  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • skywatchS
    skywatchS
    skywatch
    I have been frustrated with this for weeks now. Today I notice that void loop is not closed with a curly brace and if I add one it does not compile.
    So what black magic is going on here?
    I have been trying to get sensor readings every 2 mins and battery every half hour. But whatever I try it still gives temp every minute and battery at once a minute too. No wonder my batteries are draining so fast.
    • skywatchS skywatch
      @skywatch the curly braces were discussed and explained earlier in this thread.
      Could you post your sketch and the debug output of your node?
      • skywatchS
        skywatchS
        skywatch
        @mfalkvidd
        Thanks for fast reply! See code below. If you don't see problem there I will debug tomorrow. The battery time is set for 90sec to test, but is taking 18mins between sends!
        #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
        #define MAX_ATTACHED_DS18B20 3
        #include <OneWire.h>
        int batteryPcnt = 0;
        unsigned long SLEEP_TIME = 117000; // Sleep time between reads (in milliseconds)
        int numSensors = 0;
        const long interval = 90000;
        unsigned long previousMillis = 0;
        bool receivedConfig = false;
        bool metric = true;
        MyMessage msg(0, V_TEMP);
        void before()
          sensors.begin();
          analogReference(INTERNAL);
          sendSketchInfo("HW/CH", "0.4");
          for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
            present(i, S_TEMP);
          // get the battery Voltage
          if (currentMillis - previousMillis >= interval) {
            batteryPcnt = sensorValue / 10;
          sleep(conversionTime);
            float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
              send(msg.setSensor(i).set(temperature, 1));
              lastTemperature[i] = temperature;
          int8_t sleep(1, FALLING, SLEEP_TIME);
          @mfalkvidd
          int numSensors = 0;
          bool metric = true;
          void before()
            sensors.begin();
              present(i, S_TEMP);
          #120
          @skywatch doing what you want is a bit hard since millis won't update while the node is in power save mode (sleeping). But this should do it:
          set SLEEP_TIME = 2 * 60 * 1000 // 2 minutes
          and change
          to
          unsigned int batteryReportFactor = 30*60*1000ul/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
          unsigned int timesSlept = 0;
            if (timesSlept < batteryReportFactor) {
              timesSlept++;
              timesSlept = 0;
          I don't understand why you're using interrupt to sleep though.
          skywatchS 1 Reply Last reply
            and change
            to
                timesSlept++;
                timesSlept = 0;
            skywatchS
            skywatchS
            skywatch
            #121
            @mfalkvidd said in 💬 Temperature Sensor:
            Thank you very much for helping out with this! - I will try it today if I can. I guess I could use the same principle to send sensor data every 2 minutes instead of every 1 minute and further reduce battery draw. I know the DS18B20 sensors are correctly going into sleep mode, but the node itself is still using too much juice.
            There is nothing in the API about this, would be nice if it were added as I don't think I will be the only person with such requirements. Also, what does sleep actually do and are there further things I could do to reduce the power use?
            That is because I haven't finished this node yet.... I am working on it systematically and in future a water leak detector will be added. But only when this part is working correctly and I have good battery life from the node.
              #122
              @skywatch said in 💬 Temperature Sensor:
              Good point. I have added a note on https://www.mysensors.org/download/sensor_api_20#sleeping
              It does a lot of things, but basically it puts the radio and the Arduino in power save mode and uses the Arduino's watchdog timer to roughly keep track of time (exact timing is not possible because exact timing requires power, and power save mode is all about saving power).
              https://www.mysensors.org/build/battery has the official MySensors recommendations on how to save power in battery-operated nodes.
              If you want to dive deeper, start with https://www.gammon.com.au/power
                I'd use the sleep time to 2 minutes and then simply set a counter that every 15 loops of the code sends battery status and resets the counter. Imho 2 minutes are quite often for battery life.
                  @gohan wasn't that what I did?
                  gohanG 1 Reply Last reply
                  • skywatchS
                    skywatchS
                    skywatch
                    This can't be right, can it???
                    (http://imagebucket.net/7mtp8rcnqss2/BattGraph.jpg)
                      @mfalkvidd I'm on mobile, I didn't read the code 😇
                        @skywatch it looks normal. The precision is probably 1% and the real value close to 100.5%, so sometimes it will be rounded to 101% and sometimes to 100%.
                          @gohan hek has added a great feature that I use a lot on mobile. Click the code box once to maximize it. Super neat!
                          • skywatchS
                            skywatchS
                            skywatch
                            @mfalkvidd,
                            Did you notice the time line on the bottom of the image. I thought it was supposed to send data once every 30 mins. Seems that something isn't right or I am looking at it from the wrong angle.....?
                              @mfalkvidd,
                              @skywatch I'm not that versed in c/c++ arithmetic, but I suspect the calculation might overflow. Could you add a debug print to see the value of batteryReportFactor?
                              • skywatchS
                                skywatchS
                                skywatch
                                OK I'll do that - seems to be sending battery info every minute still though- strange!
                                  #132
                                  @skywatch could you post the entire sketch also, to check if something fishy has crept in?
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    Here is the sketch, debug will be later today I hope....
                                    unsigned long SLEEP_TIME = 2 * 60 * 1000; // 2 minutes Sleep time between reads.
                                    int numSensors = 0;
                                    bool metric = true;
                                    unsigned int batteryReportFactor = 30*60*1000/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
                                    void before()
                                      sensors.begin();
                                      sendSketchInfo("HW/CH", "0.5");
                                        present(i, S_TEMP);
                                        timesSlept++;
                                        timesSlept = 0;
                                      int numSensors = 0;
                                      bool metric = true;
                                      void before()
                                        sensors.begin();
                                          present(i, S_TEMP);
                                          timesSlept++;
                                          timesSlept = 0;
                                      @skywatch code looks good to me. What type of Arduino are you using?
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        #135
                                        I am using a pro mini 3.3v 8MHz. I would ideally like to get a 1MHZ bootloader onto it but the last try stopped the temperature sensors sending data (although battery levels were still sent!)..... Hope it helps.
                                          @skywatch could you also print the return value of the sleep function. Maybe that interrupt is triggering it so it returns early?
