  3. Where to get legit nRF24L01+ modules?
counterfeitnrf24l01+nrf24l01+pa+lna
85 Posts 9 Posters 35.4k Views 12 Watching
  • Bogus ExceptionB Bogus Exception
    @Yveaux Fair enough. I won't rel on that, but did want to mention the observation.
    On a relatively side note, I got 4 SMD nRF24 cards from eByte, but can't locate any boards to mount them on! The holes are 1.27mm pitch, so I just ordered some 1.27mm headers.
    Has anyone grabbed a board to surface mount solder them at this pitch?
    @Bogus-Exception said in Where to get legit nRF24L01+ modules?:
    You can use NModule, the footprint highlighted in red color in the image below is compatible
    https://www.openhardware.io/view/364/NModule
    Bogus ExceptionB 1 Reply Last reply
    • Nca78N Nca78
      I received my Ebyte modules, not a warranty of authenticity but the nrf chip has a square instead of a dot like all the fakes I have been using until now. I have a few standard SMD modules and a PA LNA version, I will try to make some basic range tests soon compared to the SMD clones.
      Bogus ExceptionB
      Bogus ExceptionB
      Bogus Exception
      @kalina made these DIP-to-SMD-NRF24L01-adapter, but my need isn't enough quantity to buy the chemicals, pay someone to make a rum of them, or convince my wife that, "We'll sell them and make our money back!" :-[
      "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
      -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
      -ATTiny, ATMega, STM32
      -Geek Channel: https://www.youtube.com/TheSalesEngineer
      • Nca78N Nca78
        Bogus ExceptionB
        Bogus ExceptionB
        Bogus Exception
        @Nca78 Not just the module (10 for $15, right?), but the page concept is exactly what I am doing these days. Built in flexibility where it matters!
        You've clearly spent a lot of time at my stage of tinkering with this!
        Little touches like PA pinout, etc. makes this cake have more icing then cake! :o
          #60
          @Bogus-Exception
          I'm sure the Kalina adapter would be inexpensive if you purchased 3 through OSH PARK because the surface area is small.
          • d00616D d00616
            I have received two of the red modules. This is an X-Ray image of the chip (montage)
            0_1500731806314_upload-666b869a-0a72-4e85-9575-5e96bf143cee
            Bogus ExceptionB
            Bogus ExceptionB
            Bogus Exception
            @d00616 I have to ask...
            How did you create this image?
            d00616D 1 Reply Last reply
              d00616D
              d00616D
              d00616
              The image is created with a medical X-Ray machine.
                Not sure if it's what you mean, but for prototyping purposes you could solder them to generic 1.27mm proto-board, such as this: https://www.aliexpress.com/item/6-X-8CM-spacing-1-27-universal-board-thickness-1-6mm-sided-HASL-PCB-test-board/32774106087.html?spm=a2g0s.9042311.0.0.eD40xE
                Bogus ExceptionB
                Bogus ExceptionB
                Bogus Exception
                @NeverDie What I meant was, I don't have anything in 1.27mm, so now I've ordered enough stuff to keep my 2.54 and 2.0 company! :)
                • d00616D d00616
                  Bogus ExceptionB
                  Bogus ExceptionB
                  Bogus Exception
                  @d00616 Yeah, but I mean, that image doesn't show detail, does it? I thought it was thermal/IR when I first saw it-like it was running.
                  First time I've seen this tried. Has it worked for other electronics? Is that image you posted what is usually expected?
                  And most importantly, how did you talk your dentist/radiologist into doing it?! :)
                    @Bogus-Exception may I ask why are you using spi for bme280 sensor instead of i2c?
                    Bogus ExceptionB
                    Bogus ExceptionB
                    Bogus Exception
                    @gohan Was this wrong? Is there a readon to change?
                    Ya kind of left me hanging there, buddy! :)
                    gohanG 1 Reply Last reply
                      @Bogus-Exception I don't know, I just could not figure out what you were trying to achieve 😀
                      • Bogus ExceptionB
                        Bogus ExceptionB
                        Bogus Exception
                        With the inability to get signal strength from the nRF24, I'm open to any suggestions to fairly evaluate the boards I've collected. Don't think the wife will let me spring for a spectrum analyzer... :(
                          Well usually you could test how good they are by running a sketch that keeps sending data and, while increasing distance, look when you start getting NACKs on the serial monitor.
                            #69
                            Somewhere in the other thread I posted a sketch for automatically counting packet loss percentages. That's the best way that I've been able to think of. Signal strength, bit error rate, and packet loss rate should all be very strongly correlated to one another.
                            • Nca78N Nca78
                              @Nca78 where did you get the ebyte modules? From aliexpress they are charging quite a bit for shipping.
                              Nca78N 1 Reply Last reply
                                @gohan they don't charge me for shipping, but I'm in Vietnam so it's not far for them ;)
                                • d00616D
                                  d00616D
                                  d00616
                                  wrote on last edited by d00616
                                  #72
                                  Some news. After playing with NRF5 and the NRF24 protocol. The red EBYTE modules are fakes.
                                  Over the N of NRF is a dot. I have ordered these modules: https://aliexpress.com/item/Wireless-Module-NRF24L01-original-2-4-Ghz-RF-transceiver-SPI/32712174920.html they have an rectangle over the N and responding line an original NRF24L01. Maybe this helps to identify originals.
                                  The difference between both modules is in NoACK attribute handling. Fakes always responding with ACK and sending inverse NoACK attributes. So fakes have problems communicate with original modules.
                                  EDIT: This was an issue at the NRF5 side.
                                  Nca78N gohanG YveauxY 3 Replies Last reply
                                  • d00616D d00616
                                    wrote on last edited by Nca78
                                    #73
                                    @d00616 said in Where to get legit nRF24L01+ modules?:
                                    You mean you bought those red modules from Ebyte shop and they sent you some with a dot on the chip ?
                                    The ones I received from them (blue SMD ones) have a rectangle, that's in fact made with very close lines.
                                    Is there an "easy"/"not too hard" way to test that ?
                                    • d00616D d00616
                                      @d00616 Are you sure about that?
                                      • Nca78N Nca78
                                        d00616D
                                        d00616D
                                        d00616
                                        #75
                                        @Nca78 said in Where to get legit nRF24L01+ modules?:
                                        Yes. I had ordered the module in the form factor like this posted above.
                                        @gohan said in Where to get legit nRF24L01+ modules?:
                                        Yes, about the ACK/NoACK handling. With the NRF5, I see raw packages. I'm not sure about the dot vs. rectangle, but my modules with a dot violating the protocol.
                                          how did you setup NRF5 "sniffer" ?
                                          BTW, my red modules are working really great; the link you provided from aliexpress are really genuine?
                                          Nca78N d00616D 2 Replies Last reply
