  3. nRF5 action!
nRF5 action!
  • rmtuckerR rmtucker
    Try
    #518
    Try
    Unexpected result: using that as the sleep invocation, the infor-link module measures at 14ua while sleeping. i.e. worse, not better, compared to the 6ua measured earlier.
      #519
      Looks as though the infor-link is using an A620N crystal:
      I tried to see if I could find a datasheet for it, in the hope of learning what its current consumption is (or, at least, should be). Unfortunately, though, I couldn't find a datasheet for an A620N.
        #520
        Maybe it doesn't matter, because in looking at the actual module I received, it appears to use a different XTAL anyway: A649N.
        rmtuckerR 1 Reply Last reply
          #521
          Maybe from a current consumption standpoint, not using an external XTAL crystal, but rather relying on the nRF52832's internal resonator would draw less current? I know that's true for the atmega328p. If so, then that's a trade-off worth examining more carefully.
            rmtuckerR
            rmtuckerR
            rmtucker
            Sorry i have been a little distracted because my waveshare BLE400 and jlink just turned up.
            Took a little time to get it running but i loaded up the mockmysensors sketch with all the sensors un commented and pow all 30 odd sensors showed up in domoticz which made me chuckle.
            Anyway post your sketch for the consumption testing and i will put it in and see if it works on my board.
            The only problem is i can not unplug it from the Ble400 because i have no way of connecting wires to the core board because of the smaller pitch pins.
              @rmtucker
              Here's the sketch I tested with:
              * MockMySensors
              //#define MY_RADIO_NRF24
              #define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #define MY_NODE_ID 254
              // Wait times
              #define LONG_WAIT 500
              #define SHORT_WAIT 50
              #define SKETCH_VERSION "v0.5"
              // Define Sensors ids
              	S_SCENE_CONTROLLER
              // one at a time.
              //#define ID_S_TEMP              7
              //// Lib 1.5 sensors
              //#define ID_S_SPRINKLER         29
              // Global Vars
              unsigned long SLEEP_TIME = 3600000; // Sleep time between reads (in milliseconds)
              bool metric = true;
              long randNumber;
              #ifdef ID_S_ARMED
              bool isArmed;
              #ifdef ID_S_LIGHT
              bool isLightOn=0;
              #ifdef ID_S_DIMMER
              int dimmerVal=100;
              #ifdef ID_S_COVER
              #ifdef ID_S_TEMP
              #ifdef ID_S_HUM
              #ifdef ID_S_BARO
              //MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
              #ifdef ID_S_WIND
              #ifdef ID_S_RAIN
              #ifdef ID_S_UV
              #ifdef ID_S_WEIGHT
              #ifdef ID_S_POWER
              #ifdef ID_S_HEATER
              float heater_setpoint=21.5;
              //  float heater_temp=23.5;
              //  bool heater_status=false;
              #ifdef ID_S_DISTANCE
              #ifdef ID_S_LIGHT_LEVEL
              #ifdef ID_S_LOCK
              bool isLocked = 0;
              #ifdef ID_S_IR
              long irVal = 0;
              #ifdef ID_S_WATER
              #ifdef ID_S_AIR_QUALITY
              #ifdef ID_S_DUST
              #ifdef ID_S_SCENE_CONTROLLER
              char *scenes[] = {
              	(char *)"Good Morning",
              	(char *)"Clean Up!",
              	(char *)"All Lights Off",
              	(char *)"Music On/Off"
              int sceneVal=0;
              int sceneValPrevious=0;
              #ifdef ID_S_RGB_LIGHT
              String rgbState="000000";
              //RGB light V_RGB, V_WATT
              #ifdef ID_S_RGBW_LIGHT
              String rgbwState="00000000";
              #ifdef ID_S_COLOR_SENSOR
              //Color sensor	V_RGB
              #ifdef ID_S_HVAC
              //Thermostat/HVAC device
              // NOT IMPLEMENTED YET
              #ifdef ID_S_MULTIMETER
              // V_VOLTAGE	38	Voltage level
              // V_CURRENT	39	Current level
              #ifdef ID_S_SPRINKLER
