  3. MY_SIGNING_SIMPLE_PASSWD
20 Posts 2 Posters 3.7k Views 4 Watching
  • L Offline
    L Offline
    LuFi
    Dear all,
    yesterday i tried to test the "MY_SIGNING_SIMPLE_PASSWD" feature from the Development Branch.
    But without success.
    I configured the Gateway and also one of my Sensors with the same Password, but always i'got "SIGN FAIL" on my sensor and nothing happens on the gateway.
    Are there any other Requirements except the Passwrd to test this Feature ?
    Is it required, that the Backend (FHEM) supports this feature ?
    Or is this Feature currently "work in Progress" and not usable ?
    Thx
    LuFi
    A 1 Reply Last reply
    • L LuFi
      Dear all,
      Thx
      LuFi
      A Offline
      A Offline
      Anticimex
      @LuFi it is fully implemented and tested on the development branch. Have you examined the log to be sure all messages are successfully transmitted? I am 95% sure you have messages that fail to be sent. The log would show them as NACKs. The log parser on the home page can help you.
      • L Offline
        L Offline
        LuFi
        @Anticimex
        First a small explaniation:
        I'am using an Arduino Nano as an Serial Gateway and an Pro Mini 8Mhz 3.3v as Node.
        The Nodes using the latest (dev) MysBootloader.
        I updated to the latest Git today. (The last copy was around 2 weeks old). And some new Problems occur.
        First of all, if the sketch uses more than 40% of Flash size, it will be not possible to enable MY_DEBUG.
        For testing i only uncomment te following line from MyConfig.h:
        //#define MY_SIGNING_SIMPLE_PASSWD "MyInsecurePassword"
        After this i flashed the Gateway with the sample serial gateway Code and my node with some cleanups and my sources.
        Gateway DEBUG:
        0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta
        0;255;3;0;9;27 !SGN:PER:TAMPERED
        0;255;3;0;9;67 SGN:INI:BND OK
        0;255;3;0;9;69 TSM:INIT
        0;255;3;0;9;71 TSF:WUR:MS=0
        0;255;3;0;9;80 TSM:INIT:TSP OK
        0;255;3;0;9;220397651 TSM:INIT:GW MODE
        0;255;3;0;9;587730215 TSM:READY:ID=0,PAR=0,DIS=0
        0;255;3;0;9;7698180 MCO:REG:NOT NEEDED
        0;255;0;0;18;2.2.0-beta
        0;255;3;0;9;470288900 MCO:BGN:STP
        0;255;3;0;9;470288908 MCO:BGN:INIT OK,TSP=1
        0;255;3;0;9;470288913 TSM:READY:NWD REQ
        0;255;3;0;9;943272247 SGN:SGN:NREQ=255
        0;255;3;0;9;24117412 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        0;255;3;0;9;841822260 TSM:READY:NWD REQ
        0;255;3;0;9;842151476 SGN:SGN:NREQ=255
        0;255;3;0;9;27217422 TSF:MSG:SEND,0-0-265-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        GATEWAY while NODE goes online:
        0;255;3;0;9;841883507 TSF:MSG:READ,102-102-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;1030958138 TSF:MSG:BC
        0;255;3;0;9;1196641597 TSF:MSG:FPAR REQ,ID=102
        0;255;3;0;9;1178224471 TSF:PNG:SEND,TO=0
        0;255;3;0;9;1396328274 TSF:CKU:OK
        0;255;3;0;9;1430995773 TSF:MSG:GWL OK
        0;255;3;0;9;1196641915 SGN:SKP:MSG CMD=3,TYPE=8
        0;255;3;0;9;1196641922 TSF:MSG:SEND,0-0-102-102,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        0;255;3;0;9;1196        TSM:READY:NWD REQ
        0;255;3;0;9;825832008 SGN:SGN:NREQ=255
