  3. Where to get legit nRF24L01+ modules?
counterfeitnrf24l01+nrf24l01+pa+lna
85 Posts 9 Posters 35.4k Views 12 Watching
  • Nca78N Nca78
    I received my Ebyte modules, not a warranty of authenticity but the nrf chip has a square instead of a dot like all the fakes I have been using until now. I have a few standard SMD modules and a PA LNA version, I will try to make some basic range tests soon compared to the SMD clones.
    Bogus ExceptionB
    Bogus ExceptionB
    Bogus Exception
    OK! I followed your suggestions and tried itead. These are the pics of what I got 4 of (sorry no pro rig-just a loupe & module in one hand & mouse in the other!
    (all are hosted on one of my servers, not here locally)
    "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
    -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
    -ATTiny, ATMega, STM32
    -Geek Channel: https://www.youtube.com/TheSalesEngineer
    gohanG 1 Reply Last reply
    • Bogus ExceptionB Bogus Exception
      @Bogus-Exception let us know how they perform
      Bogus ExceptionB 1 Reply Last reply
        Bogus ExceptionB
        Bogus ExceptionB
        Bogus Exception
        @gohan I'll do my best to measure meaningful metrics between these & clones. Also, I have 4 eBytes coming (2x blue, 2x red)...
        • Bogus ExceptionB
          Bogus ExceptionB
          Bogus Exception
          wrote on last edited by Bogus Exception
          #48
          So far I've noticed on all versions of the legit nRF24 chips that the 'square' is actually 4 vertical lines, covering a square area, at the 'top left' of the chip.
          Just tried over the past 2 hours to replace the clone in my MyController gateway with either the itead or ebyte legit modules, and neither one of them would communicate with the other nodes. I put the clone back in, and it worked. Weird.
          Not like it matters much, but here is the sketch (all comments removed) using a BME280 and a light sensor module, on a Nano, USB powered:
          #define MY_GATEWAY_SERIAL
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          #include <Adafruit_Sensor.h>
          #include <Adafruit_BME280.h>
          #define BME_SCK 13
          #define BME_MISO 12
          #define BME_MOSI 11
          #define BME_CS 6
          #define SEALEVELPRESSURE_HPA (1013.25)
          const float ALTITUDE = 18;
          Adafruit_BME280 bme(BME_CS); // hardware SPI
          #define LIGHT_CHILD 0
          #define BARO_CHILD 1
          #define TEMP_CHILD 2
          #define HUM_CHILD 3
          boolean metric;
          uint8_t decimals;
          MyMessage lightMsg(LIGHT_CHILD, V_LIGHT_LEVEL); // 0
          MyMessage pressureMsg(BARO_CHILD, V_PRESSURE); // 1
          MyMessage tempMsg(TEMP_CHILD, V_TEMP); // 2
          MyMessage humMsg(HUM_CHILD, V_HUM); // 3
          int lastLightLevel;
          unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
            #ifdef MY_DEBUG
            decimals = 2;
            bool status;
            status = bme.begin();
            if (!status) {
              #ifdef MY_DEBUG
                Serial.println("Could not find a valid BME280 sensor, check wiring!");
              while (1);
            sendSketchInfo("Master Nano", "1.0");
            present(LIGHT_CHILD, S_LIGHT_LEVEL);  // 0
            present(BARO_CHILD, S_BARO);          // 1
            present(TEMP_CHILD, S_TEMP);          // 2
            present(HUM_CHILD, S_HUM);            // 3
            int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              #ifdef MY_DEBUG
                Serial.print(F("Sending lightMsg: "));
                Serial.println(String(lightLevel));
              send(lightMsg.set(lightLevel));
              lastLightLevel = lightLevel;
            float p_Mb = bme.readPressure() / 100.0F;
            float p_Hg = p_Mb / 33.86;
            #ifdef MY_DEBUG
              Serial.print(F("Sending pressureMsg: "));
              Serial.println(String(p_Hg));
            send(pressureMsg.set(p_Hg, decimals));
            float t_C = bme.readTemperature();
            float t_F = (t_C * (9/5)) + 32;
            #ifdef MY_DEBUG
              Serial.print(F("Sending tempMsg: "));
              Serial.println(String(t_F));
            send(tempMsg.set(t_F, decimals));
            float h_Pct = bme.readHumidity();
            #ifdef MY_DEBUG
              Serial.print(F("Sending humMsg: "));
              Serial.println(String(h_Pct));
            send(humMsg.set(h_Pct, decimals));
            #ifdef MY_DEBUG
              Serial.print(F("Sleeping for: "));
              Serial.println(String(SLEEP_TIME));
            sleep(SLEEP_TIME);
          It works with the clone... I am using a regulator board for the nRF24-the one it plugs into & breaks out the 8 pins...
