MY_SIGNING_SIMPLE_PASSWD
@Anticimex said in MY_SIGNING_SIMPLE_PASSWD:
You need to redo personalization in order to get the checksum stored correctly.
Is it enough to use an empty gateway sketch with the following line to accomplish this?
#define RESET_EEPROM_PERSONALIZATION@LuFi No, because
- That flag is specific to the personalizer sketch
- That flag will erase any personalization and replace with 0xFF as documented in the description of the define.
EDIT: by doing this in the personalizer sketch and executing that, it should then pass as using the simple flag does not require personalization data. You probably was using personalization data at some point.
ok, i tried that and the "TAMPERED" message is gone.
But it does not work ......
I never received a message from the serial gateway. So i added a short print to the Setup() function and now i see a reboot every time i send a message to the gateway.
Into the Node log i can see some cryptic characters.
Could this be a Memory problem ?
Flash: 20338 Bytes (66%)
SRAM: 1664 Bytes (81%)Or are the 328p Arduino are not really usable for this ?
Are there any Hardware recommendations for Signing / Encryption ?
Gateway:
0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta 0;255;3;0;9;60 TSM:INIT 0;255;3;0;9;62 TSF:WUR:MS=0 0;255;3;0;9;71 TSM:INIT:TSP OK 0;255;3;0;9;74 TSM:INIT:GW MODE 0;255;3;0;9;77 TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;80 MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.2.0-beta 0;255;3;0;9;86 MCO:BGN:STP SETUP() 0;255;3;0;9;92 MCO:BGN:INIT OK,TSP=1 0;255;3;0;9;12518 TSF:MSG:SEND,0-57-54-0,s=101,c=7,t=104,pt=2,l=0,sg=0,ft=0,st=OK:30068 0;255;3;0;9;1 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta 0;255;3;0;9;66 TSM:INIT 0;255;3;0;9;68 TSF:WUR:MS=0 0;255;3;0;9;77 TSM:INIT:TSP OK 0;255;3;0;9;80 TSM:INIT:GW MODE 0;255;3;0;9;83 TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;87 MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.2.0-beta 0;255;3;0;9;91 MCO:BGN:STP SETUP() 0;255;3;0;9;98 MCO:BGN:INIT OK,TSP=1 0;255;3;0;9;2097 0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta 0;255;3;0;9;59 TSM:INIT 0;255;3;0;9;61 TSF:WUR:MS=0 0;255;3;0;9;69 TSM:INIT:TSP OK 0;255;3;0;9;72 TSM:INIT:GW MODE 0;255;3;0;9;75 TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;78 MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.2.0-beta 0;255;3;0;9;83 MCO:BGN:STP SETUP() 0;255;3;0;9;90 MCO:BGN:INIT OK,TSP=1Node:
0 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 83 TSM:INIT 86 TSF:WUR:MS=0 94 TSM:INIT:TSP OK 96 TSF:SID:OK,ID=102 98 TSM:FPAR 141 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 876 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 882 TSF:MSG:FPAR OK,ID=0,D=1 2150 TSM:FPAR:OK 2150 TSM:ID 2152 TSM:ID:OK 2154 TSM:UPL 2158 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2168 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2174 TSF:MSG:PONG RECV,HP=1 2179 TSM:UPL:OK 2181 TSM:READY:ID=102,PAR=0,DIS=1 2183 TSM:READY:ID=102,PAR=0,DIS=1 2220 TSM:INIT 2220 TSF:WUR:MS=0 2228 TSM:INIT:TSP OK 2232 TSF:SID:OK,ID=102 2234 TSM:FPAR 2277 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OM: 1074660236 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 1074660242 TSF:MSG:FPAR OK,ID=0,D=1 1074661412 TSM:FPAR:OK 1074661414 TSM:ID 1074661416 TSM:ID:OK 1074661418 TSM:UPL 1074661424 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 77014330 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 77014338 TSF:MSG:PONG RECV,HP=1 77014340 TSM:UPL:OK 77014344 TSM:READY:ID=102,PAR=0,DIS=1 9373611 TSF:MSG:READ,143-0-7,s=95,c=7,t=171,pt=5,l=0,sg=1: 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 94 TSM:INIT 96 TSF:WUR:MS=0 104 TSM:INIT:TSP OK 106 TSF:SID:OK,ID=102 108 TSM:FPAR 151 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 163 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 169 TSF:MSG:FPAR OK,ID=0,D=1 2160 TSM:FPAR:OK 2160 TSM:ID 2162 TSM:ID:OK 2164 TSM:UPL 2207 !TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1 4216 TSM:UPL 4222 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1 4233 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 4239 TSF:MSG:PONG RECV,HP=1 4241 TSM:UPL:OK 4243 TSM:READY:ID=102,PAR=0,DIS=1 