        0;255;3;0;9;24117412 TSF:MSG:SEND,3.0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        0;255;30-2<5-255;0;9;841822260 TSM:READY:NWD REQ
        0;255;3;0;9;842151477 SGN:SGN:NREQ=255
        0;255;3;0;9;24117412 TSF:MSG:SEND,3.0-265-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        0;255;3;0;9;841823834 TSF:MSG:READ,8-175-167/t=123,c=3,t=23,pt=4,l=11,sg=0:1929015540
        0;255;3;0;9;842087802 TSF:MSG:REL MSG
        0;255;3;0;9;1196641597 SGN:SGN:8!=0 NUS
        0;255;3;0;9;1196641650 !TSF:MSG:SEND,8-0-144-167,s=122,c=3,t=23,pt=4,l=11,sg=0,ft=0,st=NACK:1929015540
        0;255;3;0;9;1196641660 TSM:READY:NWD REQ
        0;255;3;0;9;825636406 SGN:SGN:NREQ=255
        0;255;3;0;9;⸮G RECV,HP TSM:READY:NWD REQ
        0;255;3;0;9;841824088 TSF:MSG:READ,237-90-229-s=73,c=6,t=170,pt=6,l=25,sg=1:243C493A88BC436FBA00000000000000000000000000000000000A004D
        0;255;3;0;9;926774071 TSF:MSG:REL MSG
        0;255;3;0;9;1196641597 SGN:SGN:237!=0 NUS
        0;255;3;0;9;1196641650 !TSF:MSG:SEND,237-0-18-226,s=72,c=6,t=170,pt=6,l=29,sg=1,ft=0,st=NACK:243C493A88BC436FKD000300000000000000000000000000
        0;255;3;0;5;0
        0;255;3;0;9;808464461 TSM:READY:NWD REQ
        0;255;3;0;9;875836982 SGN:SGN:NREQ=255
        0;255;3;0;9        TSM:READY:NWD REQ
        0;255;3;0;9;841822280 SGN:SGN:NREQ=255
        0;255;3;0;9;841824075 TSF:MSG:READ,225-4-204,s=31,c=3,t=141,pt=4,l=10,sg=1:-624252800
        0;255;6<0;9<825441657 !TSF:MSG:PVER,1=2
        0;25
        NODE Log:
        0 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta
        49 !SGN:PER:TAMPERED
        79 SGN:INI:BND OK
        81 TSM:INIT
        81 TSF:WUR:MS=0
        90 TSM:INIT:TSP OK
        92 TSF:SID:OK,ID=102
        96 TSM:FPAR
        96 SGN:SKP:MSG CMD=3,TYPE=7
        141 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        954 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        960 SGN:SKP:MSG CMD=3,TYPE=8
        962 TSF:MSG:FPAR OK,ID=0,D=1
        2150 TSM:FPAR:OK
        2150 TSM:ID
        2152 TSM:ID:OK
        2154 TSM:UPL
        2156 SGN:SKP:MSG CMD=3,TYPE=24
        2162 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2172 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2179 SGN:SKP:MSG CMD=3,TYPE=25
        2181 TSF:MSG:PONG RECV,HP=1
        2185 TSM:UPL:OK
        2187 TSM:READY:ID=102,PAR=0,DIS=1
        2189 !SGN:SGN:STATE
        2191 !TSF:MSG:SIGN FAIL
        2195 SGN:PRE:SGN REQ
        2197 SGN:PRE:WHI NREQ
        2199 SGN:SKP:MSG CMD=3,TYPE=15
        2205 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=1,st=OK:0101
        2213 SGN:PRE:XMT,TO=0
        2215 SGN:PRE:WAIT GW
        2220 TSF:MSG:READ,0-0-102,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        2228 SGN:SKP:MSG CMD=3,TYPE=15
        2230 SGN:PRE:SGN REQ,FROM=0
        2234 !SGN:SGN:STATE
        2236 !TSF:MSG:SIGN FAIL
        2238 !SGN:SGN:STATE
        2240 !TSF:MSG:SIGN FAIL
        4243 !SGN:SGN:STATE
        4245 !TSF:MSG:SIGN FAIL
        4247 !SGN:SGN:STATE
        4249 !TSF:MSG:SIGN FAIL
        4251 !SGN:SGN:STATE
        4253 !TSF:MSG:SIGN FAIL
        4255 !SGN:SGN:STATE
        4257 !TSF:MSG:SIGN FAIL
        4261 !SGN:SGN:STATE
        4263 !TSF:MSG:SIGN FAIL
        4265 !SGN:SGN:STATE
        4268 !TSF:MSG:SIGN FAIL
        4270 MCO:REG:REQ
        4272 SGN:SKP:MSG CMD=3,TYPE=26
        4278 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=8,st=OK:2