          YveauxY gohanG 2 Replies Last reply
            #define BME_SCK 13
            #define BME_MISO 12
            #define BME_MOSI 11
            #define BME_CS 6
            #define HUM_CHILD 3
            boolean metric;
            uint8_t decimals;
            int lastLightLevel;
              #ifdef MY_DEBUG
              decimals = 2;
              bool status;
              if (!status) {
                #ifdef MY_DEBUG
                while (1);
                #ifdef MY_DEBUG
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
              sleep(SLEEP_TIME);
            @Bogus-Exception said in Where to get legit nRF24L01+ modules?:
            You cannot rely on the print of the nRF to distinguish fake from genuine. Nordic is fabless, so they use different factories to produce their chips, each with its own specific marking.
              #define BME_SCK 13
              #define BME_MISO 12
              #define BME_MOSI 11
              #define BME_CS 6
              #define HUM_CHILD 3
              boolean metric;
              uint8_t decimals;
              int lastLightLevel;
                #ifdef MY_DEBUG
                decimals = 2;
                bool status;
                if (!status) {
                  #ifdef MY_DEBUG
                  while (1);
                  #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                sleep(SLEEP_TIME);
              @Bogus-Exception may I ask why are you using spi for bme280 sensor instead of i2c?
              Bogus ExceptionB 2 Replies Last reply
                Bogus ExceptionB
                Bogus ExceptionB
                Bogus Exception
                @gohan I already have the 3 pins for SPI in use for the nRF, so adding the BME was just one more pin. Simply conserving pins.
                • YveauxY Yveaux
                  Bogus ExceptionB
                  Bogus ExceptionB
                  Bogus Exception
                  @Yveaux Fair enough. I won't rel on that, but did want to mention the observation.
                  On a relatively side note, I got 4 SMD nRF24 cards from eByte, but can't locate any boards to mount them on! The holes are 1.27mm pitch, so I just ordered some 1.27mm headers.
                  Has anyone grabbed a board to surface mount solder them at this pitch?
                  NeverDieN Nca78N 2 Replies Last reply
                    #53
                    What's the pitch on most other SMD nRF24L01+ modules? Is it also 1.27mm, or something else? I hadn't paid attention.
                      Bogus ExceptionB
                      Bogus ExceptionB
                      Bogus Exception
                      @NeverDie Great question. Mine look like these from a post earlier in this thread, and they are the first I've seen that didn't have their (breadboard-unfriendly) pinout.
                        Not sure if it's what you mean, but for prototyping purposes you could solder them to generic 1.27mm proto-board, such as this: https://www.aliexpress.com/item/6-X-8CM-spacing-1-27-universal-board-thickness-1-6mm-sided-HASL-PCB-test-board/32774106087.html?spm=a2g0s.9042311.0.0.eD40xE
                          I think there are adapters to solder the smd version and make them 8 pin compatible or there are generic adapters that can change the pitch
                            You can use NModule, the footprint highlighted in red color in the image below is compatible
                            https://www.openhardware.io/view/364/NModule
                            • Nca78N Nca78
                              Bogus ExceptionB
                              Bogus ExceptionB
                              Bogus Exception
                              @kalina made these DIP-to-SMD-NRF24L01-adapter, but my need isn't enough quantity to buy the chemicals, pay someone to make a rum of them, or convince my wife that, "We'll sell them and make our money back!" :-[
                              • Nca78N Nca78
                                Bogus ExceptionB
                                Bogus ExceptionB
                                Bogus Exception
                                @Nca78 Not just the module (10 for $15, right?), but the page concept is exactly what I am doing these days. Built in flexibility where it matters!
                                You've clearly spent a lot of time at my stage of tinkering with this!
                                Little touches like PA pinout, etc. makes this cake have more icing then cake! :o
                                  #60
                                  @Bogus-Exception
                                  I'm sure the Kalina adapter would be inexpensive if you purchased 3 through OSH PARK because the surface area is small.
                                  • d00616D d00616
                                    I have received two of the red modules. This is an X-Ray image of the chip (montage)
                                    0_1500731806314_upload-666b869a-0a72-4e85-9575-5e96bf143cee
                                    Bogus ExceptionB
                                    Bogus ExceptionB
                                    Bogus Exception
                                    @d00616 I have to ask...
                                    How did you create this image?
                                    d00616D 1 Reply Last reply
                                      d00616D
                                      d00616D
                                      d00616
                                      The image is created with a medical X-Ray machine.
                                        Bogus ExceptionB
                                        Bogus ExceptionB
                                        Bogus Exception
                                        @NeverDie What I meant was, I don't have anything in 1.27mm, so now I've ordered enough stuff to keep my 2.54 and 2.0 company! :)
                                        • d00616D d00616
                                          Bogus ExceptionB
                                          Bogus ExceptionB
                                          Bogus Exception
                                          @d00616 Yeah, but I mean, that image doesn't show detail, does it? I thought it was thermal/IR when I first saw it-like it was running.
                                          First time I've seen this tried. Has it worked for other electronics? Is that image you posted what is usually expected?
                                          And most importantly, how did you talk your dentist/radiologist into doing it?! :)
