  3. 💬 nRF52832 ESP-LINK Shield for ESP8266 Wemos D1 Mini
25 Posts 6 Posters 5.8k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
      Project completed. :)
        Uploaded sample sketch which demonstrates Serial for testing purposes and which contains instructions on how to set "Reset: Enable" on the nRF52832 module, which allows remote reset of the nRF52832 via ESP-LINK on the ESP8266 using ESP-LINK's console window. :)
        Serial works correctly, even with a baud rate of 460800.
          I just now sent a new version of this board to the fab. The new version has 4 LED's and a separate reset button for the nRF52832. I'll update the files here after I've received and verified the new board.
          • O
            O
            Omemanti
            Did you directly connect to a Controller or do you only use MQTT?
            • O Omemanti
              @omemanti Neither. In this instance, I used ESP-LINK. I gave domoticz its IP address and it was all perfectly and automatically connected via Wi-Fi.
              • O
                O
                Omemanti
                hmz,, I entered the IP address in MYSCONTROLLER but the connection is refuged.(port: 5003, by default.)
                maybe its the controller.
                • O Omemanti
                  @omemanti Domoticz treats it as an ethernet device. Are you hooking it up that way?
                  O 1 Reply Last reply
                    O
                    O
                    Omemanti
                    @neverdie
                    like this.,
                    • O Omemanti
                      @neverdie
                      like this.,
                      @omemanti ESP-LINK uses port 2323 for serial communications. As a check, you could also putty to port 2323 at its IP address, just to verify that your seeing the expected output. The cool thing is that multiple devices can connect to port 2323 at the same time.
                          O
                          O
                          Omemanti
                          Great, Thnx! , 2323 looks great, dont get the the errors :)
                          I still need to test it, but so far, so great.
                          • T
                            Toyman
                            Can you pls. upload the design files?
                            • T Toyman
                              @toyman Done.
                              They had been posted previously. Not sure what happened to them. @hek had a server crash or something?
                                Eh, not that I'm aware of. What files were missing?
                                  @hek All the files except for one gerber file and the PDF schematic.
                                    Hmm.. That's exceptionally strange. I haven't heard of any other project losing uploaded files.
                                    Have you seen anything similar in any of your other projects? Sure you really published them a year back?
                                    • Ikes 72000I
                                      Ikes 72000I
                                      Ikes 72000
                                      I'm new to mysensors, and for tests purpose, i need this gateway.
                                      Wemos works fine with esp-link.
                                      For nrf52832, i use Plateformio ide, and mysensors serial gateway sketch.
                                      //#define MY_RADIO_RF24
                                      #define MY_RADIO_NRF5_ESB
                                      //#define MY_RADIO_RFM95
                                      // Enable serial gateway
                                      #define MY_GATEWAY_SERIAL
                                      // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                                      #if F_CPU == 8000000L
                                      #define MY_BAUD_RATE 38400
                                      // Enable inclusion mode
                                      // Set blinking period
                                      // Flash leds on rx/tx/err
                                      As this, gateway don't work, esp-link don't receive anything.
                                      I think i need to specify witch pins of NRF are used for rx tx, but how doing that ?
                                      Ikes
                                      • Ikes 72000I Ikes 72000
                                        Ikes
                                        @Ikes-72000 You can define pin mappings in the MyNRF5Board.h file.
                                        #define PIN_SERIAL_RX       (8)
                                        #define PIN_SERIAL_TX       (6)
                                        as illustrated in the posted demo code. The demo code "just works" for this hardware configuration, so I suggest you start with the demo code and confirm that it's working on your instance of the hardware before moving on with other code. That's how Adafruit and Sparkfun do it with their breakout boards as well.
                                        If you're looking to get an idea of how to integrate it with mySensors in some other manner, you might have a look at:
                                        https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel
                                        Ikes 72000I 1 Reply Last reply
                                          Ikes 72000I
                                          Ikes 72000I
                                          Ikes 72000
                                          @NeverDie , thanks, but unfortunately this doesn't work.
                                          Sketch i upload to nrf:
                                          #include <nrf.h>
                                            Serial.begin(460800);
                                            Serial.println();
                                            Serial.println("Countdown 3...");
                                            Serial.flush();
                                            delay(100);
                                            Serial.println("Countdown 2...");
                                            Serial.flush();
                                            delay(100);
                                            Serial.println("Countdown 1...");
                                            Serial.flush();
                                            delay(100);
                                            Serial.flush();
                                            delay(100);
                                          uint32_t loopCounter=0;
                                            Serial.println(loopCounter++);
                                            Serial.flush();
                                          Log:
                                          c:/users/ikes/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 4 bytes
                                          c:/users/ikes/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
                                          c:/users/ikes/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
                                          Le croquis utilise 22984 octets (4%) de l'espace de stockage de programmes. Le maximum est de 524288 octets.
                                          Target voltage: 3.73V
                                          Remote debugging using \\.\COM6
                                          Available Targets:
                                          No. Att Driver
                                           1      Nordic nRF52 M3/M4
                                           2      Nordic nRF52 Access Port
                                          Attaching to Remote target
                                          0x000009c4 in ?? ()
                                          Reading symbols from MyBoardNRF5.ino.elf...done.
                                          Loading section .text, size 0x59c8 lma 0x0
                                          Loading section .ARM.exidx, size 0x8 lma 0x59c8
                                          Loading section .data, size 0xbc lma 0x59d0
                                          Start address 0x1410, load size 23180
                                          Transfer rate: 39 KB/sec, 891 bytes/write.
                                          Temporary breakpoint 1 at 0x1370: file G:\Documents\Arduino\libraries\MySensors/hal/architecture/NRF5/MyMainNRF5.cpp, line 23.
                                          Starting program: C:\Users\Ikes\AppData\Local\Temp\arduino_build_693731\MyBoardNRF5.ino.elf
                                          Note: automatically using hardware breakpoints for read-only addresses.
                                          Temporary breakpoint 1, main ()
                                              at G:\Documents\Arduino\libraries\MySensors/hal/architecture/NRF5/MyMainNRF5.cpp:23
                                          23	{
                                          Program complete!
                                          Don't see anything in esp-link console.
