
      C
      chupacabra
      wrote on last edited by chupacabra
      Soooo, anyone mucking around with UI7 yet? I've been trying to get things to work, but having trouble getting new sensors to work properly. The gateway is configured and working correctly. i was adding a simple door sensor to see if it would work and it registers, but the sensor is basically empty, Any pointers (aside form the usual downgrade to UI5)?
      • EDIT -
        The gateway shows up correctly and the first node shows up corectly as well in UI7. Now how do i add the child device for the door sensor?
        @gregl seems to have it working on UI7 using Ethernet gateway. Not sure if serial gateway works though.
        • C
          C
          chupacabra
          well, i guess patience is a virtue i don't possess... i did find an error in my code where i forgot to add the gw.sendSketchInfo() to the gateway, so i fixed that and it finally created the child device. Now testing other sensor types. will try to post updates if there are any issues. thanks for the help!
          • CaptainZapC
            CaptainZapC
            CaptainZap
            @hek : Do you have plans to upgrade the plugin for UI7 use ? I know the guys at MCV are willing to assist any developer with the upgrade :
            http://forum.micasaverde.com/index.php/topic,27645.0.html
              Don't think my family would enjoy the failing home automation which probably would be the result if I upgrade our "production" Vera.
              Would be great if someone who actually is running UI7 would assist with the necessary changes. What is not working for you?
              • greglG
                greglG
                gregl
                Yeah i wouldnt be using UI7 on a production Vera yet.
                That said i dont think there is anything actually broken with the mySensors plugin with it other than some cosmetic issues...
                • AnticimexA
                  AnticimexA
                  Anticimex
                  I am stuck on UI7 (device refuses to downgrade and I have not bothered about contacting support to have them unlock it) and I have so far only experienced HW/FW failures with my gateway (not that Vera is a good product, far from it). But I also cannot point on anything specific with UI7 that is not compatible with MySensors plugin v1.4 apart from said cosmetic details.
                  • C
                    C
                    C.r.a.z.y.
                    New version Vera have 1 USB and 1 ethernet and wifi, it will be on sale in a few weeks with ui7.
                    I dont know why some plugins work with ui5 but not compatiable with ui7.
                    Do you have any plan to make an update for mysensors plugin?
                      I don't run UI7 myself.
                      But others have reported here and on micasa that it works fine in UI7 (part from some GUI alignment).
                      • L
                        L
                        legaultf
                        I just purchased a veraedge and manage to get the usb gateway to be recognized. Unfortunatly I do not know how to get my sensors to be recognized. Inhave tried the discover button followed by a reset of the sensor without succes. I have also tried to create a new device with the dArduino1.xml but can not get this configured with my device.
                        So after reading everything I could find on the topic I am desperate to find a solution with the vera edge or an another controller that could work as stand alone or on a pc.
                        blaceyB 1 Reply Last reply
                        • L legaultf
                          blaceyB
                          blaceyB
                          blacey
                          @legaultf Which UI7 firmware are you running on your VeraEdge?
                          • jeylitesJ
                            jeylitesJ
                            jeylites
                            A trick I learned right after creating devises is to click on " Reload Luup". Then give it a couple of minutes and you should see the created devices on DEVICES on VERA.
                            " Reload Luup". could be access from Apps -> Develop apps -> Serial Port configuration -> Reload Luup
                            • BobCB
                              BobCB
                              BobC
                              I've learnt the same trick. Reload Luup from the serial config screen.
                              After a couple of trials and then finding the UI7 on Github - all's working fine with my first light sensor.
                              Now to building my solar HWS sensors. Thanks Hek for all your work and patience with everyone, a donation is on the way for you to buy a UI7 device. Cheers!
