  3. RGB LED strip
RGB LED strip
70 Posts 22 Posters 44.1k Views 27 Watching
  • AWIA AWI
    @maghac The FastLed library has some functions for linear fading. The characteristics of the Mosfet's can be ignored. When using PWM these are used as switches (i.e. on/off).
    For inspiration: this sketch was for a RGBW strip and uses the FastLED nscale8() for smooth fading. Also there is a non-blocking version of the fading routine and a state machine to have button control.
    (the 'W' in the RGBW can easily be removed. It is calculated here as a kind of greatest common divisor of RGB)
     PROJECT: MySensors / RGB light NEOPIXEL
     PROGRAMMER: AWI
     DATE: october 10, 2015/ last update: september 20, 2016
     FILE: AWI_Wall_LIght_x.ino
     LICENSE: Public domain
     Hardware: RGBW Pro Mini and MySensors 2.0,
     Special:
    	uses Fastled library  (great & fast RBG/HSV universal library) 			https://github.com/FastLED/FastLED
     SUMMARY:
    	Different patterns and brightness settings
    	Button switches on/off and color with long press
     Remarks:
    	Fixed node-id
     Change log:
     20160915 - Updated to MySensors 2.0
     20160920 - Changed state change to dimmer i.s.o. switch()
     20161120 - Various small adjustments
     20170120 - Change to RGBW non addressable strip
    //****  MySensors *****
    #define MY_RADIO_NRF24										// Enable and select radio type attached
    #define MY_NODE_ID 63										// 62
    #define NODE_TXT "W 63"										// Text to add to sensor name
    // change the pins to free up the pwm pin for led control
    #define MY_RF24_CE_PIN   4 									//<-- NOTE!!! changed, the default is 9
    #define MY_RF24_CS_PIN   10  								// default is 10
    //#define RF24_PA_LEVEL RF24_PA_MAX
    // helpers
    #define LOCAL_DEBUG											// enable if print wanted
    #ifdef LOCAL_DEBUG
    #define Sprint(...) (Serial.print( __VA_ARGS__))			// macro as substitute for print, enable if no print wanted
    #define Sprintln(...) (Serial.println( __VA_ARGS__))		// macro as substitute for println
    #define Sprint(a)
    #define Sprintln(a)
    #include <SPI.h>											// My Sensors
    #include <FastLED.h>										// https://github.com/FastLED/FastLED
    #include "Button.h"											// https://github.com/JChristensen/Button
    // Arduino pin attached to drivers
    const int RED_PIN  = 5 ;
    const int WHITE_PIN = 9 ;
    const int GREEN_PIN = 3 ;
    const int BLUE_PIN = 6 ;
    const int buttonPin = 7 ;									// push button
    const int RGB_LightChild = 0 ;								// Child Id's, standard light child on/off/ dim
    const int RGB_RGBChild = 1 ;								// RGB light child (on/off/dim/color, if controller supports V_RBG))
    CRGB strip ;												// RGB(W) strip (Fastled)
    uint8_t stripW = 0 ;										// White component
    uint8_t actualBrightness = 0xFF ;							// actual strip brightness
    // Kelving colors: Light & daylight (in Fastled reference only)
    /// 1900 Kelvin Candle=0xFF9329 /* 1900 K, 255, 147, 41 */,
    /// 2600 Kelvin Tungsten40W=0xFFC58F /* 2600 K, 255, 197, 143 */,
    /// 2850 Kelvin Tungsten100W=0xFFD6AA /* 2850 K, 255, 214, 170 */,
    /// 3200 Kelvin	Halogen=0xFFF1E0 /* 3200 K, 255, 241, 224 */,
    /// 5200 Kelvin CarbonArc=0xFFFAF4 /* 5200 K, 255, 250, 244 */,
    /// 5400 Kelvin HighNoonSun=0xFFFFFB /* 5400 K, 255, 255, 251 */,
