  3. nRF5 action!
nRF5 action!
  • rmtuckerR rmtucker
    I can not understand why you are drawing 9.4uA in the first place?.
    My nrf51822 seems to consistently only draw 4-5uA with no strip down of software when in mysensors sleep mode.
    Fair enough i have not got your measurement equipment but i don,t see it being that far away.
    The data sheets seem to point to under 5uA.
    d00616D
    d00616D
    d00616
    While developing the nRF5 port, I had no chance to measure the current of the nRF52 accurate. With my original nRF51 dev kit I I have a sleeping current matching the data sheet.
    Now I can measure currents in the µA range. With all nRF52 I have, I measured sleeping currents around 10µA. This is to much. We have to see 2-3µA. I have no original nRF52832 dev kit to compare. The reason of this sleeping current can be either an error in the layout or there is a component which is not required in active state while sleeping.
    At the moment I have no time to analyse this. There is a bug in the radio code, which I have to fix. When transport debug is disabled no packages are received. In my opinion this has more priority.
      @NeverDie did you select the option with internal crystal ? 1s accuracy after 12h like you said before sounds more like a precise external crystal than an internal one.
      Up until today I was using just the external crystal on the Ebyte nRF52832's. It was only for comparison purposes of current consumption that today I switched to the internal resonator. It's about the same current consumption. Maybe if I now remove the external crystal, it will save some current? I just don't know.
      KoreshK
      KoreshK
      Koresh
      @NeverDie Just my two cents. Leakage current through non ideal capacitors can be 1-10uA.
        So, to move forward with this, I took a super-stripped down nRF52832, and loaded it with a super stripped down sketch that never initializes the radio and pretty much just jumps directly into a long RTC 12 hour slumber using the MySensors sleep routine. Measuring the current drawn while in that slumber using a uCurrent Gold, I'm reading about 9.3ua. So, to confirm that, I'm running the same stripped down setup from a 10F supercap, and I'll see at what rate the supercap voltage drops with time, and whether that appears to agree or not with these initial measurements.
        Hopefully the current draw will remain low, and there will be no surprises. In that case, I'll add stuff back in until I find the culprit that was previously causing the higher current draw.
        It turns out that the culprit was the mere act of using pinmode to designate a pin as an input pin, even if it's not connected to anything. Then, during sleep, the current consumption is an order of magnitude higher. This is quite different behavior than on, say, an Arduino pro mini, where the input pins are high impedance and there's neglible current draw.
        Not sure what to do about it though. Any ideas?
          #735
          The same sort of thing happens if pinmode is used to designate a pin as an output pin--again, even if nothing is connected to it.
          This is a potential show stopper. This module is useless to me if I can't connect it to anything.
          As a workaround, is there some way to designate a pin as undefined again after having used pinmode to define it as either an input pin or an output pin?
            #736
            Well, setting the pinmode to OUTPUT and then digitalwriting it to LOW seems to help considerably--at least when it's not connected to anything.
            [Edit: Setting it to HIGH also helps similarly.]
            d00616D 1 Reply Last reply
              #737
              Anyhow, I'm relieved that the radio isn't the source of these power drain problems. This pinmode stuff is a bummer, but it looks like I can at least partially work around it.
                d00616D
                d00616D
                d00616
                Thank's. I check this after I fixed the Radio.
                Actually, I have this board running. I measure a voltage of 0.13mV=6,6µA at the shunt with a simple sleep sketch. When I switch two pins into INPUT_PULLUP, then I measure 0.15mV==7,5µA.
                When I switch on the LED then I measure 12.75mV == 0,6375mA, One pin in OUTPUT_H1H0 mode. With LED off I measure 0.15mV==7,5µA.
                My MCU is nRF52832 QFAAB0 1615AX
                P.S.: I have no documentation about the board. When I measure the boards current, then I have an shunt factor of 22,5. I think calculating with 20 is ok.
                • d00616D d00616
                  #739
                  @d00616
                  Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers. :)
                  https://www.aliexpress.com/item/NRF52832-Mini-Development-Board-Gold-Core-board-Wireless-Bluetooth-Transceiver-Module/32798618219.html?spm=2114.search0204.3.1.GUmybP&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5490020_10068_5430020_5410020_10307_10137_10060_10155_10154_10333_10334_10056_5370011_10335_10055_10336_10054_10059_10332_100031_10099_5400020_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_5380020_10326_5390020_10084_10083_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10316_10078_10079_10073_5420011-10332_10333,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=78a27a2f-4aa5-49a0-a538-502a2c86d8f2&algo_expid=598ae4bb-6401-4529-89ad-6e8d8a90af12-0&algo_pvid=598ae4bb-6401-4529-89ad-6e8d8a90af12&transAbTest=ae803_3
                  [By the way, I did my measurements on an Ebyte nRF52832 module]
                    #740
                    in that case, you need to set it as a floating input i think, like it's generally at reset.
                    In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
                    This should do the job..
                      @d00616
                      d00616D
                      d00616D
                      d00616
                      Ok. I have measured my Ebyte with the same sketch and in the µA range of my VC165 multimeter. Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82€)
                      Should I add a DISCONNECTED mode to hwPinMode()?
                      NeverDieN rmtuckerR 2 Replies Last reply
                      • d00616D d00616
                        #742
                        Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode....
                        Ah, maybe that's part of the difference. I was doing just:
                        pinMode(ALPHA_PIN, INPUT)
                        pinMode(BETA_PIN, OUTPUT)
                        because that's how I would have done it on an Arduino. Should we instead always use INPUT_PULLUP and OUTPUT_H0H1 instead?
                        rmtuckerR 1 Reply Last reply
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          Should be
                          According to NRF5 platform
                            Thanks! Somehow didn't remember that.
                            So, as suggested by @scalz what is some example code that can be used to "disconnect" the pin later?
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              He has not added that facility yet,i think he asked you if you wanted it adding to the code?
                                Definitely!
                                  #747
                                  for unused pins, it should be floating, not pullup. set the pin register you need to 0x02.
                                  Something like that
                                  NRF_GPIO->PIN_CNF[ulPin] = 0x02;
                                  that will put pin in same state like it's on reset. Everything disabled/default, floating, with disconnect bit set.
                                  (see datasheet gpio).
                                  make sense to have it for input too.. i agree :simple_smile:
                                    #748
                                    Maybe add:
                                    OUTPUT_D0D1 -> Disconnected 0, Disconnected 1
                                    or similar to your list as another easy way to effectuate the disconnect?
                                      #749
                                      It finally makes sense now as to why there were all those "disconnected" choices among the various OUTPUT options. In my case, for controlling whether the solar panel is connected or disconnected, choosing OUTPUT_S0D1 works perfectly. :)
                                      So, I suppose another way to disconnect an input pin would be to redefine it as an OUTPUT pin with a disconnect state, and then immediately put it into the disconnected state.
                                      • d00616D d00616
                                        Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
                                        The sleep() function is now more precise for sleeping <512s:
                                        https://github.com/mysensors/MySensors/pull/909
                                        The PR is waiting for merge.
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        Hmm just tried the latest commit and it is giving me 306ms for sleep(10000).
                                        Something not quite right.
                                          @rmtucker
                                          How are you measuring how long it's sleeping?
