NRF24 i cant configure raspberry pi1
@Rodolfo-Vieira everything on a single line :)
./configure and then add all the options you want. Then press enter. Then run make.But it looks like the radio is not correctly wired. Could you post a photo?
off course
@mfalkvidd ok no problem i waiting
@mfalkvidd you are correct. I confirm all the wires 5 times.
but the error is the same.after that i changed my nrf for two other that i had, and the error is the same.
exist any way to confirm if the nrf24 is working fine? may be my nrf are damaged. i dont know.
edit: I tried to , connect POWER NRF24 to external power, and connect ground external power to ground raspberry pi.. and the result is the same.
TSM:INIT:TSP FAIL
TSM:INIT:TSP FAIL
@mfalkvidd
yes i changed gnd As you told me,,,and not work.
after that i confirm again all wires...and not work again.... then i connect more two nrf24...make sudo reboot
and run sudo ./bin/mysgw -dbut the error is the same,,, so a decide help with external source 3.3v
i connected wire power nrf24 ---> power external source
gnd powersource -------> other gnd raspberry pisudo reboot again...
after sudo ./bin/mysgw -dand the error is the same..... :(
@mfalkvidd
may be all my nrf24 are damaged, i have 3.Is there any way to check if they are good?
If the connections are well made should work correct?And is an external source even necessary?
tomorrow i will test what do you say me now, because now have to go to work.
Same problem here.
Same problem here.
@Juan-González-M. said in NRF24 i cant configure raspberry pi1:
Same problem here.
If you solve the problem please tell me.
hi,
I just did this setup last week and also had similar problems. I did run make without any options added. NRF24 is allready enabled by default.
One thing I did was to enable SPI and then I think it worked better. There's options in "sudo raspi-config" (advanced menu) to enable I2C and SPI, could that be the issue?
//Henrik
