  3. OpenHAB
  4. Beginner - what is wrong
45 Posts 6 Posters 17.4k Views 6 Watching
  • X
    X
    xmonika
    Thank you for pointing my focus. I will try to experiment with that tonight.
    X 1 Reply Last reply
    • X xmonika
      X
      X
      xmonika
      wrote on last edited by xmonika
      Unfortunately I couldn't move futher because of not being able to upload sketch into the node. I've bought CP1202 USB-TTL/3V3 with DTR pin, downgraded Arduino IDE to 1.6.13, set up Mysensebender micro board, COM6, ATmega328 8 MHz and tried all the programmers available but everytime got
      Arduino: 1.6.13 (Windows 10), Vývojová deska: "Sensebender Micro, Atmega328 8Mhz"
      Projekt zabírá 20 862 bytů (67%)  úložného místa pro program. Maximum je 30 720 bytů.
      Globální proměnné zabírají 747 bytů (36%)  dynamické paměti, 1 301 bytů zůstává pro lokální proměnné. Maximum je 2 048 bytů.
      avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc2
      avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x37
      avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb4
      avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x57
      avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc5
      avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
      avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
      avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd9
      avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe5
      avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x41
      Nastala chyba při nahrávaní projektu.
      Táto zpráva by měla mít víc informacií v
      "Zobrazení podrobného výstupu při kompilaci"
      podle zapnuté volby v Soubor -> Nastavení.
      I've tried to switch Tx/Rx but not helped. I can track serial output, so there is some transfer
      Sensebender Micro FW 1.1req node id
      send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
      sensor started, id 255
       - Online!
      req node id
      req node id
      req node id
      req node id
      isMetric: 1
      req node id
      T: 21.09
      H: 53
      Any ideas how to setup IDE to push the code into node?
      • Nca78N
        Hello, you should link TX of the adapter to RX on the board, and RX to TX.
        Make sure DTR pin is corretly connected to DTR pin of the board and check all the wires you could have a defective one.
        Selected programmer in Arduino should be AVR ISP mk2
          If you have the red ftdi like in the picture, you can plug it straight in
          • X
            X
            xmonika
            I have this one alt text.
            The programmer I am using is called AVRISP.mkII, hope that is correct.
            I have the RX-TX and TX-RX connected. I tried to switch them as well and suppose they are now correct because serial monitor works. DTR on the adapter is connected to the board. The board in self test mode works ok, so it is not damaged.
            The output is the error as above. This is very frustrating I already have some experience with arduino but here after 20+ hours of experimenting I am not able to get out of point zero.
            Anyway thank you for your patience and help.
            • tbowmoT
              tbowmoT
              tbowmo
              @xmonika
              The node requests an ID from the controller.. It is also shown in the MQTT on your raspberry pi, but the controller doesn't seem to reply to this ID request.
              Have you configured OpenHAB to use MQTT for the mysensor gateway? Does the log in OpenHAB tell you anything?
              Did you try to hardcode the node ID, as suggested by @gohan? If yes, could you post the node and gateway logs after this?
              gohanG 1 Reply Last reply
              • tbowmoT tbowmo
                @xmonika
                @tbowmo he tried to add the node id, but he is stuck with the uploading of the sketch :D
                @xmonika then you start to see "uploading" in arduino IDE, try pressing the reset button on the arduino and see if it starts transferring the program.
                  X
                  X
                  xmonika
                  @gohan But I don't have arduino, I have direct connection between USB/TTL and sensebender micro like this (double checked)
                  CP1202 USB-TTL <-> MySensebender micro
                  GND <-> GND
                  3v3 <-> VCC (tried as well with AA battery without VCC connected)
                  RX <-> TX
                  TX <-> RX
                  DTR <-> DTR
                  Is there some way to manipulate reset directly on Sensebender micro? Like try to generate edge with the wire?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @xmonika
                    What target do you use in Arduino, when you're trying to program the sensebender micro?
                    • tbowmoT tbowmo
                      @xmonika
                      X
                      X
                      xmonika
                      @tbowmo In IDE (Arduino: 1.6.13 - Windows 10), I have: "Sensebender Micro, Atmega328 8Mhz" (it is also shown in the code above) is that correct configuration?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @xmonika
                        And you can successfully see the debug log in your terminal program, from your sensebender micro?
                        • tbowmoT tbowmo
                          @xmonika
                          X
                          X
                          xmonika
                          @tbowmo Yes, i.e. now I can see in the terminal all this:
                           - Online!
                          req node id
                          req node id
                          req node id
                          req node id
                          isMetric: 1
                          req node id
                          T: 19.93
                          H: 79
                          req node id
                          req node id
                          tbowmoT 1 Reply Last reply
                          • X xmonika
                             - Online!
                            req node id
                            req node id
                            req node id
                            req node id
                            isMetric: 1
                            req node id
                            T: 19.93
                            H: 79
                            req node id
                            req node id
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @xmonika and still you can not upload a new sketch to this Pcb?
                            • tbowmoT tbowmo
                              X
                              X
                              xmonika
                              @tbowmo Yes, exactly. By pressing Project Upload => not in sync and Upload error. By pressing Project Upload via programmer => just Upload error message. Here is my setup
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                I'm out of ideas right now.
                                Did you try a more recent version of the arduino ide?
                                • tbowmoT tbowmo
                                  X
                                  X
                                  xmonika
                                  @tbowmo I will try to install all the drivers & IDE on diferent comp tomorrow. I already did the downgrade from 1.8 because of the note "Arduino IDE 1.5.x & 1.6.x compatible." in SB tech specs.
                                  Anyway thanks for your help. I will have to invest more hours yet to reinvent the wheel but it is fine to have somebody to consult with.
                                  • X xmonika
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @xmonika
                                    Hmm.. it should be compatible with anything above arduino 1.6.. But it's a while since I compiled anything for that target (all my sensebenders have been in "production" since june 2015)
                                    • X
                                      X
                                      xmonika
                                      So I have tried it on the different computer and the results are the same.
                                      This is what I did:
                                      • download ide 1.8 here https://www.arduino.cc/en/main/software & install
                                      • download CP CP2102 win 10 drivers here https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
                                      • install mysensors libraries in IDE via manage library internal tool
                                      • add https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json to IDE
                                      • select Sensebender micro board, COM6 (the only available), Programmer AVRISP.mkII
                                      • add necessary libraries to compile the sensebender micro sketch as described here https://www.mysensors.org/about/arduino#optional---install-external-mysensors-examples - via creating zip files and add zip library file to sketch. Necessary libraries were SI7021 + sha204 + RunningAverage
                                      • compile and upload the basic sketch from here https://www.openhardware.io/view/1/Sensebender-Micro
                                      Result is: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @xmonika
                                        Wait a moment, you choose AVRISP.mkII ? That shouldn't be necessary, as it is only needed if you ever want to upload a new bootloader (and then you need a different programming adapter as well)
                                        You are using the build in arduino programming tool to download? (Second icon from left, in the top menu)
                                        • tbowmoT tbowmo
                                          @xmonika
                                          X
                                          X
                                          xmonika
                                          @tbowmo Yes, second icon from the left (or Ctrl+U).
                                          By pressing Project Upload via programmer (in menu Project or Ctrl+Shift+U) the result is little bit different - no stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb error just uncommented Upload error.