    /// 6000 Kelvin DirectSunlight=0xFFFFFF /* 6000 K, 255, 255, 255 */,
    /// 7000 Kelvin OvercastSky=0xC9E2FF /* 7000 K, 201, 226, 255 */,
    /// 20000 Kelvin ClearBlueSky=0x409CFF /* 20000 K, 64, 156, 255 */
    char setRGBvalue[] = "FEBC5400";
    CRGB curRGB = 0xFEBC54 ;	 								// Controller sent RGB(W) value, default tungsten40W "FFC58F"
    uint16_t curBrightness = 0xFF, setBrightness = 0xFF ;		// Brightness globals (actualBrightness)
    unsigned long updateBrightnessDelay, lastBrightnessUpdate ; // Brightness timers
    int RGBonoff ;												// OnOff flag
    unsigned long idleTimer = millis() ;						// return to idle timer
    const unsigned long idleTime = 10000UL;						// return to idle after 10 secs
    const unsigned long dimTime = 1000UL;						// dim period
    const unsigned long heartbeatInterval = 1 * 60UL * 1000UL ;	// heartbeatinterval, just to let the controller know I am alive
    unsigned long heartbeatCounter = 0 ;
    MyMessage lightRGBMsg(RGB_LightChild, V_RGB);				// standard messages, light
    MyMessage lightdimmerMsG(RGB_LightChild ,V_DIMMER);
    MyMessage lightOnOffMessage(RGB_LightChild, V_STATUS);
    Button myBtn(buttonPin, true, true, 20);					//Declare the button (pin, pull_up, invert, debounce_ms)
    // Simple state machine for button state
    enum {sIdle, sBrightness, sPattern} ;						// simple state machine for button press
    int State ;
    	pinMode(RED_PIN,   OUTPUT);
    	pinMode(GREEN_PIN, OUTPUT);
    	pinMode(BLUE_PIN,  OUTPUT);
    	pinMode(WHITE_PIN, OUTPUT);
    	request(RGB_LightChild, V_RGBW) ;
    	/*for(int i = 0 ; i < 6 ; i++) {			// get color value from EEPROM (8 char for RGBW)
    		setRGBvalue[i] = loadState(i) ;
    	curRGB = strtol( setRGBvalue, NULL, 16);				// copy the RGB value to the led Strip (convert to long)
    	showAnalogRGB() ;
    void presentation(){
    // MySensors
    	sendSketchInfo("AWI RGBW strip " NODE_TXT, "2.0"); wait(50) ;
    	present(RGB_RGBChild, S_RGB_LIGHT, "RGB RGBW strip " NODE_TXT); wait(50) ;
    // read button and act accordingly
    // short press: on/off
    // longer press: set patterns with following short press
    // long press: set brightness increase
    	myBtn.read();               							//Read the button (only read)
    	unsigned long now = millis(); 							// loop timer reference
    	switch (State) {
    		case sIdle:											// default state, browse through patterns
    			if (myBtn.wasReleased()){						// light on/ off in idle
    				RGBonoff = !RGBonoff ;						// invert light state
    				setLightBrightness((RGBonoff == 1)?setBrightness:0, dimTime);
    				send(lightOnOffMessage.set(RGBonoff));		// and update controller
    			} else if (myBtn.pressedFor(800)){				// move to Pattern update state with long press
    				idleTimer = now ;							// return to idle after ...
    				State = sPattern ;
    			break ;
    		case sPattern:										// entered after long press/ change colors (tbd)
    			if (myBtn.pressedFor(4000)){					// when press even longer move to Brightness update
    				State = sBrightness ;
    			} else if (myBtn.wasPressed()){
    				//setPattern = (setPattern + 1) % lastPatternIdx ;  // increase pattern and wrap
    				//setLightPattern((setPattern), 500 );
    				idleTimer = now ;
    			} else if ( now > idleTime + idleTimer  ){		// return to idle after ...
