  3. Where to get legit nRF24L01+ modules?
counterfeitnrf24l01+nrf24l01+pa+lna
85 Posts 9 Posters 35.4k Views 12 Watching
    @Bogus-Exception may I ask why are you using spi for bme280 sensor instead of i2c?
    Bogus ExceptionB
    Bogus ExceptionB
    Bogus Exception
    @gohan Was this wrong? Is there a readon to change?
    Ya kind of left me hanging there, buddy! :)
    "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
    -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
    -ATTiny, ATMega, STM32
    -Geek Channel: https://www.youtube.com/TheSalesEngineer
    gohanG 1 Reply Last reply
    • Bogus ExceptionB Bogus Exception
      @Bogus-Exception I don't know, I just could not figure out what you were trying to achieve 😀
      • Bogus ExceptionB
        Bogus ExceptionB
        Bogus Exception
        With the inability to get signal strength from the nRF24, I'm open to any suggestions to fairly evaluate the boards I've collected. Don't think the wife will let me spring for a spectrum analyzer... :(
          Well usually you could test how good they are by running a sketch that keeps sending data and, while increasing distance, look when you start getting NACKs on the serial monitor.
            #69
            @Bogus-Exception said in Where to get legit nRF24L01+ modules?:
            Somewhere in the other thread I posted a sketch for automatically counting packet loss percentages. That's the best way that I've been able to think of. Signal strength, bit error rate, and packet loss rate should all be very strongly correlated to one another.
            • Nca78N Nca78
              I received my Ebyte modules, not a warranty of authenticity but the nrf chip has a square instead of a dot like all the fakes I have been using until now. I have a few standard SMD modules and a PA LNA version, I will try to make some basic range tests soon compared to the SMD clones.
              @Nca78 where did you get the ebyte modules? From aliexpress they are charging quite a bit for shipping.
              Nca78N 1 Reply Last reply
                @gohan they don't charge me for shipping, but I'm in Vietnam so it's not far for them ;)
                • d00616D
                  d00616D
                  d00616
                  wrote on last edited by d00616
                  #72
                  Some news. After playing with NRF5 and the NRF24 protocol. The red EBYTE modules are fakes.
                  Over the N of NRF is a dot. I have ordered these modules: https://aliexpress.com/item/Wireless-Module-NRF24L01-original-2-4-Ghz-RF-transceiver-SPI/32712174920.html they have an rectangle over the N and responding line an original NRF24L01. Maybe this helps to identify originals.
                  The difference between both modules is in NoACK attribute handling. Fakes always responding with ACK and sending inverse NoACK attributes. So fakes have problems communicate with original modules.
                  EDIT: This was an issue at the NRF5 side.
                  Nca78N gohanG YveauxY 3 Replies Last reply
                  • d00616D d00616
                    wrote on last edited by Nca78
                    #73
                    @d00616 said in Where to get legit nRF24L01+ modules?:
                    You mean you bought those red modules from Ebyte shop and they sent you some with a dot on the chip ?
                    The ones I received from them (blue SMD ones) have a rectangle, that's in fact made with very close lines.
                    Is there an "easy"/"not too hard" way to test that ?
                    d00616D 1 Reply Last reply
                    • d00616D d00616
                      @d00616 Are you sure about that?
                      • Nca78N Nca78
                        d00616D
                        d00616D
                        d00616
                        #75
                        @Nca78 said in Where to get legit nRF24L01+ modules?:
                        Yes. I had ordered the module in the form factor like this posted above.
                        @gohan said in Where to get legit nRF24L01+ modules?:
                        Yes, about the ACK/NoACK handling. With the NRF5, I see raw packages. I'm not sure about the dot vs. rectangle, but my modules with a dot violating the protocol.
                          how did you setup NRF5 "sniffer" ?
                          BTW, my red modules are working really great; the link you provided from aliexpress are really genuine?
                          Nca78N d00616D 2 Replies Last reply
                            @gohan do you have rectangles/squares or dots on yours ?
                              I don't remember, I'll have to look tonight
                                d00616D
                                d00616D
                                d00616
                                #79
                                At the moment, I reimplement the protocol for NRF5 chips to fix an NRF5 hardware issue. I don't have a "sniffer".
                                My red modules are good working clones, but they are clones which violating the protocol. Using clones resulting in sending more packages over the air and never receiving an ACK package from original NRF24. So it looks like a duck, but not quacks like a duck over the air.
                                EDIT: Sorry, Cannot identify clones at the moment.
                                  #80
                                  There's no reason to continue using nRF24L01's anyway, except for legacy situations. Their only virtue is cheapness, and the nRF51's offer a good substitute for that.
                                    d00616D
                                    d00616D
                                    d00616
                                    @NeverDie said in Where to get legit nRF24L01+ modules?:
                                    ...when https://github.com/mysensors/MySensors/issues/949 is fixed. If not, a node requires an hard reset from time to time.
                                    • d00616D d00616
                                      Here we go again... Nordic is a fabless company. Therefore the laser marking on their genuine models can be different with each batch. There is no known way to tell if a module is genuine or not from the outside of the module.
                                      • d00616D d00616
                                        First I've heard of this. How often is "from time to time"?
                                          d00616D
                                          d00616D
                                          d00616
                                          <0,1% of packages. I have three versions of the ESB protocol code. With the published version, the module hangs when PAN#102 is triggered. My second version was a try to fix this issue by adding some timer code. With this fix, the NRF5 looses more packages than before. The version I currently working on looks more stable, is easier to debug, supports the fast ramp up mode partially, but it's not complete yet.