        6287 SGN:SKP:MSG CMD=3,TYPE=26
        6293 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        8302 SGN:SKP:MSG CMD=3,TYPE=26
        8308 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        10317 SGN:SKP:MSG CMD=3,TYPE=26
        10323 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        12333 MCO:BGN:STP
        12388 MCO:BGN:INIT OK,TSP=1
        The node ends up into an Bootloop.
        And some node Messages causes an Gateway Reboot.
        Another Point i recognized was that i were no longer able to see the Bootloader requests in my Backend (FHEM) log.
        What i'am doing wrong ?
        Best Regards
        LuFi
        • L LuFi
          @Anticimex
          Gateway DEBUG:
          0;255;3;0;5;0
          0;25
          NODE Log:
          79 SGN:INI:BND OK
          81 TSM:INIT
          81 TSF:WUR:MS=0
          90 TSM:INIT:TSP OK
          96 TSM:FPAR
          2150 TSM:FPAR:OK
          2150 TSM:ID
          2152 TSM:ID:OK
          2154 TSM:UPL
          2185 TSM:UPL:OK
          2189 !SGN:SGN:STATE
          2234 !SGN:SGN:STATE
          2238 !SGN:SGN:STATE
          4243 !SGN:SGN:STATE
          4247 !SGN:SGN:STATE
          4251 !SGN:SGN:STATE
          4255 !SGN:SGN:STATE
          4261 !SGN:SGN:STATE
          4265 !SGN:SGN:STATE
          4270 MCO:REG:REQ
          12333 MCO:BGN:STP
          Best Regards
          LuFi
          A Offline
          A Offline
          Anticimex
          @LuFi on beta track signing personalization has been updated to track corruptions. You need to redo personalization in order to get the checksum stored correctly. The log reports that personalization had been tampered.
          Tips for reducing memory footprint on development branch is available here.
          L 1 Reply Last reply
          • A Anticimex
            L Offline
            L Offline
            LuFi
            @Anticimex said in MY_SIGNING_SIMPLE_PASSWD:
            Is it enough to use an empty gateway sketch with the following line to accomplish this?
            #define RESET_EEPROM_PERSONALIZATION
            • L LuFi
              A Offline
              A Offline
              Anticimex
              @LuFi No, because
              1. That flag is specific to the personalizer sketch
              2. That flag will erase any personalization and replace with 0xFF as documented in the description of the define.
                EDIT: by doing this in the personalizer sketch and executing that, it should then pass as using the simple flag does not require personalization data. You probably was using personalization data at some point.
              • L Offline
                L Offline
                LuFi
                ok, i tried that and the "TAMPERED" message is gone.
                But it does not work ......
                I never received a message from the serial gateway. So i added a short print to the Setup() function and now i see a reboot every time i send a message to the gateway.
                Into the Node log i can see some cryptic characters.
                Could this be a Memory problem ?
                Flash: 20338 Bytes (66%)
                SRAM: 1664 Bytes (81%)
                Or are the 328p Arduino are not really usable for this ?
                Are there any Hardware recommendations for Signing / Encryption ?
