  3. [SOLVED] Problems with ESP8266 and NRF24L01+
24 Posts 5 Posters 20.4k Views 5 Watching
  • sundberg84S sundberg84
    @numanx said in Problems with ESP8266 and NRF24L01+:
    separately from a 5V PSU with the 5V regulator
    You mean 3.3v adapter? The ESP is not compatible with 5v.
    Do you use the NodeMCU as described in the build section or another device? I know the pinout can be a bit tricky...
    numanxN
    numanxN
    numanx
    @sundberg84
    The ESP8266 was running from my PC using a usb cable.
    I've tried to power the NRF24L01+ from the ESP8266 directly with dupont cable also I've tried through the Socket adapter plate board. I've tried to power the NRF24L01+ from a 5V power supply. The NRF24L01+ ground was common with the ESP8266 ground and the VCC on the adapter(which pass through the 5V to 3.3V regulator and then to NRF24L01+) was connected from the 5V power supply.
    I am using the NodeMCU as described in the following link https://www.mysensors.org/build/connect_radio#nrf24l01+-&-esp8266
    • numanxN numanx
      @sundberg84
      sundberg84S
      sundberg84S
      @numanx - good, then the nodeMCU regulated the voltage to 3.3v internaly if you power it through the USB.
      Make sure you power the radio with 3.3v as well... the radio cant handle 5v. Use 3V3 from the nodeMCU.
      !TSM:INIT:TSP FAIL
      This means the radio cant initialize.
      Either its wrong wired, got the wrong power or its a bad radio.
      numanxN 1 Reply Last reply
      • numanxN numanx
        I have a problem using an ESP8266 and a NRF24L01+ module.
        I followed all the steps from this guide https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help and still it won't work.
        I am using an adapter like this https://www.aliexpress.com/item/5pcs-Socket-Adapter-Module-Board-for-NRF24L01-Wireless-Module/32368381876.html for converting the power and for power stability.
        I have two NRF24L01+ modules and I've tested them with an Arduino Nano which it works.
        I can't get it to work with ESP8266, I've checked the wirings multiple times.
        Arduino IDE 1.6.8 with latest version of MySensors Library on Linux and Mac OS X using an ESP8266 and NRF24L01+
        I've tried to power the module directly from ESP8266 and separately from a 5V PSU with the 5V regulator adapter and common ground with the ESP8266.
        Thanks for your help!
        This is the serial monitor error:
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:FAIL:CNT=7
        0;255;3;0;9;TSM:FAIL:PDT
        0;255;3;0;9;TSM:FAIL:RE-INIT```
        @numanx
        Make sure you wire not to MOSI, etc., but to HMOSI, etc.
          !TSM:INIT:TSP FAIL
          numanxN
          numanxN
          numanx
          @sundberg84 @NeverDie
          Thanks for your answers.
          I've connected the ESP8266 and NRF24L01+ exactly as described in Connecting the Radio(https://www.mysensors.org/build/connect_radio) at the NRF24L01+ & ESP8266 section.
          Still the same error, I've tried rewiring a couple of times using different wires.
            Which board did you pick beneath the board manager?
            • numanxN numanx
              @numanx
              Also, what voltage are you supplying the socket adapter with? If you're supplying it with 3.3v, then that may be your problem. Supply it with 5v instead. It has a voltage regulator to reduce the voltage to 3.3v, but if you feed it with 3.3v instead, it maybe isn't producing enough regulated voltage.
              • mfalkviddM
                How about skipping the adapter, at least temporarily to check whether the radio works without it. That would eliminate one possible problem source.
                  numanxN
                  numanxN
                  numanx
                  The board selected is NodeMCU 1.0 (ESP-12E module)
                  I've tried suplying the adapter with 3.3v and also with 5V.
                  @mfalkvidd
                  Now the radio is connected directly to the ESP8266 but still I have the same error.
                    At this point, it becomes 20 questions unless you post detailed photos of exactly what you've done. Either your hardware is defective or you've made an error that you can't see by yourself.
                    If all else fails, you can try this instead:
                    https://www.openhardware.io/view/442/Small-nRF24L01-Shield-for-ESP8266-Wemos-D1-Mini
                    It's not nodemcu, but it is ESP8266. It does the "wiring" for you. And it works.
