  3. nRF5 action!
nRF5 action!
    The only problem is i can not unplug it from the Ble400 because i have no way of connecting wires to the core board because of the smaller pitch pins.
    For the current measurement, just program it with the above sketch on your Waveshare, then unplug your module from the BLE400 board and power it using a GND dupont wire and a Vcc dupont wire connected through your uCurrent Gold, or whatever it is that you're using to measure current. I should think that would work, wouldn't it?
    Or do you only have the main board without the smaller plug-in module?
    It actually looks like a nice setup.
    rmtuckerR
    rmtuckerR
    rmtucker
    When you unplug the little board it only has 1.27mm spaced pins and they are not standard dupont size so shy soldering to them which would mean i could not plug it back in to the BLE.
    Anyway i am only using a crappy multimeter and with it plugged in and running your sketch i am getting 140uA but i will find a way of unplugging it so hang fire.
    Nca78N 1 Reply Last reply
    • rmtuckerR rmtucker
      @rmtucker you could try to just solder 2 tiny wires on top of the board for vcc and gnd pins so you don't mess with the connectors for plugin it back on the main board ?
      • Nca78N Nca78
        #527
        @Nca78
        Agreed. It sounds as though the bigger problem is going to be his crappy multimeter, if that's all he has. Maybe a good time for an upgrade?
          rmtuckerR
          rmtuckerR
          rmtucker
          Ok with my crappy multimeter i am getting 4-5uA with just Vcc and Ground connected.
            #529
            I'll try removing the 32.768Khz crystal from an infor-link module and then re-run the sketch that relies on an external interrupt to wake from sleep. Maybe that will get us closer to the theoretical minimum current of just the nRF52832 chip by itself.
              rmtuckerR
              rmtuckerR
              rmtucker
              Just a little thought on this and a bit of googling.
              Just the system on consumption is 1-2uA without the rtc that is needed for wakeup so i don,t think the figures we are getting are that far away from the spec sheet?
                Agreed. We're in the ballpark.
                rmtuckerR 1 Reply Last reply
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  400,000 hours on 2xAA if we let it sleep.:smile:
                  That will do for me!.
                  Now a little playtime and maybe some range testing.
                    Yeah, I guess I won't amputate the xtal just yet. It can run for quite a while at 6ua. :)
                      So, just did the experiment, and here are the results. Supplying 3.3v to the Ebyte Module, a voltage of 3.0 volts on A4 yields an analogRead(A4) of 4095. Less voltage on A4 yields a lower number.
                      So, generalizing, I suspect that the reference voltage for analogRead() is Vcc-0.3.
                      So, you either know Vcc, because of a voltage regulator or something, or else you must call hwCpuVoltage() to get what it is. Then, subtract 0.3v from that, and that's the reference voltage which corresponds to an analogRead() return value of 4095.
                      d00616D
                      d00616D
                      d00616
                      The internal reference is 0.6V the nRF5 MCU's have an internal programmable divider. With Arduino this divider is programmed to 1/5. If you switch to the external reference the "gain" is 1/4.
                      I measure with my CDEByte 11-15µA for sleep without interrupt waiting. With a RedBear BLE Nano 2 I have measured 15µA. Both compiled as BLE Nano 2. I have used the VC165 multimeter.
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        I2c is not working properly either.
                        Here is a test on a HTU21D sensor.
                        HTU21D-F test
                        Temp: -46.57		Hum: 84.10
                        Temp: 81.10		Hum: 59.68
                        Temp: 81.10		Hum: 26.48
                        Temp: -2.64		Hum: 26.48
                        Temp: 51.58		Hum: 26.48
                        Temp: 4.91		Hum: 25.02
                        Temp: 33.74		Hum: 25.02
                        Temp: 93.45		Hum: 25.02
                        Temp: 4.22		Hum: 26.48
                        Temp: 95.51		Hum: 116.81
                        Temp: -39.02		Hum: 116.81
                        Temp: 94.14		Hum: 25.02
                        Temp: 94.14		Hum: 116.81
                        Temp: 120.22		Hum: 116.81
                        Temp: -8.82		Hum: 111.44
                        Temp: 120.22		Hum: 19.64
                        Temp: 94.14		Hum: 111.44
                        Temp: -8.82		Hum: 116.81
                        Temp: 120.22		Hum: 111.44
                        Temp: -8.82		Hum: 19.64
                        Temp: 33.05		Hum: 111.44
                        Temp: 94.14		Hum: 19.64
                        Temp: 4.22		Hum: 19.64
                        Temp: 2.84		Hum: 111.44
                        Temp: 3.53		Hum: 111.44
                        Temp: -10.20		Hum: 19.64
                          #536
                          Seems like there's more than one library named "Wire" that's floating around at the same time. I wonder if perhaps the compiler is finding the proper Wire library inside Arduino-nRF5? Or maybe it's linking with an unrelated Wire library? To answer that, you could try inserting a Serial.println() into the proper library and see if it fires off when you run your code.
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            Yes checked that and it is using the correct wire.h.
                              #538
                              @rmtucker
                              Is there a mysensors demo sketch that involves i2c? I could try it on my end, though I expect I'd probably get the same as you.
                              d00616D 1 Reply Last reply
                                I see that Amazon is selling the Arduino Primo now: https://www.amazon.com/Arduino-A000138-low-power-coin-sized-wearables/dp/B073JN7XXR/ref=sr_1_12?ie=UTF8&qid=1501982634&sr=8-12&keywords=nrf52832
                                First time I've seen it for sale anywhere.
                                  Toyman
                                  wrote on last edited by Toyman
                                  #540
                                  @NeverDie they also has started to sell "big" Primo
                                  • T Toyman
                                    Yeah, the big version has Wi-Fi, so I suspect it's meant to function much like a wireless serial gateway.
                                    For the convenience of other readers here, here's a link:
                                    https://www.amazon.com/Arduino-A000135-featuring-Nordic-processor/dp/B0721P6STJ/ref=sr_1_1?ie=UTF8&qid=1502011422&sr=8-1&keywords=arduino+primo
                                      Maybe you can get much of the same benefits--but at a lower cost--by combining an nRF5 with an ESP8266. Example:
                                        #543
                                        This is strange: now when I do the timed sleep on the infor-link module, it shows a current drain of about 60ua, whereas yesterday it was around 6ua. Maybe I somehow damaged it by connecting a couple of the input pins (A2 and A4) to Vcc? I wouldn't think so, though, because the datasheet says it should be safe to Vcc + 0.3v.
                                        I have one unused infor-link module left. I'll try wiring it up, but without the input pins this time, and measure it. I'm wondering now whether the sleep current will measure out to be 60ua, or 6ua.
                                          @rmtucker
                                          d00616D
                                          d00616D
                                          d00616
                                          I have used I2C with an display and u8g2 without any problem.
                                          With the nRF51 there is an bug, after using the debug interface the current consumption is higher until reset.
