  3. loungeroom sketch transport failure
18 Posts 4 Posters 4.6k Views 3 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    hi all
    using
    mysensors 2.1.1
    get the following log
    4 TSM:INIT
    4 TSF:WUR:MS=0
    10 !TSM:INIT:TSP FAIL
    14 TSM:FAIL:CNT=1
    14 TSM:FAIL:PDT
    10018 TSM:FAIL:RE-INIT
    10020 TSM:INIT
    10027 !TSM:INIT:TSP FAIL
    10031 TSM:FAIL:CNT=2
    10033 TSM:FAIL:PDT
    transport failure...not really sure what that is, and posts show it being many different things
    this is my code
    i know i must have something wrong, but i cant work it out.... any help is appreciated
    // Enable debug prints
    #define MY_NODE_ID 4
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define HUMIDITY_SENSOR_DIGITAL_PIN 6
    #define LIGHT_SENSOR_ANALOG_PIN A1
    unsigned long SLEEP_TIME = 120000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "loungeroom living sensor #1"        // Change to a fancy name you like
    #define SKETCH_VERSION "1"                    // Your version
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int LightLevel = 0;
    int lastLightLevel;
    MyMessage LightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      present(CHILD_ID_HUM, S_HUM);
      if (isnan(temperature)) {
        lastTemp = temperature;
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          send(LightMsg.set(lightLevel));
          lastLightLevel = lightLevel;
      batM();
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       if (batLoop > 2) {
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           batLoop = 0;
         batLoop++;
    • rejoe2R
      rejoe2R
      rejoe2
      Did you already follow the procedures described here: https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
      • Nca78N
        Transport init fail = the Arduino didn't manage to communicate with the radio.
        Check the wiring and power source of the radio.
        • markjgabbM
          markjgabbM
          markjgabb
          god i need new glasses...back to fornt capacitor on the antenna module....
          ok thanks guys...that parts resolved, now just gotta go though no parent found part....other devices in the same location works, just not this one...time to start swapping capacitors
          • markjgabbM markjgabb
            sundberg84S
            sundberg84S
            @markjgabb - no reply means the node can't find its way to the radio. Just as you are saying look over that you have all the right capacitors. Sometimes you need a 47uF capacitor instead of the 4,7uF on the radio. (Sometimes you need to try different ones).
            How do you power the node?
            • markjgabbM
              markjgabbM
              markjgabb
              its battery powered, i have the jumpers, i just got registration on node....but not all sensors are sending data....
              @sundberg84 would it be possible for you to review the below code....have i missed something?
              unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
              DHT dht;
              float lastTemp;
              float lastHum;
              int LightLevel = 0;
              int lastLightLevel;
                    lastHum = humidity;
                batM();
                 delay(500);
                 delay(500);
                 if (batLoop > 2) {
                   batteryPcnt=100;
                     batLoop = 0;
                   batLoop++;
                DHT dht;
                float lastTemp;
                float lastHum;
                int LightLevel = 0;
                int lastLightLevel;
                      lastHum = humidity;
                  batM();
                   delay(500);
                   delay(500);
                   if (batLoop > 2) {
                     batteryPcnt=100;
                       batLoop = 0;
                     batLoop++;
                sundberg84S
                sundberg84S
                @markjgabb said in loungeroom sketch transport failure:
                This means it will only send if the value is changed... could that be the cause?
                Any logs from the node? Ack ok?
                • markjgabbM
                  markjgabbM
                  markjgabb
                  wrote on last edited by markjgabb
                  7778 MCO:SLP:WUP=-1
                  9306 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.0
                  T: 20.00
                  9316 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:18.0
                  H: 18.00
                  Battery percent: -89 %
                  10326 MCO:SLP:MS=120000,SMS=0,I1=255,M1=255,I2=255,M2=255
                  10332 MCO:SLP:TPD
                  this is my current log....
                  so temp and hum is wrking...but my lux level keeps coming back 0 i think thats what its saying....can i insert more logging on that one to see how its doing the math?
                    7778 MCO:SLP:WUP=-1
                    T: 20.00
                    H: 18.00
                    10332 MCO:SLP:TPD
                    sundberg84S
                    sundberg84S
                    @markjgabb - ok, communication looks good! Great!
                    It looks like you are not getting anything out of the sensor. Is it powered? Did you connect it to analog output? (Some sensors have both digital and analog out).
                    There is not much else to log.
                    You could do: Serial.println(LIGHT_SENSOR_ANALOG_PIN); to see the raw value (should be 0-1v). on the analog input.
                    You can also measure the voltage coming on the analog output pin on the sensor and see.
                    The battery measurment looks strange though... negative 89? :)
                    • markjgabbM
                      markjgabbM
                      markjgabb
                      ok raw lux is 15
                      good point...ive used a 47k resistor instead of a 470k, ill change that in the morning
                      Raw Lux: 15
                      send Lux: 0
                      obviously a sensor error, ive moved the photo resistor into diffrent light like 4 times, and no change in reading
                        ok raw lux is 15
                        Raw Lux: 15
                        send Lux: 0
                        sundberg84S
                        sundberg84S
                        @markjgabb - if you can confirm that with a multimeter, its defenetly a error in the sensor... but verify because it can be a fault in the pro mini hardware/software as well.
                        Raw lux (Serial.println(LIGHT_SENSOR_ANALOG_PIN);) should be between value 0 and 1023.
                        I probably wrote wrong above though... if you are using a 5v pro mini, the input voltage range should be 0 to 5 volts
                        • markjgabbM
                          markjgabbM
                          markjgabb
                          nah its a 3.3 pro mini
                          back
                          • markjgabbM
                            markjgabbM
                            markjgabb
                            photo resistor is now working...domoticz is showing varied amounts of reading though the night and morning....
                            but its back to front....
                            its reads 90ish in the middle of the night and this morning fluxuated between 50-10 and is now sitting at 30 with an empty house......did i math backwards? or is this expected behaviour due to the way the resistance works?
                            in domoticz would i just use low values as my brightness
                            Nca78N 1 Reply Last reply
                              Resistance gets lower when you have light. So higher when you have no light, meaning you have higher voltage when you measure voltage across the photoresistor.
                              • Nca78N Nca78
                                sundberg84S
                                sundberg84S
                                @Nca78 - what kind of sensor are you using? Or just a single photoresistor as Nca78 suggested?
                                • markjgabbM
                                  markjgabbM
                                  markjgabb
                                  just a single photoresistor,
                                  i just wasnt sure if there was a way to reverse map the numbers so that if it says 1 it sends 99
                                    sundberg84S
                                    sundberg84S
                                    @markjgabb - a single photoresistor can be extremly sensitive, ie 0 to full in a small change in light. There are alot of guides out there, just google around.
                                    • markjgabbM
                                      markjgabbM
                                      markjgabb
                                      @sundberg84 solved the light sensitivity level by swapping the 10k for a 100k...
                                      makes it more acurate in lighter enviroments, but less so in dark enviroments
                                      but by my theory after its a little dim im counting it as dark all the way to full dark for lighting purposes anyway
                                      cheers for all your help....