                    • numanxN
                      numanxN
                      numanx
                      Now I have another problem...
                      I've tried to change the Wireless SSID and Password in the sketch and it seems that after uploading on the ESP8266 it doesn't update them. I've tried clearing EEPROM memory and now the ESP8266 seems to be stucked in the AP mode and I have some strange characters when I open Serial Monitor...
                      0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGE--,VER=2.1.1
                      0;255;3;0;9;TSF:LRT:OK
                      0;255;3;0;9;TSF:WUR:MS=0
                      0;255;3;0;9;TSM:FAIL:CNT=1
                      chg_A2:-40
                      • numanxN
                        numanxN
                        numanx
                        Ok, I've solved the problem with the Wireless SSID and password by uploading the HelloServer sketch from the ESP8266 examples.
                        Now I rewire the ESP8266 and Radio and I will post some photos.
                        • numanxN
                          numanxN
                          numanx
                          wrote on last edited by numanx
                          Here are the photos of the ESP8266 board, NR24L01+ and the wiring.
                          1_1502911770672_IMG_1597.JPG 0_1502911770672_IMG_1596.JPG 0_1502911837444_IMG_1594.JPG 0_1502911797701_IMG_1592.JPG 0_1502911843654_IMG_1595.JPG
                          • numanxN
                            numanxN
                            numanx
                              It's hard to tell from your photos what is wired to what.
                              Suggest you upgrade to the current Arduino IDE and verify that you have the most current NodeMCU board definition installed. Also confirm that you're using the latest release of the Mysensors library.
                              Have you verified that your hardware is working? e.g. try the radio module in a different "known good" platform and see if it runs correctly. On the NodeMCU, try driving something else that has a SPI interface and confirm that it works properly.
                              If all of the above checks out, then I would think the next step would be to use a logic probe to see if you're getting the proper signals sent between your NodeMCU and the nRF24L01 module. If not, maybe you need to add a pull-up or a pull-down resistor on one of the datalines. The logic probe would tell the tale.
                              • numanxN
                                numanxN
                                numanx
                                Finally got it!
                                It seems that I have a problem with the ESP8266.
                                After about 24 Hours of debugging I found the problem...
                                Steps:
                                Checked if the wiring is good with a multimeter probe on each pin of the adapter(which I know it worked) and each pin of the radio to verify the correct pinout.
                                It seems that the pinout was ok and the wiring was also ok.
                                Write a sketch with all the ports from D2 to D8 in output HIGH and with a little buzzer I've tested each pin.
                                It seems that D7 doesn't give voltage.
                                Checked the pinout diagram for the ESP-12E. Checked for continuity between GPIO13(from the chip) and D7 and there was no continuity.
                                Tried to connect the radio MOSI Pin directly to GPIO13 and IT WORKED!
                                0;255;3;0;9;TSM:INIT:TSP OK
                                0;255;3;0;9;TSM:INIT:GW MODE
                                Is there any way to move the MOSI pin from the board to another digital pin from ESP8266?
                                mfalkviddM NeverDieN 2 Replies Last reply
                                • numanxN numanx
                                  Finally got it!
                                  Steps:
                                  Great work @numanx !
                                  It is possible to use software spi instead of hardware spi (hardware spi only works with the default pins). See https://www.mysensors.org/build/ethernet_gateway for how to enable software spi and use #define directives to use different pins.
                                  • numanxN numanx
                                    Finally got it!
                                    Steps:
                                    Good work!
                                    Check the solder connection between the GPIO13 and the pcb. Probably it's faulty. With a little luck probably you can just re-solder the connection manually, and `then you'll be good to go.
                                      numanxN
                                      numanxN
                                      numanx
                                      @mfalkvidd
                                      It seems that ESP8266 doesn't support SOFTSPI
                                      In file included from /home/numanx/Arduino/ESP8266OTA/ESP8266OTA.ino:120:0:
                                      /home/andreihering/Arduino/libraries/MySensors/MySensors.h:248:2: error: #error Soft SPI is not available on ESP8266
                                      • numanxN numanx
                                        @mfalkvidd
                                        @numanx oh. Sorry. My bad.
                                          Good work!
                                          numanxN
                                          numanxN
                                          numanx
                                          @NeverDie @mfalkvidd
                                          Today I've resoldered the ESP8266 Chip.
                                          Everything works perfect.
