  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
    @Ed1500 I got the bigger brother of that one. Look at the workshop discussion. I can't wait to start testing this stuff with all the voltage regulators I got and see how much energy I can actually store in the same 2 caps both in series and parallel
    @gohan said in Powering mote 24/7 using only a supercap and solar:
    Uh, what workshop discussion would that be?
      https://forum.mysensors.org/topic/229/your-workshop
        #211
        Well, after much digging, I think I finally found your post. Is this what you're referring to?
        https://www.banggood.com/DANIU-3_5inch-Colorful-Display-Multi-functional-TFT-Backlight-Transistor-Tester-p-1083042.html?p=9825091683131201505R
        Is it better than the one I posted?
        I'm thinking of possibly getting one of these:
        http://www.ebay.com/itm/261114892135
        if only because the company that makes it also makes a popular low budget signal generator.
        I don't know that I actually need it though, except to verify that stuff purchased from Aliexpress actually is what it purports to be. :grinning:
          Actually I went for the 2017 version on aliexpress that also has a pulse generator
            If anyone interested for some ideas of supercaps protection https://youtu.be/NsTAyD2i3rc
              #214
              Useful video if connecting capacitors in series. If using just one capacitor, though, I wonder whether there's any advantage to using the described shunt regulator circuit compared to simply using a 2.7v LDO voltage regulator?
              By the way, if your supercap's will be in a higher than room temperature environment, you may have to de-rate their max voltage. In general, supercaps won't last as long at high temperatures. Worth checking the datasheet for the details if that's a possible concern.
              E 1 Reply Last reply
                I'll experiment when I'll get the small adjustable dc-dc converters and see how they go.
                  E
                  E
                  Ed1500
                  @NeverDie The unforgettable "guy with the swiss accent" videos :-)
                  Though very useful information, not so applicable to me as I am using 5,5V capacitors on a regulated 3V3 line
                    #217
                    I think the Swiss guy presents an interesting notion, and it's worth watching for that. However, I think his part choice of the TL431 is a poor fit for my solar application. According to the datasheet (cf page 6 of http://www.ti.com/lit/ds/symlink/tl431a.pdf), the minimum cathod current required for regulation is between 0.4ma and 1ma. From indoors, that's generally more current than I'm receiving from the solar panel! Now, double that, because you'll need two of them.
                    Also, it can't handle very high currents either, which is, I presume, why the Swiss guy resorts to the transistorized circuit and/or the chinese supercap protector PCB circuit.
                    HOWEVER, I notice that TI has a more recent successor to the TL431, called the ATL431, which appears to address both of those shortcomings: http://www.ti.com/lit/ds/symlink/atl431.pdf
                    Also, the ATL431 price would be much less than the Chinese transistor supercap protector board. The ATL431 price is about 58 cents, quantity 1 (http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=229180358&uq=636316574771858018)
                      E
                      E
                      Ed1500
                      @NeverDie Oh that is good to know, thanks
                        Has anyone seen this solution for balancing the supercaps?
                        https://www.youtube.com/watch?v=rWN7YOuhcO0
                          #220
                          @gohan
                          Sounds better than the Andreas Speiss method. Thanks for posting it!
                            Has anyone figured out how to do use this chip?
                              #222
                              I haven't pursued it, because I haven't heard a strong argument as to why two or more supercaps are better than one for powering a mote. The economics of supercaps seems to favor a one supercap solution.
                                Well it is all related to what voltage you need to store I'd say: if you need to use more than the standard 2.7v you need more caps in series (for example if you want to make a 12v pack for your car)
                                  #224
                                  @gohan
                                  Well, if you need more than 400F... maybe then. I'm sure there's a crossover point somwhere if the storage requirements get high enough. At that point, though, it would seem you're doing much more than powering a sensor mote.
                                  Anyhow, I look forward to seeing what you come up with. Maybe you've found an interesting use-case that I haven't even considered.
                                    not for near future... I am still preparing a bunch of other things :D
                                      #226
                                      I notice Julian Ilett seems to enjoy playing around with these 700F supercapacitors:
                                      https://www.youtube.com/watch?v=B8T9KR3b-RM
                                      Ebay seems to have the lowest price: https://www.ebay.com/itm/1pcs-2-5V-700F-Automobile-Super-Farad-Capacitance-NEW-L85/262714791208?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                                      Anyone here tried them? I'm curious as to their self-discharge rate when they're not being charged.
                                        #227
                                        Also, although I'm doubtful about the brand, these 500F supercaps might be interesting because they're relatively inexpensive:
                                        https://www.aliexpress.com/item/1PCS-AMS1117-5-0-DC-DC-Step-Down-Voltage-Regulator-Adapter-Convertor/32328707306.html?spm=a2g0s.13010208.99999999.269.QVr0W1
                                        alexsh1A 1 Reply Last reply
                                          so far what I saw is that good branded supercaps have much better self discharge compared to the cheap ones