                Gateway:
                0;255;3;0;9;60 TSM:INIT
                0;255;3;0;9;62 TSF:WUR:MS=0
                0;255;3;0;9;71 TSM:INIT:TSP OK
                0;255;3;0;9;74 TSM:INIT:GW MODE
                0;255;3;0;9;77 TSM:READY:ID=0,PAR=0,DIS=0
                0;255;3;0;9;80 MCO:REG:NOT NEEDED
                0;255;3;0;9;86 MCO:BGN:STP
                SETUP()
                0;255;3;0;9;92 MCO:BGN:INIT OK,TSP=1
                0;255;3;0;9;12518 TSF:MSG:SEND,0-57-54-0,s=101,c=7,t=104,pt=2,l=0,sg=0,ft=0,st=OK:30068
                0;255;3;0;9;1 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta
                0;255;3;0;9;66 TSM:INIT
                0;255;3;0;9;68 TSF:WUR:MS=0
                0;255;3;0;9;77 TSM:INIT:TSP OK
                0;255;3;0;9;80 TSM:INIT:GW MODE
                0;255;3;0;9;83 TSM:READY:ID=0,PAR=0,DIS=0
                0;255;3;0;9;87 MCO:REG:NOT NEEDED
                0;255;3;0;9;91 MCO:BGN:STP
                SETUP()
                0;255;3;0;9;98 MCO:BGN:INIT OK,TSP=1
                0;255;3;0;9;2097 0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta
                0;255;3;0;9;59 TSM:INIT
                0;255;3;0;9;61 TSF:WUR:MS=0
                0;255;3;0;9;69 TSM:INIT:TSP OK
                0;255;3;0;9;72 TSM:INIT:GW MODE
                0;255;3;0;9;75 TSM:READY:ID=0,PAR=0,DIS=0
                0;255;3;0;9;78 MCO:REG:NOT NEEDED
                0;255;3;0;9;83 MCO:BGN:STP
                SETUP()
                0;255;3;0;9;90 MCO:BGN:INIT OK,TSP=1
                Node:
                83 TSM:INIT
                86 TSF:WUR:MS=0
                94 TSM:INIT:TSP OK
                96 TSF:SID:OK,ID=102
                98 TSM:FPAR
                876 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                882 TSF:MSG:FPAR OK,ID=0,D=1
                2150 TSM:FPAR:OK
                2150 TSM:ID
                2152 TSM:ID:OK
                2154 TSM:UPL
                2158 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                2168 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2174 TSF:MSG:PONG RECV,HP=1
                2179 TSM:UPL:OK
                2181 TSM:READY:ID=102,PAR=0,DIS=1
                2183 TSM:READY:ID=102,PAR=0,DIS=1
                2220 TSM:INIT
                2220 TSF:WUR:MS=0
                2228 TSM:INIT:TSP OK
                2232 TSF:SID:OK,ID=102
                2234 TSM:FPAR
                2277 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OM:
                1074660236 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                1074660242 TSF:MSG:FPAR OK,ID=0,D=1
                1074661412 TSM:FPAR:OK
                1074661414 TSM:ID
                1074661416 TSM:ID:OK
                1074661418 TSM:UPL
                1074661424 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                77014330 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                77014338 TSF:MSG:PONG RECV,HP=1
                77014340 TSM:UPL:OK
                77014344 TSM:READY:ID=102,PAR=0,DIS=1
                9373611 TSF:MSG:READ,143-0-7,s=95,c=7,t=171,pt=5,l=0,sg=1:
                2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta
                94 TSM:INIT
                96 TSF:WUR:MS=0
                104 TSM:INIT:TSP OK
                106 TSF:SID:OK,ID=102
                108 TSM:FPAR
                151 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                163 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                169 TSF:MSG:FPAR OK,ID=0,D=1
                2160 TSM:FPAR:OK
                2160 TSM:ID
                2162 TSM:ID:OK
                2164 TSM:UPL
                2207 !TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                4216 TSM:UPL
                4222 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                4233 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                4239 TSF:MSG:PONG RECV,HP=1
                4241 TSM:UPL:OK
                4243 TSM:READY:ID=102,PAR=0,DIS=1
                81 TSM:INIT
                81 TSF:WUR:MS=0
                90 TSM:INIT:TSP OK
                96 TSM:FPAR