    				State = sIdle ;
    			break ;
    		case sBrightness:									// entered after looong press
    			if (myBtn.wasPressed()){						// if pressed again increase brightness
    				setLightBrightness((curBrightness+0x1F) % 0xFF, 0) ; // increase brightness and wrap (0..0xFF)
    				idleTimer = now ;
    				State = sIdle ;
    			break ;
    		default :
    			State = sIdle ;
    			break ;
    	updateLightBrightness();								// update Brightness if time
    	if ( now > heartbeatCounter  + heartbeatInterval){		// heartbeat every hour
    	    sendHeartbeat();
    		heartbeatCounter = now ;
    // Sets the light brightness, takes value and time (ms) as input
    void setLightBrightness(int newBrightness, unsigned long updateTime){
    	// global: curBrightness, actualBrightness, updateBrightnessDelay
    	updateBrightnessDelay = updateTime / 0xFF ;				// delay = time / max steps
    	curBrightness = newBrightness ;							// set curBrightness to new value, rest is done in update
    // Update the light brightness if time
    void updateLightBrightness(){
    	// global: curBrightness, actualBrightness, updateBrightnessDelay, lastBrightnessUpdate ;
    	//static byte actualBrightness ;							// store real brightness state for slow dim
    	unsigned long now = millis() ;
    	if (now > lastBrightnessUpdate + updateBrightnessDelay){// check if time for update
    		if ( actualBrightness > curBrightness) {
    			--actualBrightness ;
    			showAnalogRGB() ;
    		} else if ( actualBrightness < curBrightness){
    			++actualBrightness ;
    			showAnalogRGB() ;
    		lastBrightnessUpdate = now ;
    // Incoming messages from MySensors
    void receive(const MyMessage &message){
    	int ID = message.sensor;
    	Serial.print("Sensor: ");
    	Serial.println(ID);
    	switch (ID){
    		case RGB_LightChild:									// same behaviour as RGB child/ fall through
    		case RGB_RGBChild:										// if controller can handle V_RGB
    			if (message.type == V_RGB) {						// check for RGB type
    				strcpy(setRGBvalue, message.getString());		// get the payload
    				curRGB = strtoul( setRGBvalue, NULL, 16) ;	// copy the RGB value to the led Strip (convert to long)
    			} else if (message.type == V_RGBW) {						// check for RGB type
    				curRGB = strtoul( setRGBvalue, NULL, 16) >> 8;	// copy the RGB value to the led Strip (convert to long)
    			} else if (message.type == V_DIMMER) {				// if DIMMER type, adjust brightness
    				setBrightness = map(message.getInt(), 0, 100, 0, 255);
    				setLightBrightness(setBrightness, dimTime) ;
    			} else if (message.type == V_STATUS) {				// if on/off type, toggle brightness
    				RGBonoff = message.getInt();
    			break ;
        showAnalogRGB();
    	dispRGBstat();
    // showAnalogRGB: this is like FastLED.show(), but outputs on
    // analog PWM output pins instead of sending data to an intelligent,
    // pixel-addressable LED strip.
    void showAnalogRGB(){
    	strip = curRGB ;
    	strip.nscale8(actualBrightness)  ;
    	int commonRGB = min(min(strip.r, strip.g), strip.b) ;		// smallest value is White component
    	strip.r -= commonRGB ;
    	strip.g -= commonRGB ;
    	strip.b -= commonRGB ;
    	stripW = commonRGB ;
    	Sprint("Color RGBW ") ;
    	Sprint(strip.r, HEX);
    	Sprint(" ") ;
    	Sprint(strip.g, HEX);
    	Sprint(" ") ;
    	Sprint(strip.b, HEX);
    	Sprint(" ") ;
    	Sprintln(stripW, HEX) ;
    	analogWrite(RED_PIN,   strip.r );
    	analogWrite(GREEN_PIN, strip.g );
    	analogWrite(BLUE_PIN,  strip.b );
    	analogWrite(WHITE_PIN, stripW ) ;
    // debug
    // display the status of all RGB: controller, requested, real
    void dispRGBstat(void){
        Serial.print(" Color: "); Serial.print(setRGBvalue);
        Serial.print(" Brightness: "); Serial.println(setBrightness);
    maghacM
    maghacM
    maghac
    @AWI Looks good, I'll see if I can incorporate this in my solution. Thanks!
    • maghacM
      maghacM
      maghac
      I'd thought I'd share a pic now that the led strip has been mounted. Unfortunately the iphone camera doesn't have enough dynamic range to capture the light correctly - it looks a lot better in reality!
      Through some HomeAssistant/tellstick magic I can also turn it on and off using a normal 433Mhz remote instead of having to send MQTT messages from the command line. This increased the WAF considerably :)
      • maghacM maghac
        I built a RGB LED strip controllable via mysensor, based on a 12V RGB LED strip and three IRF540 MOSFETs. The arduino is a 5V pro mini clone that I feed with 12V on the RAW pin.
        I followed the guide on https://learn.adafruit.com/rgb-led-strips/usage for wiring the MOSFETS and the LED strip. I used the Newbie PCB by @sundberg84 for holding the arduino and the radio, but put the MOSFETs on a separate prototyping board (maybe next time I'll try to solder them to the prototyping area of the Newbie PCB).
        I implemented a fading feature in the sketch, so it can fade slowly between colors or on/off. The speed is controlled by sending a V_VAR1 message with the speed (typical value could be around 200-300 for a nice effect). Speed = 0 means fading is off.
