  3. nRF5 action!
nRF5 action!
  • M Mike_Lemo
    @NeverDie Dam you why would you make it so wide? can it fit on a single bread board?
    #449
    Sorry, you'll need two.
      mtiutiuM
      mtiutiuM
      mtiutiu
      #450
      • mtiutiuM mtiutiu
        Here: https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-module-Bluetooth-5-program-PCBA-serial-transmission-cost-effective/32818791344.html?spm=a2g0s.9042311.0.0.jWh9gH
        Nca78N 1 Reply Last reply
          @NeverDie I guess you don't need to make a breakout board for those, your spare NModules will do if you use the "PA/LNA" radio footprint ;)
          • Nca78N Nca78
            @Nca78
            Thanks! Good to know.
            • Nca78N
              Just realized it has 2 extra I/O on the side, and the SWD are only pads on top, which makes 8 I/O available, it's much more interesting than the NRF51822 version.
              • Nca78N Nca78
                @Nca78
                Is there even a way to program the nRF51822 version? I'd have to check, but I don't recall the two SWD pins being on its pinout.
                  @Nca78
                  @Nca78
                  They are on the pinout, so you only have 4 I/Os available.
                  • d00616D d00616
                    I tried this function call on an nRF52 DK, and it seems to work. I then tried it on an Ebyte module, treated as an nRF52 DK "board", and it reported zero voltage.
                    d00616D 1 Reply Last reply
                      Mike_Lemo
                      From what I understand the NRF52832 has some kind of enforcer that allows different serial hardwares to be assigned to different pins
                          Mike_Lemo
                          Does anybody know why the function tone() doesn't work for the nrf52?
                          mfalkviddM d00616D 2 Replies Last reply
                          • M Mike_Lemo
                              Mike_Lemo
                              BUZZER_PIN = 26
                              BUZZER_TONE = 3000
                              • M Mike_Lemo
                                BUZZER_PIN = 26
                                BUZZER_TONE = 3000
                                ATmega8
                                ATmega168/328
                                ATmega1280
                                  ATmega8
                                  ATmega168/328
                                  ATmega1280
                                  Mike_Lemo
                                  ATmega8
                                  ATmega168/328
                                  ATmega1280
                                  How is it possible to make it copatible with the NRF52?
                                  • M Mike_Lemo
                                    ATmega8
                                    ATmega168/328
                                    ATmega1280
                                    #465
                                    @Mike_Lemo it (the tone library) would need to be ported
                                      Mike_Lemo
                                      @Mike_Lemo it would need to be ported
                                      No idea what you are talking about.
                                      • M Mike_Lemo
                                          Some further evidence in support of this hypothesis (from: https://github.com/mysensors/ArduinoHwNRF5):