                137 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                311 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                317 TSF:MSG:FPAR OK,ID=0,D=1
                2146 TSM:FPAR:OK
                2146 TSM:ID
                2148 TSM:ID:OK
                2150 TSM:UPL
                2154 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                2164 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2170 TSF:MSG:PONG RECV,HP=1
                2174 TSM:UPL:OK
                2177 TSM:READY:ID=102,PAR=0,DIS=1
                ⸮⸮55⸮ 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta
                83 TSM:INIT
                83 TSF:WUR:MS=0
                92 TSM:INIT:TSP OK
                94 TSF:SID:OK,ID=102
                98 TSM:FPAR
                139 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2148 !TSM:FPAR:NO REPLY
                2150 TSM:FPAR
                2193 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                3135 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                3141 TSF:MSG:FPAR OK,ID=0,D=1
                4202 TSM:FPAR:OK
                4202 TSM:ID
                4204 TSM:ID:OK
                4206 TSM:UPL
                4249 !TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                4259 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                4265 TSF:MSG:PONG RECV,HP=1
                4268 TSM:UPL:OK
                4270 TSM:READY:ID=102,PAR=0,DIS=1
                83 TSM:INIT
                83 TSF:WUR:MS=0
                92 TSM:INIT:TSP OK
                96 TSM:FPAR
                243 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                249 TSF:MSG:FPAR OK,ID=0,D=1
                2148 TSM:FPAR:OK
                2148 TSM:ID
                2150 TSM:ID:OK
                2152 TSM:UPL
                2156 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                2166 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2172 TSF:MSG:PONG RECV,HP=1
                2177 TSM:UPL:OK
                2179 TSM:READY:ID=102,PAR=0,DIS=1
                83 TSM:INIT
                83 TSF:WUR:MS=0
                92 TSM:INIT:TSP OK
                96 TSM:FPAR
                2150 TSM:FPAR
                2453 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                2459 TSF:MSG:FPAR OK,ID=0,D=1
                4202 TSM:FPAR:OK
                4202 TSM:ID
                4204 TSM:ID:OK
                4206 TSM:UPL
                4210 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                4220 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                4227 TSF:MSG:PONG RECV,HP=1
                4231 TSM:UPL:OK
                4233 TSM:READY:ID=102,PAR=0,DIS=1
                81 TSM:INIT
                83 TSF:WUR:MS=0
                92 TSM:INIT:TSP OK
                96 TSM:FPAR
                540 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                546 TSF:MSG:FPAR OK,ID=0,D=1
                2148 TSM:FPAR:OK
                2148 TSM:ID
                2150 TSM:ID:OK
                2152 TSM:UPL
                2195 !TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                2205 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2211 TSF:MSG:PONG RECV,HP=1
                2213 TSM:UPL:OK
                2215 TSM:READY:ID=102,PAR=0,DIS=1
                • L LuFi
                  Gateway:
                  SETUP()
                  SETUP()
                  SETUP()
                  Node:
                  83 TSM:INIT
                  86 TSF:WUR:MS=0
                  94 TSM:INIT:TSP OK
                  98 TSM:FPAR
                  2150 TSM:FPAR:OK
                  2150 TSM:ID
                  2152 TSM:ID:OK
                  2154 TSM:UPL
                  2179 TSM:UPL:OK
                  2220 TSM:INIT
                  2220 TSF:WUR:MS=0
                  2234 TSM:FPAR
                  1074661414 TSM:ID
                  1074661418 TSM:UPL
                  77014340 TSM:UPL:OK
                  94 TSM:INIT
                  96 TSF:WUR:MS=0
                  104 TSM:INIT:TSP OK
                  108 TSM:FPAR
                  2160 TSM:FPAR:OK