              #ifdef ID_S_WATER_LEAK
              #ifdef ID_S_SOUND
              #ifdef ID_S_VIBRATION
              #ifdef ID_S_MOISTURE
              #ifdef ID_S_CUSTOM
              	// Random SEED
              	randomSeed(analogRead(0));
              	wait(LONG_WAIT);
              	Serial.println("GW Started");
              	Serial.print(SKETCH_NAME);
              	wait(LONG_WAIT);
              	Serial.print("Get Config: ");
              	wait(LONG_WAIT);
              	// Init Armed
              #ifdef ID_S_ARMED
              	isArmed = true;
              #ifdef ID_S_DOOR
              	Serial.println("  S_DOOR");
              	wait(SHORT_WAIT);
              #ifdef ID_S_MOTION
              	Serial.println("  S_MOTION");
              	wait(SHORT_WAIT);
              #ifdef ID_S_SMOKE
              	Serial.println("  S_SMOKE");
              	wait(SHORT_WAIT);
              #ifdef ID_S_LIGHT
              	Serial.println("  S_LIGHT");
              	wait(SHORT_WAIT);
              #ifdef ID_S_DIMMER
              	Serial.println("  S_DIMMER");
              	wait(SHORT_WAIT);
              #ifdef ID_S_COVER
              	Serial.println("  S_COVER");
              	wait(SHORT_WAIT);
              #ifdef ID_S_TEMP
              	Serial.println("  S_TEMP");
              	wait(SHORT_WAIT);
              #ifdef ID_S_HUM
              	Serial.println("  S_HUM");
              	wait(SHORT_WAIT);
              #ifdef ID_S_BARO
              	Serial.println("  S_BARO");
              	present(ID_S_BARO,S_BARO," Voltage");
              	wait(SHORT_WAIT);
              #ifdef ID_S_WIND
              	Serial.println("  S_WIND");
              	wait(SHORT_WAIT);
              #ifdef ID_S_RAIN
              	Serial.println("  S_RAIN");
              	wait(SHORT_WAIT);
              #ifdef ID_S_UV
              	Serial.println("  S_UV");
              	wait(SHORT_WAIT);
              #ifdef ID_S_WEIGHT
              	Serial.println("  S_WEIGHT");
              	wait(SHORT_WAIT);
              #ifdef ID_S_POWER
              	Serial.println("  S_POWER");
              	wait(SHORT_WAIT);
              #ifdef ID_S_HEATER
              	Serial.println("  S_HEATER");
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              #ifdef ID_S_LOCK
              	Serial.println("  S_LOCK");
              	wait(SHORT_WAIT);
              #ifdef ID_S_IR
              	Serial.println("  S_IR");
              	wait(SHORT_WAIT);
              #ifdef ID_S_WATER
              	Serial.println("  S_WATER");
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              #ifdef ID_S_DUST
              	Serial.println("  S_DUST");
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              #ifdef ID_S_HVAC
              	Serial.println("  HVAC");
              	wait(SHORT_WAIT);
              	wait(SHORT_WAIT);
              #ifdef ID_S_SOUND
              	wait(SHORT_WAIT);
              #ifdef ID_S_CUSTOM
              	Serial.println("  S_CUSTOM");
              	wait(SHORT_WAIT);
              	Serial.println("");
              	Serial.println("");
              	Serial.println("");
              	randNumber=random(0,101);
              	Serial.println(randNumber);
              	// Send fake battery level
              	sendBatteryLevel(randNumber);
              	wait(LONG_WAIT);
              	// Request time
              	requestTime();
              	wait(LONG_WAIT);
              	//Read Sensors
              #ifdef ID_S_DOOR
              	door();
              #ifdef ID_S_MOTION
              	motion();
              #ifdef ID_S_SMOKE
              	smoke();
              #ifdef ID_S_LIGHT
              	light();
              #ifdef ID_S_DIMMER
              	dimmer();
              #ifdef ID_S_COVER
              	cover();
              #ifdef ID_S_TEMP
              	temp();
              #ifdef ID_S_HUM
              	hum();
              #ifdef ID_S_BARO
              	baro();
              #ifdef ID_S_WIND
              	wind();
              #ifdef ID_S_RAIN
              	rain();
              #ifdef ID_S_UV
              	uv();
              #ifdef ID_S_WEIGHT
              	weight();
              #ifdef ID_S_POWER
              	power();
              #ifdef ID_S_HEATER