        Here is the code:
         * LED STRIP sketch for Mysensors
         * 1.0
         *   Based on the example sketch in mysensors
         * 1.1
         *   fadespeed parameter (send as V_VAR1 message)
         *   HomeAssistant compatible (send status to ack)
        #define MY_OTA_FIRMWARE_FEATURE
        #define MY_NODE_ID AUTO
        #define CHILD_ID_LIGHT 1
        #define SN "LED Strip"
        #define SV "1.1"
        MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
        MyMessage rgbMsg(CHILD_ID_LIGHT, V_RGB);
        MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
        byte red = 255;
        byte green = 255;
        byte blue = 255;
        byte r0 = 255;
        byte g0 = 255;
        byte b0 = 255;
        char rgbstring[] = "ffffff";
        int on_off_status = 0;
        int dimmerlevel = 100;
        int fadespeed = 0;
        #define REDPIN 6
        #define GREENPIN 5
        #define BLUEPIN 3
          // Fix the PWM timer. Without this the LEDs will flicker.
          TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00);
          // Output pins
          pinMode(REDPIN, OUTPUT);
          pinMode(GREENPIN, OUTPUT);
          pinMode(BLUEPIN, OUTPUT);
        	sendSketchInfo(SN, SV);
          static bool first_message_sent = false;
          if ( first_message_sent == false ) {
            Serial.println( "Sending initial state..." );
            set_hw_status();
            send_status();
            first_message_sent = true;
          int val;
        		Serial.println( "V_RGB command: " );
            Serial.println(message.data);
            long number = (long) strtol( message.data, NULL, 16);
            // Save old value
            strcpy(rgbstring, message.data);
            // Split it up into r, g, b values
            red = number >> 16;
            green = number >> 8 & 0xFF;
            blue = number & 0xFF;
            send_status();
            set_hw_status();
        	} else if (message.type == V_LIGHT || message.type == V_STATUS) {
            Serial.println( "V_LIGHT command: " );
            val = atoi(message.data);
            if (val == 0 or val == 1) {
              on_off_status = val;
              send_status();
              set_hw_status();
          } else if (message.type == V_DIMMER || message.type == V_PERCENTAGE) {
            Serial.print( "V_DIMMER command: " );
            if (val >= 0 and val <=100) {
              dimmerlevel = val;
              send_status();
              set_hw_status();
          } else if (message.type == V_VAR1 ) {
            Serial.print( "V_VAR1 command: " );
            if (val >= 0 and val <= 2000) {
              fadespeed = val;
        		Serial.println( "Invalid command received..." );
        		return;
        void set_rgb(int r, int g, int b) {
          analogWrite(REDPIN, r);
          analogWrite(GREENPIN, g);
          analogWrite(BLUEPIN, b);
        void set_hw_status() {
          int r = on_off_status * (int)(red * dimmerlevel/100.0);
          int g = on_off_status * (int)(green * dimmerlevel/100.0);
          int b = on_off_status * (int)(blue * dimmerlevel/100.0);
          if (fadespeed >0) {
            float dr = (r - r0) / float(fadespeed);
            float db = (b - b0) / float(fadespeed);
            float dg = (g - g0) / float(fadespeed);
            for (int x = 0;  x < fadespeed; x++) {
              set_rgb(r0 + dr*x, g0 + dg*x, b0 + db*x);
              delay(100);
          set_rgb(r, g, b);
          r0 = r;
          b0 = b;
          g0 = g;
        void send_status() {
          send(rgbMsg.set(rgbstring));
          send(lightMsg.set(on_off_status));
          send(dimmerMsg.set(dimmerlevel));
        I have a MQTT gateway and I can turn the strip on, set the color to pink and fade speed to 500 by the following commands:
        mosquitto_pub -t mysensors-in/240/1/1/0/40 -m ff6060
        mosquitto_pub -t mysensors-in/240/1/1/0/24 -m 500
        mosquitto_pub -t mysensors-in/240/1/1/0/2 -m 1
        A couple of pics:
        OliverDogO
        OliverDogO
        OliverDog
        @maghac , great work!!!
        I want to build a battery powered Mood Light based on your sketch and RGB Common Cathode Leds (4 or 5 of them).
        Before getting those RGB leds yet (already ordered but it takes 2 months to receive) I tested your sketch with three ordinary 3 mm colored leds - Green, Red and Yellow (should be blue but I don´t have it) and got it running on Home Assistant. On batteries as well. Color selection and Dimmer working as well...
        But I don´t get fading effects (called by transition time on Home Assistant). No matter how long I ask the transition it changes the same time I ask.
        Serial monitor never shows that V_VAR1 message type. Was it supposed to show it?
        What did I miss?
        • maghacM
          maghacM
          maghac
          wrote on last edited by maghac
          @OliverDog, thanks!