                  2160 TSM:ID
                  2162 TSM:ID:OK
                  2164 TSM:UPL
                  4216 TSM:UPL
                  4241 TSM:UPL:OK
                  81 TSM:INIT
                  81 TSF:WUR:MS=0
                  90 TSM:INIT:TSP OK
                  96 TSM:FPAR
                  2146 TSM:FPAR:OK
                  2146 TSM:ID
                  2148 TSM:ID:OK
                  2150 TSM:UPL
                  2174 TSM:UPL:OK
                  83 TSM:INIT
                  83 TSF:WUR:MS=0
                  92 TSM:INIT:TSP OK
                  98 TSM:FPAR
                  2150 TSM:FPAR
                  4202 TSM:FPAR:OK
                  4202 TSM:ID
                  4204 TSM:ID:OK
                  4206 TSM:UPL
                  4268 TSM:UPL:OK
                  83 TSM:INIT
                  83 TSF:WUR:MS=0
                  92 TSM:INIT:TSP OK
                  96 TSM:FPAR
                  2148 TSM:FPAR:OK
                  2148 TSM:ID
                  2150 TSM:ID:OK
                  2152 TSM:UPL
                  2177 TSM:UPL:OK
                  83 TSM:INIT
                  83 TSF:WUR:MS=0
                  92 TSM:INIT:TSP OK
                  96 TSM:FPAR
                  2150 TSM:FPAR
                  4202 TSM:FPAR:OK
                  4202 TSM:ID
                  4204 TSM:ID:OK
                  4206 TSM:UPL
                  4231 TSM:UPL:OK
                  81 TSM:INIT
                  83 TSF:WUR:MS=0
                  92 TSM:INIT:TSP OK
                  96 TSM:FPAR
                  2148 TSM:FPAR:OK
                  2148 TSM:ID
                  2150 TSM:ID:OK
                  2152 TSM:UPL
                  2213 TSM:UPL:OK
                  A Offline
                  A Offline
                  Anticimex
                  @LuFi not that I know of. I use atmga328p myself and it works fine.
                  If you read the signing documentation, you'll see that there is a hw chip available for signing; the atsha204a. For encryption, there is the rfm69.
                  • L Offline
                    L Offline
                    LuFi
                    Yes, i did read that documentation.
                    So for encryption you prefer the atsha204a (hardware encryption) in combination with the rfm69 (433/868/915) Mhz radio ?
                    Typically, the encryption should work via the NRF2401 (2.4 Ghz) module though?
                    And you have already used it?
                    I am always ready to look for the error first with me ;-)
                    P.S.:+1: Many thx for your Support
                    Regards
                    LuFi
                    • L LuFi
                      Regards
                      LuFi
                      A Offline
                      A Offline
                      Anticimex
                      @LuFi no, atsha204a is for signing. Nrf24 has no hw encryption support. Rfm69 has. I use nrf24 with software encryption for my tests. And if you use the simple password option, you get software based signing and software based encryption on all hw (except rfm69 based nodes).
                      • L Offline
                        L Offline
                        LuFi
                        All right, thank you. I'll look what I do wrong.
                        • L LuFi
                          A Offline
                          A Offline
                          Anticimex
                          @LuFi there is constant action on the development branch. It could be that something grew over a critical threshold for atmga328p based gateways with the simple signing option enabled. You could try to sift through log using git bisect if you have an older known good version. Signing and personalization has not been touched for some time. I have not tested any signing features since my last signing commit. You could start with 59337b19fe2280e3d375a5e70156c75379d18196
                          • L Offline
                            L Offline
                            LuFi
                            You are fully right, i tested again with the Version from 7 of June.
                            And now i'am able to see messages on node and Gateway.