              	heater();
              	distance();
              	light_level();
              #ifdef ID_S_LOCK
              	lock();
              #ifdef ID_S_IR
              	ir();
              #ifdef ID_S_WATER
              	water();
              	air();
              #ifdef ID_S_DUST
              	dust();
              	scene();
              	rgbLight();
              	rgbwLight();
              	color();
              #ifdef ID_S_HVAC
              	hvac();
              	multimeter();
              #ifdef ID_S_SOUND
              	moisture();
              #ifdef ID_S_CUSTOM
              	custom();
              	wait(SHORT_WAIT);
              	//wait(SLEEP_TIME); //sleep a bit
                //sleep(60000); // Sleeps for a minute in deep sleep
                //sleep(6000000); // Sleeps for 100 minutes in deep sleep
              //void door(){}
              #ifdef ID_S_DOOR
              void door()
              	Serial.print("Door is: " );
              	if (randNumber <= 50) {
              		Serial.println("Open");
              		Serial.println("Closed");
              #ifdef ID_S_ARMED
              	Serial.print("System is: " );
              #ifdef ID_S_MOTION
              void motion()
              	Serial.print("Motion is: " );
              		Serial.println("Active");
              		send(msg_S_MOTION_T.set(1));
              		Serial.println("Quiet");
              		send(msg_S_MOTION_T.set(0));
              #ifdef ID_S_ARMED
              #ifdef ID_S_SMOKE
              void smoke()
              	Serial.print("Smoke is: " );
              		send(msg_S_SMOKE_T.set(1));
              		send(msg_S_SMOKE_T.set(0));
              #ifdef ID_S_ARMED
              #ifdef ID_S_LIGHT
              void light()
              	Serial.print("Light is: " );
              #ifdef ID_S_DIMMER
              void dimmer()
              	Serial.println(dimmerVal);
              #ifdef ID_S_COVER
              void cover()
              	Serial.print("Cover is : " );
              	if (coverState == 1) {
              		Serial.println("Opening");
              		send(msg_S_COVER_U.set(1));
              		Serial.println("Closing");
              		send(msg_S_COVER_D.set(0));
              		Serial.println("Idle");
              		send(msg_S_COVER_S.set(-1));
              #ifdef ID_S_TEMP
              void temp()
              #ifdef ID_S_HUM
              void hum()
              #ifdef ID_S_BARO
              void baro()
              	//long pressure = map(randNumber,1,100,870,1086);// hPa?
              	//int forecast = map(randNumber,1,100,0,5);
                 long voltage =  hwCPUVoltage();
              	Serial.print("Power source voltage is: " );
              	Serial.println(voltage);
              	send(msg_S_BARO_P.set(voltage));
              	//Serial.print("Weather forecast: " );
              	//send(msg_S_BARO_F.set(weather[forecast]));
              #ifdef ID_S_WIND
              void wind()
              #ifdef ID_S_RAIN
              void rain()
              #ifdef ID_S_UV
              void uv()
              #ifdef ID_S_WEIGHT
              void weight()
              	Serial.print("Weight is: " );
              #ifdef ID_S_POWER
              void power()
              	Serial.print("Watt is: " );
              	Serial.print("KWH is: " );
              #ifdef ID_S_HEATER
              void heater()
              	//  String heatState="Off";
              void distance()
              void light_level()
              #ifdef ID_S_LOCK
              void lock()
              	Serial.print("Lock is: " );
              #ifdef ID_S_IR
              void ir()
              	Serial.println(irVal);
              	send(msg_S_IR_S.set(irVal));
              	send(msg_S_IR_R.set(irVal));
              #ifdef ID_S_WATER
              void water()
              void air()
              #ifdef ID_S_DUST
              void dust()
              void scene()
              	Serial.print("Scene is: " );
              		sceneValPrevious=sceneVal;
              void rgbLight()
              	Serial.println(rgbState);
              void rgbwLight()
              	Serial.println(rgbwState);
              void color()
              	String colorState;
              	Serial.println(colorState);
