  3. NRF24 i cant configure raspberry pi1
25 Posts 4 Posters 6.2k Views 4 Watching
  • Rodolfo VieiraR
    Rodolfo VieiraR
    Rodolfo Vieira
    @Rodolfo-Vieira said in NRF24 i cant configure raspberry pi1:
    [WARNING] No supported SPI driver detected
    @mfalkvidd ahhhh ok :) sorry, now i can solve this problem:
    • Rodolfo VieiraR Rodolfo Vieira
      @Rodolfo-Vieira that is just a warning. What does it say after?
      • Rodolfo VieiraR
        Rodolfo VieiraR
        Rodolfo Vieira
        wrote on last edited by Rodolfo Vieira
        @mfalkvidd
        ok, already actived SPY
        [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv6l.
        [OK] Finished.
        now what the frequency i should in this line:
        --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw
        remember i use nrf24 no rfm69
          @mfalkvidd
          [OK] Finished.
          @Rodolfo-Vieira none of the rfm parameters are applicable if you use the nrf24 radio.
          • Rodolfo VieiraR
            Rodolfo VieiraR
            Rodolfo Vieira
            @mfalkvidd
            ok thank you so...i make this:
            1 git clone https://github.com/mysensors/MySensors.git --branch master
            cd MySensors
            2 ./configure --my-transport=nrf24
            3 ./configure --my-gateway=ethernet --my-port=5003
            4 ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.1.65
            5 make
            6 sudo ./bin/mysgw -h
            7 sudo ./bin/mysgw -d
            and i receive this:
            pi@hassbian:~/MySensors $ sudo ./bin/mysgw -d
            mysgw: Starting gateway...
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: !TSM:INIT:TSP FAIL
            mysgw: TSM:FAIL:CNT=1
            mysgw: TSM:FAIL:PDT
            mysgw: TSM:FAIL:RE-INIT
            mysgw: TSM:INIT
            mysgw: TSM:FAIL:CNT=2
            mysgw: TSM:FAIL:PDT
            what is the problem?
              @mfalkvidd
              cd MySensors
              5 make
              and i receive this:
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:FAIL:PDT
              mysgw: TSM:INIT
              mysgw: TSM:FAIL:PDT
              @Rodolfo-Vieira everything on a single line :)
              ./configure and then add all the options you want. Then press enter. Then run make.
              But it looks like the radio is not correctly wired. Could you post a photo?
              • Rodolfo VieiraR
                Rodolfo VieiraR
                Rodolfo Vieira
                @mfalkvidd lol ok, i am newbie sorry for the stupid acts.
                1 ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.1.65
                2 make
                3 sudo ./bin/mysgw -h
                4 sudo ./bin/mysgw -d
                result:
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:FAIL:PDT
                  TSM:INIT:TSP FAIL means the software is unable to communicate with the radio. That is usually due to the radio not being correctly wired. Could you post a photo?
                  • Rodolfo VieiraR
                    Rodolfo VieiraR
                    Rodolfo Vieira
                    off course
                    https://goo.gl/photos/WB7kkt9A4uxkSwr99
                      off course
                      @Rodolfo-Vieira thanks. It will take me a while to compare to the wiring guide but I'll report as soon as I have mapped the colors.
                      • Rodolfo VieiraR
                        Rodolfo VieiraR
                        Rodolfo Vieira
                        @mfalkvidd ok no problem i waiting
                          @Rodolfo-Vieira on raspberry pi 1, pin 15 is not gnd. Move it to pin 20 or one of the other gnd pins. Stop mysgw (ctrl+c) and start it again after you have switched pins.
                          • Rodolfo VieiraR
                            Rodolfo VieiraR
                            Rodolfo Vieira
                            @mfalkvidd you are correct. I confirm all the wires 5 times.
                            but the error is the same.
                            after that i changed my nrf for two other that i had, and the error is the same.
                            exist any way to confirm if the nrf24 is working fine? may be my nrf are damaged. i dont know.
                            edit: I tried to , connect POWER NRF24 to external power, and connect ground external power to ground raspberry pi.. and the result is the same.
                            TSM:INIT:TSP FAIL
                              TSM:INIT:TSP FAIL
                              @Rodolfo-Vieira do you mean that moving gnd on nrf24 from 19 to 20 on raspberry pi did not help?
                              • Rodolfo VieiraR
                                Rodolfo VieiraR
                                Rodolfo Vieira
                                @mfalkvidd
                                yes i changed gnd As you told me,,,and not work.
                                after that i confirm again all wires...and not work again.... then i connect more two nrf24...make sudo reboot
                                and run sudo ./bin/mysgw -d
                                but the error is the same,,, so a decide help with external source 3.3v
                                i connected wire power nrf24 ---> power external source
                                gnd powersource -------> other gnd raspberry pi
                                sudo reboot again...
                                after sudo ./bin/mysgw -d
                                and the error is the same..... :(
                                • mfalkviddM
                                  Sorry, I see now that I probably misinterpreted the photo.
                                  Cross-referencing your colors with the official wiring instructions is very tedious.
                                  But it looks like the wiring is indeed correct.
                                  • mfalkviddM
                                    Easiest way to check the nrf is probably to build a node, if you have a spare Arduino.
                                    • Rodolfo VieiraR
                                      Rodolfo VieiraR
                                      Rodolfo Vieira
                                      @mfalkvidd
                                      may be all my nrf24 are damaged, i have 3.
                                      Is there any way to check if they are good?
                                      If the connections are well made should work correct?
                                      And is an external source even necessary?
                                      tomorrow i will test what do you say me now, because now have to go to work.
                                      • J
                                        J
                                        Juan González M.
                                        Same problem here.
                                        Rodolfo VieiraR 1 Reply Last reply
                                        • J Juan González M.
                                          Same problem here.
                                          Rodolfo VieiraR
                                          Rodolfo VieiraR
                                          Rodolfo Vieira
                                          @Juan-González-M. said in NRF24 i cant configure raspberry pi1:
                                          Same problem here.
                                          If you solve the problem please tell me.
