  3. nRF5 action!
nRF5 action!
    #722
    So, to move forward with this, I took a super-stripped down nRF52832, and loaded it with a super stripped down sketch that never initializes the radio and pretty much just jumps directly into a long RTC 12 hour slumber using the MySensors sleep routine. Measuring the current drawn while in that slumber using a uCurrent Gold, I'm reading about 9.3ua. So, to confirm that, I'm running the same stripped down setup from a 10F supercap, and I'll see at what rate the supercap voltage drops with time, and whether that appears to agree or not with these initial measurements.
    Hopefully the current draw will remain low, and there will be no surprises. In that case, I'll add stuff back in until I find the culprit that was previously causing the higher current draw.
    rmtuckerR NeverDieN 2 Replies Last reply
      rmtuckerR
      rmtuckerR
      rmtucker
      I can not understand why you are drawing 9.4uA in the first place?.
      My nrf51822 seems to consistently only draw 4-5uA with no strip down of software when in mysensors sleep mode.
      Fair enough i have not got your measurement equipment but i don,t see it being that far away.
      The data sheets seem to point to under 5uA.
      NeverDieN d00616D 2 Replies Last reply
      • rmtuckerR rmtucker
        Yes, it is puzzling. I don't have a good answer as to why it measures so high. Maybe the crystal oscillator? What else is there that might be causing it?
        Nca78N 1 Reply Last reply
          After this initial run completes, I'll try reprogramming it to use the internal resonnator instead and see if that makes any difference.
            #726
            Indeed, reprogramming the Ebyte nRF52832 to use the internal oscillator dropped the sleep current consumption down to 5.4ua. :)
            I wonder whether physically removing the crystal oscillator would result in additional savings, or if that's as low as it goes?
            I also wonder whether the datasheet cheats a bit by not counting the current consumed by the external crystal oscillator when that's being used? Otherwise, I don't see how Nordic can claim a <2ua sleep current for the nRF52832.
            rmtuckerR 1 Reply Last reply
              rmtuckerR
              rmtuckerR
              rmtucker
              Stranger still my 4-5uA is using the external crystal??.
                I have to amend what I just said, because I took a measurement short-cut that in retrospect I shouldn't have: namely, I did the measurements on two different modules.
                I went back and changed the 5.4ua module using the RC internal oscillator to use the external crystal oscillator, and it measures about the same.
                So... The difference I was reading was a difference in the way the two modules measure. I'm not sure why one reads higher than the other, except perhaps that I didn't clean the solder flux off the higher reading module, and I did clean off the solder flux on the lower reading module.
                I'll try cleaning the solder flux off the higher reading module and see if that drops the current consumed.
                  I cleaned off the solder flux and... no real difference. Go figure. Maybe it's just random variation among the Ebyte Modules? I guess I'll have to wire up more of them and see how they all compare.
                    @NeverDie did you select the option with internal crystal ? 1s accuracy after 12h like you said before sounds more like a precise external crystal than an internal one.
                    • Nca78N Nca78
                      Up until today I was using just the external crystal on the Ebyte nRF52832's. It was only for comparison purposes of current consumption that today I switched to the internal resonator. It's about the same current consumption. Maybe if I now remove the external crystal, it will save some current? I just don't know.
                      KoreshK 1 Reply Last reply
                        d00616D
                        d00616D
                        d00616
                        While developing the nRF5 port, I had no chance to measure the current of the nRF52 accurate. With my original nRF51 dev kit I I have a sleeping current matching the data sheet.
                        Now I can measure currents in the µA range. With all nRF52 I have, I measured sleeping currents around 10µA. This is to much. We have to see 2-3µA. I have no original nRF52832 dev kit to compare. The reason of this sleeping current can be either an error in the layout or there is a component which is not required in active state while sleeping.
                        At the moment I have no time to analyse this. There is a bug in the radio code, which I have to fix. When transport debug is disabled no packages are received. In my opinion this has more priority.
                          KoreshK
                          KoreshK
                          Koresh
                          @NeverDie Just my two cents. Leakage current through non ideal capacitors can be 1-10uA.
                            It turns out that the culprit was the mere act of using pinmode to designate a pin as an input pin, even if it's not connected to anything. Then, during sleep, the current consumption is an order of magnitude higher. This is quite different behavior than on, say, an Arduino pro mini, where the input pins are high impedance and there's neglible current draw.
                            Not sure what to do about it though. Any ideas?
                              #735
                              The same sort of thing happens if pinmode is used to designate a pin as an output pin--again, even if nothing is connected to it.
                              This is a potential show stopper. This module is useless to me if I can't connect it to anything.
                              As a workaround, is there some way to designate a pin as undefined again after having used pinmode to define it as either an input pin or an output pin?
                                #736
                                Well, setting the pinmode to OUTPUT and then digitalwriting it to LOW seems to help considerably--at least when it's not connected to anything.
                                [Edit: Setting it to HIGH also helps similarly.]
                                d00616D 1 Reply Last reply
                                  #737
                                  Anyhow, I'm relieved that the radio isn't the source of these power drain problems. This pinmode stuff is a bummer, but it looks like I can at least partially work around it.
                                    d00616D
                                    d00616D
                                    d00616
                                    Thank's. I check this after I fixed the Radio.
                                    Actually, I have this board running. I measure a voltage of 0.13mV=6,6µA at the shunt with a simple sleep sketch. When I switch two pins into INPUT_PULLUP, then I measure 0.15mV==7,5µA.
                                    When I switch on the LED then I measure 12.75mV == 0,6375mA, One pin in OUTPUT_H1H0 mode. With LED off I measure 0.15mV==7,5µA.
                                    My MCU is nRF52832 QFAAB0 1615AX
                                    P.S.: I have no documentation about the board. When I measure the boards current, then I have an shunt factor of 22,5. I think calculating with 20 is ok.
                                    • d00616D d00616
                                      #739
                                      @d00616
                                      Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers. :)
                                      https://www.aliexpress.com/item/NRF52832-Mini-Development-Board-Gold-Core-board-Wireless-Bluetooth-Transceiver-Module/32798618219.html?spm=2114.search0204.3.1.GUmybP&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5490020_10068_5430020_5410020_10307_10137_10060_10155_10154_10333_10334_10056_5370011_10335_10055_10336_10054_10059_10332_100031_10099_5400020_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_5380020_10326_5390020_10084_10083_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10316_10078_10079_10073_5420011-10332_10333,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=78a27a2f-4aa5-49a0-a538-502a2c86d8f2&algo_expid=598ae4bb-6401-4529-89ad-6e8d8a90af12-0&algo_pvid=598ae4bb-6401-4529-89ad-6e8d8a90af12&transAbTest=ae803_3
                                      [By the way, I did my measurements on an Ebyte nRF52832 module]
                                        #740
                                        in that case, you need to set it as a floating input i think, like it's generally at reset.
                                        In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
                                        This should do the job..
                                          @d00616
                                          d00616D
                                          d00616D
                                          d00616
                                          Ok. I have measured my Ebyte with the same sketch and in the µA range of my VC165 multimeter. Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82€)
                                          Should I add a DISCONNECTED mode to hwPinMode()?
                                          NeverDieN rmtuckerR 2 Replies Last reply