              #ifdef ID_S_HVAC
              void hvac()
              	Serial.println(hvac_Speed);
              void multimeter()
              	Serial.println(impedance);
              	Serial.println(volt);
              	Serial.println(amps);
              #ifdef ID_S_SOUND
              void moisture()
              #ifdef ID_S_CUSTOM
              void custom()
              	switch (message.type) {
              #ifdef ID_S_ARMED
              	case V_ARMED:
              		isArmed = message.getBool();
              #ifdef ID_S_DOOR
              		door();//temp ack for door
              #ifdef ID_S_MOTION
              		motion();//temp ack
              #ifdef ID_S_SMOKE
              		smoke();//temp ack
              	case V_STATUS: // V_LIGHT:
              #ifdef ID_S_LIGHT
              			light(); // temp ack
              		//    #ifdef ID_S_HEATER
              		//    #endif
              #ifdef ID_S_DIMMER
              	case V_DIMMER:
              		dimmerVal= message.getInt();
              		dimmer();// temp ack
              #ifdef ID_S_COVER
              	case V_UP:
              		coverState=1;
              		Serial.println("V_UP");
              		cover(); // temp ack
              	case V_DOWN:
              		coverState=-1;
              		Serial.println("V_DOWN");
              		cover(); //temp ack
              	case V_STOP:
              		coverState=0;
              		Serial.println("V_STOP");
              		cover(); //temp ack
              	case V_HVAC_SETPOINT_HEAT:
              #ifdef ID_S_HEATER
              			heater();//temp ack
              #ifdef ID_S_HVAC
              			hvac();//temp ack
              	case V_HVAC_FLOW_STATE:
              #ifdef ID_S_HEATER
              			heater();//temp ack
              #ifdef ID_S_HVAC
              			hvac();//temp ack
              #ifdef ID_S_LOCK
              	case V_LOCK_STATUS:
              		lock(); //temp ack
              #ifdef ID_S_IR
              	case V_IR_SEND:
              		irVal = message.getLong();
              		ir(); // temp ack
              	case V_IR_RECEIVE:
              		ir(); // temp ack
              	case V_SCENE_ON:
              		sceneVal = message.getInt();
              		Serial.println(" On");
              		scene();// temp ack
              	case V_SCENE_OFF:
              		Serial.println(" Off");
              		scene();// temp ack
              	case V_RGB:
              		rgbState=message.getString();
              		rgbLight(); // temp ack
              	case V_RGBW:
              		rgbwLight();
              #ifdef ID_S_HVAC
              	//  hvac_SetPointHeat
              	//  hvac_SetPointCool
              	//  hvac_FlowState
              	//  hvac_FlowMode
              	//  hvac_Speed
              	case V_HVAC_SETPOINT_COOL:
              		hvac();//temp ack
              	case V_HVAC_FLOW_MODE:
              		hvac();//temp ack
              	case V_HVAC_SPEED:
              		hvac();//temp ack
              	default:
              		Serial.println(message.type);
              I selected the board "Nordic nRF52832 DK" in the board manager.
              You'll need a separate serial gateway running for it to communicate with, or else it will never get to the section where it sleeps.
                #524
                For the current measurement, just program it with the above sketch on your Waveshare, then unplug your module from the BLE400 board and power it using a GND dupont wire and a Vcc dupont wire connected through your uCurrent Gold, or whatever it is that you're using to measure current. I should think that would work, wouldn't it?
                Or do you only have the main board without the smaller plug-in module?
                It actually looks like a nice setup.
                rmtuckerR 3 Replies Last reply
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  When you unplug the little board it only has 1.27mm spaced pins and they are not standard dupont size so shy soldering to them which would mean i could not plug it back in to the BLE.
                  Anyway i am only using a crappy multimeter and with it plugged in and running your sketch i am getting 140uA but i will find a way of unplugging it so hang fire.