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 81 TSM:INIT 81 TSF:WUR:MS=0 90 TSM:INIT:TSP OK 92 TSF:SID:OK,ID=102 96 TSM:FPAR 137 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 311 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 317 TSF:MSG:FPAR OK,ID=0,D=1 2146 TSM:FPAR:OK 2146 TSM:ID 2148 TSM:ID:OK 2150 TSM:UPL 2154 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2164 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2170 TSF:MSG:PONG RECV,HP=1 2174 TSM:UPL:OK 2177 TSM:READY:ID=102,PAR=0,DIS=1 ⸮⸮55⸮ 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 83 TSM:INIT 83 TSF:WUR:MS=0 92 TSM:INIT:TSP OK 94 TSF:SID:OK,ID=102 98 TSM:FPAR 139 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2148 !TSM:FPAR:NO REPLY 2150 TSM:FPAR 2193 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 3135 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 3141 TSF:MSG:FPAR OK,ID=0,D=1 4202 TSM:FPAR:OK 4202 TSM:ID 4204 TSM:ID:OK 4206 TSM:UPL 4249 !TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1 4259 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 4265 TSF:MSG:PONG RECV,HP=1 4268 TSM:UPL:OK 4270 TSM:READY:ID=102,PAR=0,DIS=1 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 83 TSM:INIT 83 TSF:WUR:MS=0 92 TSM:INIT:TSP OK 94 TSF:SID:OK,ID=102 96 TSM:FPAR 139 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 243 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 249 TSF:MSG:FPAR OK,ID=0,D=1 2148 TSM:FPAR:OK 2148 TSM:ID 2150 TSM:ID:OK 2152 TSM:UPL 2156 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2166 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2172 TSF:MSG:PONG RECV,HP=1 2177 TSM:UPL:OK 2179 TSM:READY:ID=102,PAR=0,DIS=1 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 83 TSM:INIT 83 TSF:WUR:MS=0 92 TSM:INIT:TSP OK 94 TSF:SID:OK,ID=102 96 TSM:FPAR 139 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2148 !TSM:FPAR:NO REPLY 2150 TSM:FPAR 2193 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2453 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 2459 TSF:MSG:FPAR OK,ID=0,D=1 4202 TSM:FPAR:OK 4202 TSM:ID 4204 TSM:ID:OK 4206 TSM:UPL 4210 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 4220 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 4227 TSF:MSG:PONG RECV,HP=1 4231 TSM:UPL:OK 4233 TSM:READY:ID=102,PAR=0,DIS=1 2 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 81 TSM:INIT 83 TSF:WUR:MS=0 92 TSM:INIT:TSP OK 94 TSF:SID:OK,ID=102 96 TSM:FPAR 139 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 540 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 546 TSF:MSG:FPAR OK,ID=0,D=1 2148 TSM:FPAR:OK 2148 TSM:ID 2150 TSM:ID:OK 2152 TSM:UPL 2195 !TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1 2205 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2211 TSF:MSG:PONG RECV,HP=1 2213 TSM:UPL:OK 2215 TSM:READY:ID=102,PAR=0,DIS=1 -
Gateway:
Yes, i did read that documentation.
So for encryption you prefer the atsha204a (hardware encryption) in combination with the rfm69 (433/868/915) Mhz radio ?
Typically, the encryption should work via the NRF2401 (2.4 Ghz) module though?
And you have already used it?I am always ready to look for the error first with me ;-)
P.S.:+1: Many thx for your Support
Regards
LuFi
Regards
LuFi
@LuFi no, atsha204a is for signing. Nrf24 has no hw encryption support. Rfm69 has. I use nrf24 with software encryption for my tests. And if you use the simple password option, you get software based signing and software based encryption on all hw (except rfm69 based nodes).
@LuFi there is constant action on the development branch. It could be that something grew over a critical threshold for atmga328p based gateways with the simple signing option enabled. You could try to sift through log using git bisect if you have an older known good version. Signing and personalization has not been touched for some time. I have not tested any signing features since my last signing commit. You could start with 59337b19fe2280e3d375a5e70156c75379d18196
You are fully right, i tested again with the Version from 7 of June.
And now i'am able to see messages on node and Gateway.
Also was it be possible to enable MY_DEBUG.How i need to register the node now ?
