  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
    @gohan said in Powering mote 24/7 using only a supercap and solar:
    If anyone interested for some ideas of supercaps protection https://youtu.be/NsTAyD2i3rc
    Useful video if connecting capacitors in series. If using just one capacitor, though, I wonder whether there's any advantage to using the described shunt regulator circuit compared to simply using a 2.7v LDO voltage regulator?
    By the way, if your supercap's will be in a higher than room temperature environment, you may have to de-rate their max voltage. In general, supercaps won't last as long at high temperatures. Worth checking the datasheet for the details if that's a possible concern.
    E
    E
    Ed1500
    @NeverDie The unforgettable "guy with the swiss accent" videos :-)
    Though very useful information, not so applicable to me as I am using 5,5V capacitors on a regulated 3V3 line
      #217
      I think the Swiss guy presents an interesting notion, and it's worth watching for that. However, I think his part choice of the TL431 is a poor fit for my solar application. According to the datasheet (cf page 6 of http://www.ti.com/lit/ds/symlink/tl431a.pdf), the minimum cathod current required for regulation is between 0.4ma and 1ma. From indoors, that's generally more current than I'm receiving from the solar panel! Now, double that, because you'll need two of them.
      Also, it can't handle very high currents either, which is, I presume, why the Swiss guy resorts to the transistorized circuit and/or the chinese supercap protector PCB circuit.
      HOWEVER, I notice that TI has a more recent successor to the TL431, called the ATL431, which appears to address both of those shortcomings: http://www.ti.com/lit/ds/symlink/atl431.pdf
      Also, the ATL431 price would be much less than the Chinese transistor supercap protector board. The ATL431 price is about 58 cents, quantity 1 (http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=229180358&uq=636316574771858018)
      E 1 Reply Last reply
        E
        E
        Ed1500
        @NeverDie Oh that is good to know, thanks
          Has anyone seen this solution for balancing the supercaps?
          https://www.youtube.com/watch?v=rWN7YOuhcO0
            #220
            @gohan
            Sounds better than the Andreas Speiss method. Thanks for posting it!
              Has anyone figured out how to do use this chip?
                #222
                I haven't pursued it, because I haven't heard a strong argument as to why two or more supercaps are better than one for powering a mote. The economics of supercaps seems to favor a one supercap solution.
                  Well it is all related to what voltage you need to store I'd say: if you need to use more than the standard 2.7v you need more caps in series (for example if you want to make a 12v pack for your car)
                    #224
                    @gohan
                    Well, if you need more than 400F... maybe then. I'm sure there's a crossover point somwhere if the storage requirements get high enough. At that point, though, it would seem you're doing much more than powering a sensor mote.
                    Anyhow, I look forward to seeing what you come up with. Maybe you've found an interesting use-case that I haven't even considered.
                      not for near future... I am still preparing a bunch of other things :D
                        #226
                        I notice Julian Ilett seems to enjoy playing around with these 700F supercapacitors:
                        https://www.youtube.com/watch?v=B8T9KR3b-RM
                        Ebay seems to have the lowest price: https://www.ebay.com/itm/1pcs-2-5V-700F-Automobile-Super-Farad-Capacitance-NEW-L85/262714791208?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                        Anyone here tried them? I'm curious as to their self-discharge rate when they're not being charged.
                          #227
                          Also, although I'm doubtful about the brand, these 500F supercaps might be interesting because they're relatively inexpensive:
                          https://www.aliexpress.com/item/1PCS-AMS1117-5-0-DC-DC-Step-Down-Voltage-Regulator-Adapter-Convertor/32328707306.html?spm=a2g0s.13010208.99999999.269.QVr0W1
                          alexsh1A 1 Reply Last reply
                            so far what I saw is that good branded supercaps have much better self discharge compared to the cheap ones
                              Am noticing that on Aliexpress you can now get an entire LTC3558 board for about the same price as just the ltc3558 chip on digikey.
                              https://www.aliexpress.com/item/GY-LTC3588-LTC3588-Energy-Harvester-Breakout-LTC-3588-Energy-Harvest-Collector/32755828984.html?spm=a2g0s.13010208.99999999.277.HJ7HHP
                              So, for low light energy harvesting, it might be interesting.
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @neverdie I think the size is a killer for me. I watched Julian's video and also remember this one:
                                https://www.youtube.com/watch?v=gzaLF5tFf88
                                Great caps and the price is really good too.
                                • alexsh1A alexsh1
                                  #231
                                  @alexsh1 I purchased one of the 700F supercaps after my prior post just to see, and sure enough it has a pretty terrible self-discharge rate: about 0.4-5v per day. With a boost converter, maybe it would be good for powering an LED garden light at night.... Not sure what else it might be good for.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @neverdie That's really bad - 0.5V a day. Questionable quality I guess?
                                    I can see that similar capacitor AVX branded is much more expensive:
                                    http://uk.farnell.com/avx/sccy1kb707plble/super-cap-700f-2-7v-weldable-pin/dp/2856928?st=700F
                                    Prices are coming down gradually. I suppose soon enough we may see AVX priced more affordably.
                                      Cypress Semiconductor has an interesting energy harvesting chip intended for wireless nodes:
                                      http://www.cypress.com/file/219311/download
                                      The chip looks a little easier to solder than some of them.
                                        https://www.openhardware.io/view/620/Supercap-Solar-Charger
                                          @neverdie said in Powering mote 24/7 using only a supercap and solar:
                                          I charged up this supercap 5 months ago and then set it aside. Checking it now, it still has 0.6v left on it. I thought it would be at zero! So, maybe it really did hold a useful charge for much longer than I thought....(?)