          The V_VAR1 message is used to set the speed of the fading (e.g the time between stepping the RGB values towards the value received with the V_RGB message). Not sure why it doesn't work for you, but maybe it's related to the fact that you don't have the real RGB leds?
          You may be interested to know that I have implemented a new version of this sketch. The problem with the old one is that it did the fading in a loop which meant that no new commands were processed during the fade. The new version implements it differently so that messages can be received while the light is fading in a sort of multitasking fashion. This opened up the possibility to implement "programs" that control the LED strip in the background while the device is still receiving messages (e.g during a slow fade to green I can tell it to turn off or to fade to blue instead, without having to wait for the current fade to stop). I have implemented two such programs - one is a sort of an alarm mode (blink white on/off) and the other is a relax program (very slow fade between various pastel colours). To enable the programs, you send a V_VAR2 message with a number: 0: normal (e.g fixed to one colour), 1: alarm and 2: relax.
          Since V_VAR2 is message type 25, this is the corresponding MQTT message to enable the relax program:
          mosquitto_pub -t mysensors-in/2/1/1/0/25 -m 2
          Code is below. I intend to update it further (i.e the "party" program is missing! :) ) and then I'll post the new versions here.
          Have fun!
           * 1.0
           * 1.1
           * 1.2
           *   OTA support
           * 1.3
           *   Power-on self test
           * 1.4
           *   Bug fix
           * 1.5
           *   Other default values
           * 1.6
           *   Repeater feature
           * 1.7
           *   Multitasking. Alarm, Relax and normal modes.
          #define MY_REPEATER_FEATURE
          #define SV "1.7"
          int current_r = 255;
          int current_g = 255;
          int current_b = 255;
          int target_r = 255;
          int target_g = 255;
          int target_b = 255;
          int save_r;
          int save_g;
          int save_b;
          float delta_r = 0.0;
          float delta_g = 0.0;
          float delta_b = 0.0;
          int fadespeed = 20;
          unsigned long last_update = 0;
          int tick_length = 10;
          int fade_step = 0;
          int program_timer;
          int program_cycle;
          #define REDPIN 6
          #define GREENPIN 5
          #define BLUEPIN 3
          #define LIGHT_NORMAL 0
          #define LIGHT_FADING 1
          #define PROGRAM_NORMAL 0
          #define PROGRAM_ALARM 1
          #define PROGRAM_RELAX 2
          int light_mode = LIGHT_NORMAL;
          int program_mode = PROGRAM_NORMAL;
          #define RELAX_SPEED 50
          #define MAX_CYCLES_RELAX 7
          const int program_param_RELAX[MAX_CYCLES_RELAX][3] = {
            {255, 32, 0},
            {255, 32, 16},
            {255, 16, 32},
            {255, 128, 0},
            {255, 32, 00},
            {255, 32, 32},
            {255, 0, 32}
            // Output pins
          void selftest() {
            on_off_status = 1;
            current_r = 255;
            current_g = 0;
            current_b = 0;
            set_hw_status();
            wait(100);
            current_r = 0;
            current_g = 255;
            set_hw_status();
            wait(100);
            current_g = 0;
            current_b = 255;
            set_hw_status();
            wait(100);
            current_r = 255;
            current_g = 255;
            set_hw_status();
            wait(100);
            on_off_status = 0;
              selftest();
              set_hw_status();
              send_status(1, 1, 1);
            if (now - last_update > tick_length) {
              last_update = now;
              if (light_mode == LIGHT_FADING) {
                calc_fade();
              if (program_mode > PROGRAM_NORMAL) {
                handle_program();
            set_hw_status();
            int val;
          		Serial.print( "V_RGB: " );
              // Save old value
              int r = number >> 16;
              int g = number >> 8 & 0xFF;
              int b = number & 0xFF;
              init_fade(fadespeed, r, g, b);
              send_status(0, 0, 1);
              Serial.print( "V_LIGHT: " );
                send_status(1, 0, 0);
              Serial.print( "V_DIMMER: " );
                dimmerlevel = val;
                send_status(0, 1, 0);
              Serial.print( "V_VAR1: " );
                fadespeed = val;
            } else if (message.type == V_VAR2 ) {
              Serial.print( "V_VAR2: " );
              if (val == PROGRAM_NORMAL) {
                stop_program();
              } else if (val == PROGRAM_ALARM || val == PROGRAM_RELAX) {
                init_program(val);
          		return;
          void init_program(int program) {
            program_mode = program;
            program_cycle = 0;
            save_rgb();
            if (program == PROGRAM_ALARM) {
              current_r = 255;