                  Nca78N 1 Reply Last reply
                    @rmtucker you could try to just solder 2 tiny wires on top of the board for vcc and gnd pins so you don't mess with the connectors for plugin it back on the main board ?
                    • Nca78N Nca78
                      #527
                      @Nca78
                      Agreed. It sounds as though the bigger problem is going to be his crappy multimeter, if that's all he has. Maybe a good time for an upgrade?
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        Ok with my crappy multimeter i am getting 4-5uA with just Vcc and Ground connected.
                          #529
                          I'll try removing the 32.768Khz crystal from an infor-link module and then re-run the sketch that relies on an external interrupt to wake from sleep. Maybe that will get us closer to the theoretical minimum current of just the nRF52832 chip by itself.
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            Just a little thought on this and a bit of googling.
                            Just the system on consumption is 1-2uA without the rtc that is needed for wakeup so i don,t think the figures we are getting are that far away from the spec sheet?
                              Agreed. We're in the ballpark.
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                400,000 hours on 2xAA if we let it sleep.:smile:
                                That will do for me!.
                                Now a little playtime and maybe some range testing.
                                  Yeah, I guess I won't amputate the xtal just yet. It can run for quite a while at 6ua. :)
                                    So, just did the experiment, and here are the results. Supplying 3.3v to the Ebyte Module, a voltage of 3.0 volts on A4 yields an analogRead(A4) of 4095. Less voltage on A4 yields a lower number.
                                    So, generalizing, I suspect that the reference voltage for analogRead() is Vcc-0.3.
                                    So, you either know Vcc, because of a voltage regulator or something, or else you must call hwCpuVoltage() to get what it is. Then, subtract 0.3v from that, and that's the reference voltage which corresponds to an analogRead() return value of 4095.
                                    d00616D
                                    d00616D
                                    d00616
                                    The internal reference is 0.6V the nRF5 MCU's have an internal programmable divider. With Arduino this divider is programmed to 1/5. If you switch to the external reference the "gain" is 1/4.
                                    I measure with my CDEByte 11-15µA for sleep without interrupt waiting. With a RedBear BLE Nano 2 I have measured 15µA. Both compiled as BLE Nano 2. I have used the VC165 multimeter.
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      I2c is not working properly either.
                                      Here is a test on a HTU21D sensor.
                                      HTU21D-F test
                                      Temp: -46.57		Hum: 84.10
                                      Temp: 81.10		Hum: 59.68
                                      Temp: 81.10		Hum: 26.48
                                      Temp: -2.64		Hum: 26.48
                                      Temp: 51.58		Hum: 26.48
                                      Temp: 4.91		Hum: 25.02
                                      Temp: 33.74		Hum: 25.02
                                      Temp: 93.45		Hum: 25.02
                                      Temp: 4.22		Hum: 26.48
                                      Temp: 95.51		Hum: 116.81
                                      Temp: -39.02		Hum: 116.81
                                      Temp: 94.14		Hum: 25.02
                                      Temp: 94.14		Hum: 116.81
                                      Temp: 120.22		Hum: 116.81
                                      Temp: -8.82		Hum: 111.44
                                      Temp: 120.22		Hum: 19.64
                                      Temp: 94.14		Hum: 111.44
                                      Temp: -8.82		Hum: 116.81
                                      Temp: 120.22		Hum: 111.44
                                      Temp: -8.82		Hum: 19.64
                                      Temp: 33.05		Hum: 111.44
                                      Temp: 94.14		Hum: 19.64
                                      Temp: 4.22		Hum: 19.64
                                      Temp: 2.84		Hum: 111.44
                                      Temp: 3.53		Hum: 111.44
                                      Temp: -10.20		Hum: 19.64
                                        #536
                                        Seems like there's more than one library named "Wire" that's floating around at the same time. I wonder if perhaps the compiler is finding the proper Wire library inside Arduino-nRF5? Or maybe it's linking with an unrelated Wire library? To answer that, you could try inserting a Serial.println() into the proper library and see if it fires off when you run your code.
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          Yes checked that and it is using the correct wire.h.
