  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • d00616D d00616
    #482
    I'm happy to report this also worked when, just now, I programmed a new Ebyte module. Like d00616 said earlier, it's a much faster way to do a mass erase. :)
    Unfortunately, and in contrast with the nRF52 DK, the new Ebyte module I just programmed is behaving the same as the Ebyte I've been experimenting with. No change.
    • Nca78N
      • d00616D d00616
        You have to install the "MySensors nRF5 Boards" package. In the examples section for this package, you can find two files (MyNRF5Board.h + MyNRF5Board.cpp). Add these files to your sketch and compile it using "MyNRF5Board nRF52822" as you board.
        The registers are documented in the Infocenter and the bitfields.
        To access the registers, you have to add '#include <nrf.h>' to your code. Mostly the hardware is accesses by NRF_HWNAME->REGISTER
        Doing PWM is a little bit complex. The code is different for nRF51 and nRF52. Look into wiring_analog_nRF51.c and (wiring_analog_nRF51.c)[https://github.com/sandeepmistry/arduino-nRF5/blob/c98a190eb34c0247eb8e0764a6367c7f9e51d2fc/cores/nRF5/wiring_analog_nRF52.c#L214]
        If you clone this code, for nRF52 you have to use another timer, like TIMER2, because you can't define the interrupt routine twice.
        Mike_Lemo
        Thanks for the caring replay.
        Nca78N d00616D 2 Replies Last reply
        • M Mike_Lemo
          @Mike_Lemo it is here :
          https://github.com/mysensors/ArduinoHwNRF5
          • M Mike_Lemo
            d00616D
            d00616D
            d00616
            • Nca78N Nca78
              #487
              That would be great! :) Please try the BatteryPoweredSensor sketch when you do. I'm very curious if you will have the same or different result as what I'm getting.
                Mike_Lemo
                • M Mike_Lemo
                  Are you talking about the MyNRF5Board example? Arduino IDE compiles it for me without any complaints.
                    Mike_Lemo
                    @NeverDie When choosing "MyNRF5Board nrf52832"?
                    • M Mike_Lemo
                      Yup.
                        #492
                        At some point, I had to re-arrange the libraries though (don't remember which files or which ones) to get all this stuff working. Before that, it wasn't finding the files. Actually, I think this would be a good topic for discussion, to make sure we're all doing it the same way. If we're doing it differently, it might make cross-checking each others attempts more difficult. Also, maybe there's a better way than the brute-force way that I did it.
                        If anyone has interest, I can post how my libraries are currently structured. If nothing else, it would be a starting point for discussion on what to do (or not to do).
                          Mike_Lemo
                          Dunno that whole arduino BRF52832 programming thing seems too complicated just started to learn how to use the nordic SDK with eclipse until a proper solution is found.
                          NeverDieN d00616D 2 Replies Last reply
                          • M Mike_Lemo
                            #494
                            It hasn't been easy, I'll grant you that. I get the impression d00616 probably does most of his work in Linux, and so some of the disconnect with the Windows IDE probably stems from that. Once we get the basics ironed out, though, I expect things will go more smoothly. In fact, I think we're almost there. A lot of the work for sleeping, measuring source voltage, etc., has already been done, which is far better than starting from scratch. And there's even example code, which helps tremendously.
                              #495
                              Good news! Interestingly enough, the MockMySensors sketch seems to work fine when I load it onto the Ebyte. What a relief! So, I may try hijacking that sketch to convey voltage measurements instead of the BatteryPoweredSensor sketch that mysteriously hasn't been working on my Ebyte modules.
                              • M Mike_Lemo
                                d00616D
                                d00616D
                                d00616
                                The Nordic SDK is more complete than Arduino-nrf5 at the moment, but there is no compatibility with MySensors.
                                The good news, with SDK 13 the 'Nordic Semiconductor ASA' License was changed. The old ASA was the reason for me to rewrite the complete ESB protocol. Now the license is much less restrictive. I think now the way is open to integrate SDK code into arduino-nrf5 or provide SDK based arduino-libraries.
                                I can't change the way of Windows driver handling, but when there are Windows specific issues then they bust be fixed.
                                • d00616D d00616
                                  Mike_Lemo
                                  You mean way more complete every thing is accesable there and there is an example for everything and I didn't use my sensors anyways
                                  d00616D 1 Reply Last reply
                                  • M Mike_Lemo
                                    d00616D
                                    d00616D
                                    d00616
                                    No. I mean if you want to use the Nordic MCU with BLE and you want to access the whole hardware without developing drivers, then the Nordic SDK is an option. For special requirements like tone() you have to develop your own routine for Arduino or SDK.
                                    If you want write code which is compatible with other Vendors or want use MySensors then the SDK isn't the best choice.
                                    The arduino-nrf5 targets to provide the Arduino language. I think this is mostly complete. MySensors brings additional support for enhanced pin output modes and the random number generator (no SoftDevice support here).
                                    Accessing the internal MCU hardware must be added via Arduino libraries. With the new SDK license I think it's possible to put parts of the SDK into libraries supporting Hardware which is not specified in the Arduino reference.
                                    If you want to develop BLE applications with portable code, there are open source implementations like http://mynewt.apache.org/ which are designed to be portable.
                                      #499
                                      Good news! The hwCPUVoltage() function measures the Vcc voltage on the Ebyte module in millivolts. I'm able to send that as a barometer reading using the mocksensors sketch, and it arrives all the way into Domoticz, where it is logged and graphed. So, obviously I need to streamline that a bit, but the proof of concept works. :)
                                        #500
                                        Quantization error on the hwCpuVoltage() function appears to about 14 millivolts, which is a nice little improvement over the atmega328p. Measurement accuracy appears to be well within those bounds.
                                        Next step is to measure voltage on an analog pin using an AnalogRead. Not sure if the reference voltage is Vcc (as it typically is with the atmega328p) or something else for those measurements.
                                        • T
                                          Toyman
                                          Given new Arduino Primo contains a buzzer connected to nrf52, we might expect tone() function to be compatible with nrf52 very soon
                                          https://www.arduino.cc/en/uploads/Main/ARDUINO_PRIMO-V022_SCH.pdf
