  3. NRF24 i cant configure raspberry pi1
25 Posts 4 Posters 6.2k Views 4 Watching
  • Rodolfo VieiraR Rodolfo Vieira
    @mfalkvidd
    ok, already actived SPY
    [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv6l.
    [OK] Finished.
    now what the frequency i should in this line:
    --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw
    remember i use nrf24 no rfm69
    @Rodolfo-Vieira none of the rfm parameters are applicable if you use the nrf24 radio.
    • Rodolfo VieiraR
      Rodolfo VieiraR
      Rodolfo Vieira
      @mfalkvidd
      ok thank you so...i make this:
      1 git clone https://github.com/mysensors/MySensors.git --branch master
      cd MySensors
      2 ./configure --my-transport=nrf24
      3 ./configure --my-gateway=ethernet --my-port=5003
      4 ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.1.65
      5 make
      6 sudo ./bin/mysgw -h
      7 sudo ./bin/mysgw -d
      and i receive this:
      pi@hassbian:~/MySensors $ sudo ./bin/mysgw -d
      mysgw: Starting gateway...
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: !TSM:INIT:TSP FAIL
      mysgw: TSM:FAIL:CNT=1
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:FAIL:RE-INIT
      mysgw: TSM:INIT
      mysgw: TSM:FAIL:CNT=2
      mysgw: TSM:FAIL:PDT
      what is the problem?
        @mfalkvidd
        cd MySensors
        5 make
        and i receive this:
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:FAIL:PDT
        mysgw: TSM:INIT
        mysgw: TSM:FAIL:PDT
        @Rodolfo-Vieira everything on a single line :)
        ./configure and then add all the options you want. Then press enter. Then run make.
        But it looks like the radio is not correctly wired. Could you post a photo?
        • Rodolfo VieiraR
          Rodolfo VieiraR
          Rodolfo Vieira
          wrote on last edited by Rodolfo Vieira
          @mfalkvidd lol ok, i am newbie sorry for the stupid acts.
          1 ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.1.65
          2 make
          3 sudo ./bin/mysgw -h
          4 sudo ./bin/mysgw -d
          result:
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:FAIL:PDT
            TSM:INIT:TSP FAIL means the software is unable to communicate with the radio. That is usually due to the radio not being correctly wired. Could you post a photo?
            • Rodolfo VieiraR
              Rodolfo VieiraR
              Rodolfo Vieira
              off course
              https://goo.gl/photos/WB7kkt9A4uxkSwr99
                off course
                @Rodolfo-Vieira thanks. It will take me a while to compare to the wiring guide but I'll report as soon as I have mapped the colors.
                • Rodolfo VieiraR
                  Rodolfo VieiraR
                  Rodolfo Vieira
                  @mfalkvidd ok no problem i waiting
                    @Rodolfo-Vieira on raspberry pi 1, pin 15 is not gnd. Move it to pin 20 or one of the other gnd pins. Stop mysgw (ctrl+c) and start it again after you have switched pins.
                    • Rodolfo VieiraR
                      Rodolfo VieiraR
                      Rodolfo Vieira
                      @mfalkvidd you are correct. I confirm all the wires 5 times.
                      but the error is the same.
                      after that i changed my nrf for two other that i had, and the error is the same.
                      exist any way to confirm if the nrf24 is working fine? may be my nrf are damaged. i dont know.
                      edit: I tried to , connect POWER NRF24 to external power, and connect ground external power to ground raspberry pi.. and the result is the same.
                      TSM:INIT:TSP FAIL
                        TSM:INIT:TSP FAIL
                        @Rodolfo-Vieira do you mean that moving gnd on nrf24 from 19 to 20 on raspberry pi did not help?
                        • Rodolfo VieiraR
                          Rodolfo VieiraR
                          Rodolfo Vieira
                          @mfalkvidd
                          yes i changed gnd As you told me,,,and not work.
                          after that i confirm again all wires...and not work again.... then i connect more two nrf24...make sudo reboot
                          and run sudo ./bin/mysgw -d
                          but the error is the same,,, so a decide help with external source 3.3v
                          i connected wire power nrf24 ---> power external source
                          gnd powersource -------> other gnd raspberry pi
                          sudo reboot again...
                          after sudo ./bin/mysgw -d
                          and the error is the same..... :(
                          • mfalkviddM
                            Sorry, I see now that I probably misinterpreted the photo.
                            Cross-referencing your colors with the official wiring instructions is very tedious.
                            But it looks like the wiring is indeed correct.
                            • mfalkviddM
                              Easiest way to check the nrf is probably to build a node, if you have a spare Arduino.
                              • Rodolfo VieiraR
                                Rodolfo VieiraR
                                Rodolfo Vieira
                                @mfalkvidd
                                may be all my nrf24 are damaged, i have 3.
                                Is there any way to check if they are good?
                                If the connections are well made should work correct?
                                And is an external source even necessary?
                                tomorrow i will test what do you say me now, because now have to go to work.
                                • J
                                  J
                                  Juan González M.
                                  Same problem here.
                                  Rodolfo VieiraR 1 Reply Last reply
                                  • J Juan González M.
                                    Same problem here.
                                    Rodolfo VieiraR
                                    Rodolfo VieiraR
                                    Rodolfo Vieira
                                    @Juan-González-M. said in NRF24 i cant configure raspberry pi1:
                                    Same problem here.
                                    If you solve the problem please tell me.
                                    • H
                                      H
                                      HenkeP
                                      hi,
                                      I just did this setup last week and also had similar problems. I did run make without any options added. NRF24 is allready enabled by default.
                                      One thing I did was to enable SPI and then I think it worked better. There's options in "sudo raspi-config" (advanced menu) to enable I2C and SPI, could that be the issue?
                                      //Henrik
