  3. NRF24 i cant configure raspberry pi1
25 Posts 4 Posters 6.0k Views 4 Watching
  • Rodolfo VieiraR Rodolfo Vieira
    off course
    https://goo.gl/photos/WB7kkt9A4uxkSwr99
    @Rodolfo-Vieira thanks. It will take me a while to compare to the wiring guide but I'll report as soon as I have mapped the colors.
    • Rodolfo VieiraR
      Rodolfo VieiraR
      Rodolfo Vieira
      @mfalkvidd ok no problem i waiting
        @Rodolfo-Vieira on raspberry pi 1, pin 15 is not gnd. Move it to pin 20 or one of the other gnd pins. Stop mysgw (ctrl+c) and start it again after you have switched pins.
        • Rodolfo VieiraR
          Rodolfo VieiraR
          Rodolfo Vieira
          wrote on last edited by Rodolfo Vieira
          @mfalkvidd you are correct. I confirm all the wires 5 times.
          but the error is the same.
          after that i changed my nrf for two other that i had, and the error is the same.
          exist any way to confirm if the nrf24 is working fine? may be my nrf are damaged. i dont know.
          edit: I tried to , connect POWER NRF24 to external power, and connect ground external power to ground raspberry pi.. and the result is the same.
          TSM:INIT:TSP FAIL
            TSM:INIT:TSP FAIL
            @Rodolfo-Vieira do you mean that moving gnd on nrf24 from 19 to 20 on raspberry pi did not help?
            • Rodolfo VieiraR
              Rodolfo VieiraR
              Rodolfo Vieira
              @mfalkvidd
              yes i changed gnd As you told me,,,and not work.
              after that i confirm again all wires...and not work again.... then i connect more two nrf24...make sudo reboot
              and run sudo ./bin/mysgw -d
              but the error is the same,,, so a decide help with external source 3.3v
              i connected wire power nrf24 ---> power external source
              gnd powersource -------> other gnd raspberry pi
              sudo reboot again...
              after sudo ./bin/mysgw -d
              and the error is the same..... :(
              • mfalkviddM
                Sorry, I see now that I probably misinterpreted the photo.
                Cross-referencing your colors with the official wiring instructions is very tedious.
                But it looks like the wiring is indeed correct.
                • mfalkviddM
                  Easiest way to check the nrf is probably to build a node, if you have a spare Arduino.
                  • Rodolfo VieiraR
                    Rodolfo VieiraR
                    Rodolfo Vieira
                    @mfalkvidd
                    may be all my nrf24 are damaged, i have 3.
                    Is there any way to check if they are good?
                    If the connections are well made should work correct?
                    And is an external source even necessary?
                    tomorrow i will test what do you say me now, because now have to go to work.
                    • J
                      J
                      Juan González M.
                      Same problem here.
                      Rodolfo VieiraR 1 Reply Last reply
                      • J Juan González M.
                        Same problem here.
                        Rodolfo VieiraR
                        Rodolfo VieiraR
                        Rodolfo Vieira
                        @Juan-González-M. said in NRF24 i cant configure raspberry pi1:
                        Same problem here.
                        If you solve the problem please tell me.
                        • H
                          H
                          HenkeP
                          hi,
                          I just did this setup last week and also had similar problems. I did run make without any options added. NRF24 is allready enabled by default.
                          One thing I did was to enable SPI and then I think it worked better. There's options in "sudo raspi-config" (advanced menu) to enable I2C and SPI, could that be the issue?
                          //Henrik