                            Also was it be possible to enable MY_DEBUG.
                            How i need to register the node now ?
                            Gateway:
                            0;255;3;0;9;32 TSM:INIT
                            0;255;3;0;9;34 TSF:WUR:MS=0
                            0;255;3;0;9;44 TSM:INIT:TSP OK
                            0;255;3;0;9;47 TSM:INIT:GW MODE
                            0;255;3;0;9;49 TSM:READY:ID=0,PAR=0,DIS=0
                            0;255;3;0;9;53 MCO:REG:NOT NEEDED
                            0;255;3;0;9;57 MCO:BGN:STP
                            0;255;3;0;9;64 MCO:BGN:INIT OK,TSP=1
                            0;255;3;0;9;7947 TSF:MSG:READ,100-69-67,s=243,c=6,t=27,pt=5,l=25,sg=0:205739666
                            0;255;3;0;9;7954 !TSF:MSG:PVER,0=2
                            0;255;3;0;9;7958 TSF:MSG:READ,156-86-188,s=209,c=3,t=10,pt=2,l=19,sg=0:896
                            0;255;3;0;9;7964 !TSF:MSG:PVER,3=2
                            0;255;3;0;9;8240 TSF:MSG:READ,84-13-13,s=195,c=6,t=239,pt=0,l=24,sg=1:⸮⸮⸮⸮|x`
                            0;255;3;0;9;8247 !TSF:MSG:PVER,0=2
                            0;255;3;0;9;8251 TSF:MSG:READ,108-183-170,s=192,c=4,t=37,pt=3,l=15,sg=1:44342
                            0;255;3;0;9;8258 !TSF:MSG:PVER,1=2
                            0;255;3;0;9;24365 TSF:MSG:READ,68-108-243,s=208,c=0,t=182,pt=6,l=18,sg=1:0468A782773E75481B000000000000000000
                            0;255;3;0;9;24374 TSF:MSG:REL MSG
                            0;255;3;0;9;24378 !TSF:RTE:243 UNKNOWN
                            0;255;3;0;9;24430 !TSF:MSG:SEND,68-0-243-243,s=208,c=0,t=182,pt=6,l=18,sg=1,ft=0,st=NACK:0468A782773E75481B000000000000000000
                            0;255;3;0;9;24442 TSF:MSG:READ,12-221-80,s=37,c=1,t=70,pt=0,l=14,sg=1:⸮⸮⸮⸮⸮⸮⸮⸮
                            0;255;3;0;9;24450 !TSF:MSG:PVER,1=2
                            0;255;3;0;9;24677 TSF:MSG:READ,27-236-160,s=96,c=4,t=229,pt=4,l=25,sg=0:1384774534
                            0;255;3;0;9;24685 !TSF:MSG:PVER,3=2
                            0;255;3;0;9;24689 TSF:MSG:READ,242-199-50,s=75,c=5,t=246,pt=2,l=25,sg=0:421
                            0;255;3;0;9;24695 TSF:MSG:REL MSG
                            0;255;3;0;9;24699 !TSF:RTE:50 UNKNOWN
                            0;255;3;0;9;24752 !TSF:MSG:SEND,242-0-50-50,s=75,c=5,t=246,pt=2,l=31,sg=0,ft=0,st=NACK:421
                            Node:
                            34 TSM:INIT
                            36 TSF:WUR:MS=0
                            45 TSM:INIT:TSP OK
                            47 TSF:SID:OK,ID=102
                            49 TSM:FPAR
                            92 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            489 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            495 TSF:MSG:FPAR OK,ID=0,D=1
                            2101 TSM:FPAR:OK
                            2101 TSM:ID
                            2103 TSM:ID:OK
                            2105 TSM:UPL
                            2109 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                            2119 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            2125 TSF:MSG:PONG RECV,HP=1
                            2129 TSM:UPL:OK
                            2131 TSM:READY:ID=102,PAR=0,DIS=1
                            2134 MCO:BGN:STP
                            6148 !MCO:SND:NODE NOT REG
                            6150 !MCO:SND:NODE NOT REG
                            6299 !MCO:SND:NODE NOT REG
                            6307 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                            6338 TSF:MSG:READ,0-0-102,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                            6533 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:27
                            6541 !MCO:SND:NODE NOT REG
                            10547 !MCO:SND:NODE NOT REG
                            10549 !MCO:SND:NODE NOT REG
                            10553 MCO:BGN:INIT OK,TSP=1
                            10708 !MCO:SND:NODE NOT REG
                            14721 MCO:SLP:MS=1000,SMS=0,I1=0,M1=1,I2=255,M2=255
                            14727 TSF:TDI:TSL
                            14729 MCO:SLP:WUP=-1
                            14731 TSF:TRI:TSB
                            14733 !MCO:SND:NODE NOT REG
                            14737 MCO:SLP:MS=600000,SMS=1,I1=1,M1=1,I2=0,M2=1
