  3. Automatic stairs led lighting arduino shield
8 Posts 3 Posters 4.3k Views 3 Watching
  • C
    C
    Chen Boly
    Re: Automatic stairs led lighting arduino shield
    Hi @aivaredze
    Could you help to detail the hardware specification such as: LED Strip, Power Supply Switch and what is the device which shown on top of 2 PIR sensor? alt text
    thanks,
    Boly
      Leds 12v 2.5A max per strip
      Power supply: 12v and multiply the number of strips buy the max current they use to get the minimum output current for the power supply
      The top right component is a photo resistor used to measure how much light is in the room, so you don't turn on the stairs lights during the day
      • C
        C
        Chen Boly
        Thanks gohan, it is clear. How can I search the light resistor in ebay? do you have name or keyword to search?
        • tbowmoT
          tbowmoT
          tbowmo
          @Chen-Boly
          Have you tried searching for "light resistor"? Or perhaps "Light resistor arduino" ? ;)
          C 1 Reply Last reply
          • tbowmoT tbowmo
            @Chen-Boly
            C
            C
            Chen Boly
            @tbowmo said in Automatic stairs led lighting arduino shield:
            Thanks Tbowmo, it is this one?
            http://www.ebay.com/itm/5-Types-10-Pcs-Photoresistor-Dependent-Light-Resistor-LDR-Pack-For-Arduino-Kit-/232366567175?epid=28002809838&hash=item361a206f07:g:QQ0AAOSwKflZO107
            • tbowmoT
              tbowmoT
              tbowmo
              @Chen-Boly
              Yes, that's the one..
              • tbowmoT tbowmo
                @Chen-Boly
                C
                C
                Chen Boly
                @tbowmo
                it has a different type (different number), any type is ok, right?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  probably another manufacturer.. But I would go with this one..
                  /Thomas