Gateway:
0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS-X,VER=2.2.0-beta 0;255;3;0;9;32 TSM:INIT 0;255;3;0;9;34 TSF:WUR:MS=0 0;255;3;0;9;44 TSM:INIT:TSP OK 0;255;3;0;9;47 TSM:INIT:GW MODE 0;255;3;0;9;49 TSM:READY:ID=0,PAR=0,DIS=0 0;255;3;0;9;53 MCO:REG:NOT NEEDED 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.2.0-beta 0;255;3;0;9;57 MCO:BGN:STP 0;255;3;0;9;64 MCO:BGN:INIT OK,TSP=1 0;255;3;0;9;7947 TSF:MSG:READ,100-69-67,s=243,c=6,t=27,pt=5,l=25,sg=0:205739666 0;255;3;0;9;7954 !TSF:MSG:PVER,0=2 0;255;3;0;9;7958 TSF:MSG:READ,156-86-188,s=209,c=3,t=10,pt=2,l=19,sg=0:896 0;255;3;0;9;7964 !TSF:MSG:PVER,3=2 0;255;3;0;9;8240 TSF:MSG:READ,84-13-13,s=195,c=6,t=239,pt=0,l=24,sg=1:⸮⸮⸮⸮|x` 0;255;3;0;9;8247 !TSF:MSG:PVER,0=2 0;255;3;0;9;8251 TSF:MSG:READ,108-183-170,s=192,c=4,t=37,pt=3,l=15,sg=1:44342 0;255;3;0;9;8258 !TSF:MSG:PVER,1=2 0;255;3;0;9;24365 TSF:MSG:READ,68-108-243,s=208,c=0,t=182,pt=6,l=18,sg=1:0468A782773E75481B000000000000000000 0;255;3;0;9;24374 TSF:MSG:REL MSG 0;255;3;0;9;24378 !TSF:RTE:243 UNKNOWN 0;255;3;0;9;24430 !TSF:MSG:SEND,68-0-243-243,s=208,c=0,t=182,pt=6,l=18,sg=1,ft=0,st=NACK:0468A782773E75481B000000000000000000 0;255;3;0;9;24442 TSF:MSG:READ,12-221-80,s=37,c=1,t=70,pt=0,l=14,sg=1:⸮⸮⸮⸮⸮⸮⸮⸮ 0;255;3;0;9;24450 !TSF:MSG:PVER,1=2 0;255;3;0;9;24677 TSF:MSG:READ,27-236-160,s=96,c=4,t=229,pt=4,l=25,sg=0:1384774534 0;255;3;0;9;24685 !TSF:MSG:PVER,3=2 0;255;3;0;9;24689 TSF:MSG:READ,242-199-50,s=75,c=5,t=246,pt=2,l=25,sg=0:421 0;255;3;0;9;24695 TSF:MSG:REL MSG 0;255;3;0;9;24699 !TSF:RTE:50 UNKNOWN 0;255;3;0;9;24752 !TSF:MSG:SEND,242-0-50-50,s=75,c=5,t=246,pt=2,l=31,sg=0,ft=0,st=NACK:421Node:
0 MCO:BGN:INIT NODE,CP=RNONAS-X,VER=2.2.0-beta 34 TSM:INIT 36 TSF:WUR:MS=0 45 TSM:INIT:TSP OK 47 TSF:SID:OK,ID=102 49 TSM:FPAR 92 TSF:MSG:SEND,102-102-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 489 TSF:MSG:READ,0-0-102,s=255,c=3,t=8,pt=1,l=1,sg=0:0 495 TSF:MSG:FPAR OK,ID=0,D=1 2101 TSM:FPAR:OK 2101 TSM:ID 2103 TSM:ID:OK 2105 TSM:UPL 2109 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2119 TSF:MSG:READ,0-0-102,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2125 TSF:MSG:PONG RECV,HP=1 2129 TSM:UPL:OK 2131 TSM:READY:ID=102,PAR=0,DIS=1 2134 MCO:BGN:STP 6148 !MCO:SND:NODE NOT REG 6150 !MCO:SND:NODE NOT REG 6299 !MCO:SND:NODE NOT REG 6307 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK: 6338 TSF:MSG:READ,0-0-102,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE> 6533 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:27 6541 !MCO:SND:NODE NOT REG 10547 !MCO:SND:NODE NOT REG 10549 !MCO:SND:NODE NOT REG 10553 MCO:BGN:INIT OK,TSP=1 10708 !MCO:SND:NODE NOT REG 14721 MCO:SLP:MS=1000,SMS=0,I1=0,M1=1,I2=255,M2=255 14727 TSF:TDI:TSL 14729 MCO:SLP:WUP=-1 14731 TSF:TRI:TSB 14733 !MCO:SND:NODE NOT REG 14737 MCO:SLP:MS=600000,SMS=1,I1=1,M1=1,I2=0,M2=1 14747 TSF:M⸮G:SEND,102-102-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK: 14770 TSF:MSG:READ,0-0-102,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE> 14968 TSF:MSG:SEND,102-102-0-0,s=255,c=3,t=32,pt=5,l=4,sg=1,ft=0,st=OK:500 15480 TSF:TDI:TSLRegards
LuFi
Gateway:
LuFi
Both are PA Radios with Antenna, and on both i added an 47uf Capacitor.
What i do not understand is the Node not registerd Messge.
LuFi
@LuFi I am not an expert on those messages, I suggest you use the log parser on the homepage as I said earlier.
That said, I suspect they are there because your GW cannot get any messages through to the node, all SEND:s are NACKed. And it also looks like node and GW disasgree on protocol versions, at least that is what I think !TSF:MSG:PVER,1=2 means. -
Oh, yes. But this happens since i first updated the gateway while the node was sending Data based on latest dev Version.
After that i updated the Node.
@LuFi it is well known that sending full sized payloads (as you do when signing is enabled) puts a strain on the radio that nrf24 radios have trouble handling.
It could also be some bug on development branch present in the commit you use which has been fixed in a later commit. I also see that there are indications that your gw is configured as a repeater. I don't know if that has anything to do with it. I don't think it is supported to have a gw as a repeater. It at least makes no sense. But I could be wrong about that.
You could try the latest but without debugging and see if anything comes through that way, with and without signing. -
I used the default Gateway sample Code.
I will change this.Many thx for Support !
Regards
LuFi