                            14747 TSF:M⸮G:SEND,102-102-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            14770 TSF:MSG:READ,0-0-102,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                            14968 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=32,pt=5,l=4,sg=1,ft=0,st=OK:500
                            15480 TSF:TDI:TSL
                            Regards
                            LuFi
                            • L LuFi
                              Gateway:
                              Node:
                              34 TSM:INIT
                              36 TSF:WUR:MS=0
                              45 TSM:INIT:TSP OK
                              49 TSM:FPAR
                              2101 TSM:FPAR:OK
                              2101 TSM:ID
                              2103 TSM:ID:OK
                              2105 TSM:UPL
                              2129 TSM:UPL:OK
                              2134 MCO:BGN:STP
                              14727 TSF:TDI:TSL
                              14731 TSF:TRI:TSB
                              15480 TSF:TDI:TSL
                              Regards
                              LuFi
                              A Offline
                              A Offline
                              Anticimex
                              @LuFi you get a lot of NACKs. Have you checked your radio power supply etc? Many threads on the forum about radio issues. It is not a signing issue.
                              • L Offline
                                L Offline
                                LuFi
                                Both are PA Radios with Antenna, and on both i added an 47uf Capacitor.
                                What i do not understand is the Node not registerd Messge.
                                LuFi
                                • L LuFi
                                  LuFi
                                  A Offline
                                  A Offline
                                  Anticimex
                                  @LuFi I am not an expert on those messages, I suggest you use the log parser on the homepage as I said earlier.
                                  That said, I suspect they are there because your GW cannot get any messages through to the node, all SEND:s are NACKed. And it also looks like node and GW disasgree on protocol versions, at least that is what I think !TSF:MSG:PVER,1=2 means.
                                  • L Offline
                                    L Offline
                                    LuFi
                                    Oh, yes. But this happens since i first updated the gateway while the node was sending Data based on latest dev Version.
                                    After that i updated the Node.
                                    • L LuFi
                                      A Offline
                                      A Offline
                                      Anticimex
                                      @LuFi it is well known that sending full sized payloads (as you do when signing is enabled) puts a strain on the radio that nrf24 radios have trouble handling.
                                      It could also be some bug on development branch present in the commit you use which has been fixed in a later commit. I also see that there are indications that your gw is configured as a repeater. I don't know if that has anything to do with it. I don't think it is supported to have a gw as a repeater. It at least makes no sense. But I could be wrong about that.
                                      You could try the latest but without debugging and see if anything comes through that way, with and without signing.
                                      • L Offline
                                        L Offline
                                        LuFi
                                        I used the default Gateway sample Code.
                                        I will change this.
                                        Many thx for Support !
                                        Regards
                                        LuFi
                                        • L LuFi
                                          I will change this.
                                          Regards
                                          LuFi
                                          A Offline
                                          A Offline
                                          Anticimex
                                          @LuFi you are welcome. Hope it works out.
