  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
    @Dick thanks. The node still doesn't send any values so that's why it does not show up in Domoticz.
    My next step would be to manually add serial debug prints at end of setup(), presentation(), and almost everywhere in loop(), to see why it doesn't attempt to send.
    DickD
    DickD
    Dick
    I put some deug lines i it and after uploadig the sketch it stops here (wait conversationtime.)
    setup done.
    2191 MCO:BGN:INIT OK,TSP=1
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    • DickD Dick
      setup done.
      fetch sensors.
      fetch sensors.
      fetch sensors.
      fetch sensors.
      fetch sensors.
      fetch sensors.
      fetch sensors.
      #109
      @Dick could you try printing the value of numSensors in presentation()? (or in loop, it should have the same value there)
      DickD 1 Reply Last reply
        DickD
        DickD
        Dick
        @mfalkvidd how can I manage that? sorr for the perhaps stupid qestion?
        • DickD Dick
          @Dick
          Serial.print("Number of attached sensors found by the DallasTemperature library: ");
          Serial.println(numSensors);
          rejoe2R DickD 2 Replies Last reply
            @Dick
            rejoe2R
            rejoe2R
            rejoe2
            @Dick best place would be after numSensors = ... in presentation()
            Just to mention that: The Arduino I used already had a node ID (I usually assign it manually). But your problem seems to be something completely different.
              @Dick
              DickD
              DickD
              Dick
              @mfalkvidd I tried it in Presentation() and in Loop() inboth no results in the log (copied it as you advised me how to do. so no result bisible). it is getting complex I think!
              6 TSM:INIT
              7 TSF:WUR:MS=0
              14 TSM:INIT:TSP OK
              16 TSF:SID:OK,ID=12
              17 TSM:FPAR
              59 TSF:MSG:SEND,12-12-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              452 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              457 TSF:MSG:FPAR OK,ID=0,D=1
              561 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              2066 TSM:FPAR:OK
              2067 TSM:ID
              2068 TSM:ID:OK
              2070 TSM:UPL
              2074 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2086 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2092 TSF:MSG:PONG RECV,HP=1
              2094 TSM:UPL:OK
              2096 TSM:READY:ID=12,PAR=0,DIS=1
              2101 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2110 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2118 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              2127 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2142 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              2151 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
              2161 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
              2168 MCO:REG:REQ
              2172 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              2181 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2186 MCO:PIM:NODE REG=1
              2189 MCO:BGN:STP
              setup done.
              2190 MCO:BGN:INIT OK,TSP=1
              fetch sensors.
              fetch sensors.
              fetch sensors.
              • rejoe2R
                rejoe2R
                rejoe2
                How are your sensors wired? Parasitic or 3 wires?
                Sounds like a broken sensor, wrong wiring or a lot of sensors (to much for the pullup used).
                • mfalkviddM
                  Ok. I give up. If the node isn't executing the serial prints I know no way of troubleshooting.
                    DickD
                    DickD
                    Dick
                    @mfalkvidd I ony can tell "thanksfo the support ad you time" . Have a nice wekend!!!
                    • skywatchS
                      skywatchS
                      skywatch
                      I have been frustrated with this for weeks now. Today I notice that void loop is not closed with a curly brace and if I add one it does not compile.
                      So what black magic is going on here?
                      I have been trying to get sensor readings every 2 mins and battery every half hour. But whatever I try it still gives temp every minute and battery at once a minute too. No wonder my batteries are draining so fast.
                      • skywatchS skywatch
                        @skywatch the curly braces were discussed and explained earlier in this thread.
                        Could you post your sketch and the debug output of your node?
                        • skywatchS
                          skywatchS
                          skywatch
                          @mfalkvidd
                          Thanks for fast reply! See code below. If you don't see problem there I will debug tomorrow. The battery time is set for 90sec to test, but is taking 18mins between sends!
                          #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
                          #define MAX_ATTACHED_DS18B20 3
                          #include <OneWire.h>
                          int batteryPcnt = 0;
                          unsigned long SLEEP_TIME = 117000; // Sleep time between reads (in milliseconds)
                          int numSensors = 0;
                          const long interval = 90000;
                          unsigned long previousMillis = 0;
                          bool receivedConfig = false;
                          bool metric = true;
                          MyMessage msg(0, V_TEMP);
                          void before()
                            sensors.begin();
                            analogReference(INTERNAL);
                            sendSketchInfo("HW/CH", "0.4");
                            for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                              present(i, S_TEMP);
                            // get the battery Voltage
                            if (currentMillis - previousMillis >= interval) {
                              batteryPcnt = sensorValue / 10;
                            sleep(conversionTime);
                              float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                          #if COMPARE_TEMP == 1
                                send(msg.setSensor(i).set(temperature, 1));
                                lastTemperature[i] = temperature;
                            int8_t sleep(1, FALLING, SLEEP_TIME);
                            @mfalkvidd
                            int numSensors = 0;
                            bool metric = true;
                            void before()
                              sensors.begin();
                                present(i, S_TEMP);
                            #120
                            @skywatch doing what you want is a bit hard since millis won't update while the node is in power save mode (sleeping). But this should do it:
                            set SLEEP_TIME = 2 * 60 * 1000 // 2 minutes
                            and change
                            to
                            unsigned int batteryReportFactor = 30*60*1000ul/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
                            unsigned int timesSlept = 0;
                              if (timesSlept < batteryReportFactor) {
                                timesSlept++;
                                timesSlept = 0;
                            I don't understand why you're using interrupt to sleep though.
                            skywatchS 1 Reply Last reply
                              and change
                              to
                                  timesSlept++;
                                  timesSlept = 0;
                              skywatchS
                              skywatchS
                              skywatch
                              #121
                              @mfalkvidd said in 💬 Temperature Sensor:
                              Thank you very much for helping out with this! - I will try it today if I can. I guess I could use the same principle to send sensor data every 2 minutes instead of every 1 minute and further reduce battery draw. I know the DS18B20 sensors are correctly going into sleep mode, but the node itself is still using too much juice.
                              There is nothing in the API about this, would be nice if it were added as I don't think I will be the only person with such requirements. Also, what does sleep actually do and are there further things I could do to reduce the power use?
                              That is because I haven't finished this node yet.... I am working on it systematically and in future a water leak detector will be added. But only when this part is working correctly and I have good battery life from the node.
                                #122
                                @skywatch said in 💬 Temperature Sensor:
                                Good point. I have added a note on https://www.mysensors.org/download/sensor_api_20#sleeping
                                It does a lot of things, but basically it puts the radio and the Arduino in power save mode and uses the Arduino's watchdog timer to roughly keep track of time (exact timing is not possible because exact timing requires power, and power save mode is all about saving power).
                                https://www.mysensors.org/build/battery has the official MySensors recommendations on how to save power in battery-operated nodes.
                                If you want to dive deeper, start with https://www.gammon.com.au/power
                                  I'd use the sleep time to 2 minutes and then simply set a counter that every 15 loops of the code sends battery status and resets the counter. Imho 2 minutes are quite often for battery life.
                                    @gohan wasn't that what I did?
                                    gohanG 1 Reply Last reply
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      This can't be right, can it???
                                      (http://imagebucket.net/7mtp8rcnqss2/BattGraph.jpg)
                                        @mfalkvidd I'm on mobile, I didn't read the code 😇
                                          @skywatch it looks normal. The precision is probably 1% and the real value close to 100.5%, so sometimes it will be rounded to 101% and sometimes to 100%.