              current_g = 255;
              current_b = 255;
              program_timer = 50;
            } else if (program == PROGRAM_RELAX) {
              program_timer = 300;
                        program_param_RELAX[program_cycle][0],
                        program_param_RELAX[program_cycle][1],
                        program_param_RELAX[program_cycle][2]);
          void handle_program() {
            program_timer--;
            if (program_mode == PROGRAM_ALARM) {
              if (program_timer == 0) {
                program_timer = 50;
                if (program_cycle == 0) {
                  program_cycle = 1;
                  current_r = 0;
                  current_g = 0;
                  current_b = 0;
                  program_cycle = 0;
                  current_r = 255;
                  current_g = 255;
                  current_b = 255;
            } else if (program_mode == PROGRAM_RELAX) {
              if (light_mode == LIGHT_NORMAL) {
                program_cycle = (program_cycle+1) % MAX_CYCLES_RELAX;
                Serial.print("Next cycle step ");
                Serial.println(program_cycle);
                init_fade(fadespeed * RELAX_SPEED,
          void stop_program() {
            restore_rgb();
          void save_rgb() {
            save_r = current_r;
            save_g = current_g;
            save_b = current_b;
          void restore_rgb() {
            current_r = save_r;
            current_g = save_g;
            current_b = save_b;
          void init_fade(int t, int r, int g, int b) {
            Serial.print( "Init fade" );
            light_mode = LIGHT_FADING;
            target_r = r;
            target_g = g;
            target_b = b;
            fade_step = t;
            delta_r = (target_r - current_r) / float(fade_step);
            delta_g = (target_g - current_g) / float(fade_step);
            delta_b = (target_b - current_b) / float(fade_step);
          void calc_fade() {
            if (fade_step > 0) {
              fade_step--;
              current_r = target_r - delta_r * fade_step;
              current_g = target_g - delta_g * fade_step;
              current_b = target_b - delta_b * fade_step;
              Serial.println( "Normal mode" );
            int r = on_off_status * (int)(current_r * dimmerlevel/100.0);
            int g = on_off_status * (int)(current_g * dimmerlevel/100.0);
            int b = on_off_status * (int)(current_b * dimmerlevel/100.0);
            set_rgb(r, g, b);
          void send_status(int send_on_off_status, int send_dimmerlevel, int send_rgbstring) {
            if (send_rgbstring) send(rgbMsg.set(rgbstring));
            if (send_on_off_status) send(lightMsg.set(on_off_status));
            if (send_dimmerlevel) send(dimmerMsg.set(dimmerlevel));
          • OliverDogO
            OliverDogO
            OliverDog
            the new sketch is even better... it responds faster than the other...
            but I still don't have fading effects... just the one that you have configured on the sketch (20) which is awesome by the way...
            It seems that Home Assistant does not send neither V_VAR1 nor V_VAR2 messages...
            the command:
            {"entity_id":"light.rgb_leds_12_1", "color_name":"green", "brightness_pct": 15, "transition":20}
            shows the same effect that the command:
            {"entity_id":"light.rgb_leds_12_1", "color_name":"green", "brightness_pct": 15, "transition":1}
            I will try HASS forum!
            Thank you very much.
            maghacM 1 Reply Last reply
              moskovskiy82
              Have tried to integrate your code and it's awesome except for one thing.
              Fixing the PWM breaks the timer. So if i use it straight away my DHT22 and MQ-2 will not send any data.
              Well not like that - DHT22 sends humidity but no temp
              As soon as i comment out the below line everything starts to work out
              The only exception that i use PWM pins 5,6,9 and pin3 is user for IR transmitter. Any ideas for an easy fix?
              • OliverDogO OliverDog
                the command:
                maghacM
                maghacM
                maghac
                @OliverDog HA will not send VAR1 or VAR2 unless you implement some specific functionality to do this. I set up switches in HA to send the correct MQTT message to the mysensors gateway in order to activate the alarm and relax modes. Here's my switch.yaml file:
                - platform: tellstick
                - platform: mqtt
                  command_topic: "mysensors-in/3/1/1/0/25"
                  payload_on: "1"
                  payload_off: "0"
                  optimistic: false
                  qos: 0
                  retain: false
                - platform: mqtt
                  payload_on: "2"
                  payload_off: "0"
                  optimistic: false
                  qos: 0
                  retain: false
                OliverDogO 1 Reply Last reply
                • M moskovskiy82
                  maghacM
                  maghacM
                  maghac
                  @moskovskiy82 Thanks!
