  3. OpenHAB
  4. Beginner - what is wrong
45 Posts 6 Posters 17.4k Views 6 Watching
    @tbowmo he tried to add the node id, but he is stuck with the uploading of the sketch :D
    @xmonika then you start to see "uploading" in arduino IDE, try pressing the reset button on the arduino and see if it starts transferring the program.
    X
    X
    xmonika
    @gohan But I don't have arduino, I have direct connection between USB/TTL and sensebender micro like this (double checked)
    CP1202 USB-TTL <-> MySensebender micro
    GND <-> GND
    3v3 <-> VCC (tried as well with AA battery without VCC connected)
    RX <-> TX
    TX <-> RX
    DTR <-> DTR
    Is there some way to manipulate reset directly on Sensebender micro? Like try to generate edge with the wire?
    • tbowmoT
      tbowmoT
      tbowmo
      @xmonika
      What target do you use in Arduino, when you're trying to program the sensebender micro?
      X 1 Reply Last reply
      • tbowmoT tbowmo
        @xmonika
        X
        X
        xmonika
        @tbowmo In IDE (Arduino: 1.6.13 - Windows 10), I have: "Sensebender Micro, Atmega328 8Mhz" (it is also shown in the code above) is that correct configuration?
        • tbowmoT
          tbowmoT
          tbowmo
          @xmonika
          And you can successfully see the debug log in your terminal program, from your sensebender micro?
          • tbowmoT tbowmo
            @xmonika
            X
            X
            xmonika
            @tbowmo Yes, i.e. now I can see in the terminal all this:
            Sensebender Micro FW 1.1req node id
            send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
            sensor started, id 255
             - Online!
            req node id
            req node id
            req node id
            req node id
            isMetric: 1
            req node id
            T: 19.93
            H: 79
            req node id
            req node id
            tbowmoT 1 Reply Last reply
            • X xmonika
               - Online!
              req node id
              req node id
              req node id
              req node id
              isMetric: 1
              req node id
              T: 19.93
              H: 79
              req node id
              req node id
              tbowmoT
              tbowmoT
              tbowmo
              @xmonika and still you can not upload a new sketch to this Pcb?
              • tbowmoT tbowmo
                X
                X
                xmonika
                @tbowmo Yes, exactly. By pressing Project Upload => not in sync and Upload error. By pressing Project Upload via programmer => just Upload error message. Here is my setup
                • tbowmoT
                  tbowmoT
                  tbowmo
                  I'm out of ideas right now.
                  Did you try a more recent version of the arduino ide?
                  • tbowmoT tbowmo
                    X
                    X
                    xmonika
                    @tbowmo I will try to install all the drivers & IDE on diferent comp tomorrow. I already did the downgrade from 1.8 because of the note "Arduino IDE 1.5.x & 1.6.x compatible." in SB tech specs.
                    Anyway thanks for your help. I will have to invest more hours yet to reinvent the wheel but it is fine to have somebody to consult with.
                    • X xmonika
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @xmonika
                      Hmm.. it should be compatible with anything above arduino 1.6.. But it's a while since I compiled anything for that target (all my sensebenders have been in "production" since june 2015)
                      • X
                        X
                        xmonika
                        So I have tried it on the different computer and the results are the same.
                        This is what I did:
                        • download ide 1.8 here https://www.arduino.cc/en/main/software & install
                        • download CP CP2102 win 10 drivers here https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
                        • install mysensors libraries in IDE via manage library internal tool
                        • add https://raw.githubusercontent.com/mysensors/ArduinoBoards/master/package_mysensors.org_index.json to IDE
                        • select Sensebender micro board, COM6 (the only available), Programmer AVRISP.mkII
                        • add necessary libraries to compile the sensebender micro sketch as described here https://www.mysensors.org/about/arduino#optional---install-external-mysensors-examples - via creating zip files and add zip library file to sketch. Necessary libraries were SI7021 + sha204 + RunningAverage
                        • compile and upload the basic sketch from here https://www.openhardware.io/view/1/Sensebender-Micro
                        Result is: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @xmonika
                          Wait a moment, you choose AVRISP.mkII ? That shouldn't be necessary, as it is only needed if you ever want to upload a new bootloader (and then you need a different programming adapter as well)
                          You are using the build in arduino programming tool to download? (Second icon from left, in the top menu)
                          • tbowmoT tbowmo
                            @xmonika
                            X
                            X
                            xmonika
                            @tbowmo Yes, second icon from the left (or Ctrl+U).
                            By pressing Project Upload via programmer (in menu Project or Ctrl+Shift+U) the result is little bit different - no stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb error just uncommented Upload error.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              #27
                              @xmonika
                              When you have chosen SenseBender Micro as target, which sub variant did you choose? (8Mhz, or 1Mhz?) Can't remember if there are any differences in baudrate.. And I'm not at my arduino dev. machine right now. You should choose the 8Mhz as target.
                              Also could you check soldering of the board? (specially around the reset line, capacitor, resistors, atmega328)
                              That is the last things that I could think about right now..
                              • X
                                X
                                xmonika
                                wrote on last edited by xmonika
                                #28
                                I have selected 8 MHz. This is what it looks like by me
                                0_1503748835505_upload-ea2c7217-d6c6-430d-b59c-64c33302dbbc
                                This is what I did today - got another sensebender micro (SBM) board, soldered jumpers, connected again. Then I measured the conductivity between DTR pin on CP2102 chip and capacitor on DTR wire on SBM. It shall be conected via my wires and it was correctly connected.
                                Then I run the compillation again and the result is the same - not in sync. So I feel I have replaced everything but still getting the same error.
                                • Nca78N
                                  @xmonika do you have an arduino board ? You could try to use it to test your serial adapter.
                                  • X
                                    X
                                    xmonika
                                    So I tried Arduino nano (may be clone). The result is simillar - not in sync. But then I tried the nano via standard mini USB cable and also not in sync. Possibly WIN 10 related? I tried it with admin privileges.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @xmonika or it's related to your usb 2 serial interface?
                                      • X
                                        X
                                        xmonika
                                        #32
                                        Could be but the same I get on my second computer (win 10 as well). Will experiment with that.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          But still using the same USB device on the second computer?