                  To be absolutely honest I'm not exactly sure what the TCCR0A statement does :) I had problems with flickering LEDs so I googled it and someone on the arduino.cc forums had the same problem and fixed it by putting that line in the code.
                  Using other pins for the LEDs should be fine, as long as they are PWM pins of course. Just change the #define statements accordingly.
                    MikeF
                    @maghac @moskovskiy82 I came across this some time ago, with an RGB LED project. Whilst I can't recall the details, it's to do with setting the Arduino's PWM timers - apparently, the frequencies of the R(ed) & B(lue) channels can be close enough to causing 'beating', which gives rise to flickering. This statement changes the frequency of one of the channels slightly, thereby eliminating the flickering.
                    • M MikeF
                      maghacM
                      maghacM
                      maghac
                      Yes, after googling it I could see it was related to setting the timers. There is maybe another way to fix it and still keep the correct timer functions for other functionalities to be intact (e.g so that @moskovskiy82 can still use the DHT22), but I haven't investigated further. In any case, I believe it's easier to split separate functions to separate physical units instead of trying to put as much functionality into one single unit as possible.
                      In my case, the unit is mounted in a not-so-well-ventilated enclosure in the ceiling, so I doubt that I would get a correct temperature reading anyway :)
                      • maghacM maghac
                        - platform: mqtt
                          payload_on: "1"
                          payload_off: "0"
                          optimistic: false
                          qos: 0
                          retain: false
                        - platform: mqtt
                          payload_on: "2"
                          payload_off: "0"
                          optimistic: false
                          qos: 0
                          retain: false
                        OliverDogO
                        OliverDogO
                        OliverDog
                        @maghac I have posted the issue (not working VAR1 and VAR2 on Home Assistant) on the HA forum, and got steps for asking the implement...
                        I will ask for such implement and it may work later...
                        Thanks for the help...
                        By the way, I did not test the switches but seems doing the job...
                          moskovskiy82
                          After some investigating it wasn't a timer issue but a range issue with a node (it was hard to figure out). So went ahead and built another node with your code. But being lazy - just bought an rgb strip drive from aliexpress (too much soldering of mosfets for me).
                          It uses some RGBdriver.h library https://github.com/letsgoING/Libraries/tree/master/LEDStripDriver
                          fe
                          All i had to change was
                            Driver.begin();
                            Driver.SetColor(r, g, b);
                            Driver.end();
                          And it worked. Except that fading/RELAX don't work out for me. Instead just get a flashing of white light. So i thought you might know some other parts must be adjusted as my arduino knowledge is not there yer
                          • maghacM maghac
                            Here is the code:
                             * 1.0
                             * 1.1
                            #define SV "1.1"
                            byte red = 255;
                            byte green = 255;
                            byte blue = 255;
                            byte r0 = 255;
                            byte g0 = 255;
                            byte b0 = 255;
                            int fadespeed = 0;
                            #define REDPIN 6
                            #define GREENPIN 5
                            #define BLUEPIN 3
                              // Output pins
                                set_hw_status();
                                send_status();
                              int val;
                                // Save old value
                                red = number >> 16;
                                send_status();
                                set_hw_status();
                                  send_status();
                                  set_hw_status();
                                  dimmerlevel = val;
                                  send_status();
                                  set_hw_status();
                                  fadespeed = val;
                            		return;
                              if (fadespeed >0) {
                                  delay(100);
                              set_rgb(r, g, b);
                              r0 = r;
                              b0 = b;
                              g0 = g;
                            A couple of pics:
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @maghac What board is that?
                            • DrJeffD DrJeff
                              maghacM
                              maghacM
                              maghac
                              @DrJeff That's the Newbie PCB by @sundberg84 (https://www.mysensors.org/hardware/newbie-pcb)
                              DrJeffD 1 Reply Last reply
                              • maghacM maghac
                                DrJeffD
                                DrJeffD
                                DrJeff
                                @maghac Wow! I guess I haven't been around here for a while.
                                • DrJeffD
                                  DrJeffD
                                  DrJeff
                                  @maghac Oh yes by the way the code above works great just added some code for Motion sensor and Now I have a much better light.
                                   * 1.0
                                   * 1.1
                                   * 1.2
                                   *   OTA support
                                   * 1.3
                                   * 1.4
                                   *   Bug fix
                                   * 1.5
                                   * 1.6
                                   *   Repeater feature
                                   * 1.7
                                  #define MY_NODE_ID 31
                                  // added all the motion stuff DrJeff September 10, 2017
                                  #define MOTION_1 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                  #define MOTION_ID 90   // Id of the sensor child
                                  uint8_t lastMotion_1 = 0;
                                  unsigned long previousMillis1 = 0;
                                  unsigned long motionDelay1 = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
                                  #define SV "1.7"
                                  MyMessage motion(MOTION_ID, V_TRIPPED);
                                  int target_r = 255;
                                  int target_g = 255;
                                  int target_b = 255;
                                  int save_r;
                                  int save_g;
                                  int save_b;
                                  int fadespeed = 20;
                                  int fade_step = 0;
                                  int program_timer;
                                  int program_cycle;
                                  #define REDPIN 6
                                  #define GREENPIN 4
                                  #define BLUEPIN 5
                                    {255, 32, 0},
                                    {255, 32, 16},
                                    {255, 16, 32},
                                    {255, 128, 0},
                                    {255, 32, 00},
                                    {255, 32, 32},
                                    {255, 0, 32}
                                    // Output pins
                                    pinMode(MOTION_1, INPUT);
                                    present(MOTION_ID, S_MOTION);
                                  void selftest() {
                                    on_off_status = 1;
                                    current_r = 255;
                                    current_g = 0;
                                    current_b = 0;
                                    set_hw_status();
                                    wait(100);
                                    current_r = 0;
                                    current_g = 255;
                                    set_hw_status();
                                    wait(100);
                                    current_g = 0;
                                    current_b = 255;
                                    set_hw_status();
                                    wait(100);
                                    current_r = 255;
                                    current_g = 255;
                                    set_hw_status();
                                    wait(100);
                                    on_off_status = 0;
                                      selftest();
                                      set_hw_status();
                                      // added all the motion stuff DrJeff September 10, 2017//loop for motion
                                   if(currentMillis - previousMillis1 > motionDelay1)
                                      uint8_t motionDetect1 = digitalRead(MOTION_1);
                                      if(motionDetect1 != lastMotion_1)
                                        Serial.print("Motion 1 = ");
                                        Serial.println(motionDetect1);
                                        //  gw.send(motionStatus_1.set(motionDetect1 ? "1" : "0")); // Send tripped value to gw
                                        send(motion.set(motionDetect1));
                                        if(motionDetect1 == 1)
                                          previousMillis1 = currentMillis;  //"Tripped" delay
                                          previousMillis1 = currentMillis - motionDelay1 + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
                                        lastMotion_1 = motionDetect1;
                                  //end of motion loop
                                      last_update = now;
                                        calc_fade();
                                        handle_program();
                                    set_hw_status();
                                    int val;
                                      // Save old value
                                        dimmerlevel = val;
                                        fadespeed = val;
                                        stop_program();
                                        init_program(val);
                                      return;
                                    program_cycle = 0;
                                    save_rgb();
                                      current_r = 255;
                                      current_g = 255;
                                      current_b = 255;
                                      program_timer = 50;
                                    program_timer--;
                                        program_timer = 50;
                                          program_cycle = 1;
                                          current_r = 0;
                                          current_g = 0;
                                          current_b = 0;
                                          program_cycle = 0;
                                          current_r = 255;
                                          current_g = 255;
                                          current_b = 255;
                                    restore_rgb();
                                  void save_rgb() {
                                    save_r = current_r;
                                    save_g = current_g;
                                    save_b = current_b;
                                    current_r = save_r;
                                    current_g = save_g;
                                    current_b = save_b;
                                    target_r = r;
                                    target_g = g;
                                    target_b = b;
                                    fade_step = t;
                                  void calc_fade() {
                                      fade_step--;
                                    set_rgb(r, g, b);
                                  • mickM
                                    mickM
                                    mick
                                    Hey @maghac - just wondering how you got the 12V to your fitting? have you got a transformer in the ceiling above ? Regards, mick
                                    • mickM mick
                                      maghacM
                                      maghacM
                                      maghac
                                      @mick No, I have a separate 12V cable and a transformer from a regular wall outlet.
                                      mickM 1 Reply Last reply
                                      • maghacM maghac
                                        mickM
                                        mickM
                                        mick
                                        @maghac Thanks for the reply, mate. The light looks great mounted up - very impressed!
                                        • mickM mick
                                          maghacM
                                          maghacM
                                          maghac
                                          @mick said in RGB LED strip:
                                          Thanks! The "relax" program is actually quite nice since it changes colours so slowly so it takes a while before you notice it. A great way to impress your dinner guests :)
