  3. nRF5 action!
nRF5 action!
    #737
    Anyhow, I'm relieved that the radio isn't the source of these power drain problems. This pinmode stuff is a bummer, but it looks like I can at least partially work around it.
      Well, setting the pinmode to OUTPUT and then digitalwriting it to LOW seems to help considerably--at least when it's not connected to anything.
      [Edit: Setting it to HIGH also helps similarly.]
      d00616D
      d00616D
      d00616
      Thank's. I check this after I fixed the Radio.
      Actually, I have this board running. I measure a voltage of 0.13mV=6,6µA at the shunt with a simple sleep sketch. When I switch two pins into INPUT_PULLUP, then I measure 0.15mV==7,5µA.
      When I switch on the LED then I measure 12.75mV == 0,6375mA, One pin in OUTPUT_H1H0 mode. With LED off I measure 0.15mV==7,5µA.
      My MCU is nRF52832 QFAAB0 1615AX
      P.S.: I have no documentation about the board. When I measure the boards current, then I have an shunt factor of 22,5. I think calculating with 20 is ok.
      • d00616D d00616
        #739
        @d00616
        Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers. :)
        https://www.aliexpress.com/item/NRF52832-Mini-Development-Board-Gold-Core-board-Wireless-Bluetooth-Transceiver-Module/32798618219.html?spm=2114.search0204.3.1.GUmybP&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5490020_10068_5430020_5410020_10307_10137_10060_10155_10154_10333_10334_10056_5370011_10335_10055_10336_10054_10059_10332_100031_10099_5400020_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_5380020_10326_5390020_10084_10083_10080_10082_10081_10178_10110_10111_10112_10113_10114_10312_10313_10314_10316_10078_10079_10073_5420011-10332_10333,searchweb201603_5,ppcSwitch_4_ppcChannel&btsid=78a27a2f-4aa5-49a0-a538-502a2c86d8f2&algo_expid=598ae4bb-6401-4529-89ad-6e8d8a90af12-0&algo_pvid=598ae4bb-6401-4529-89ad-6e8d8a90af12&transAbTest=ae803_3
        [By the way, I did my measurements on an Ebyte nRF52832 module]
        d00616D 1 Reply Last reply
          #740
          in that case, you need to set it as a floating input i think, like it's generally at reset.
          In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
          This should do the job..
            @d00616
            d00616D
            d00616D
            d00616
            Ok. I have measured my Ebyte with the same sketch and in the µA range of my VC165 multimeter. Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82€)
            Should I add a DISCONNECTED mode to hwPinMode()?
            NeverDieN rmtuckerR 2 Replies Last reply
            • d00616D d00616
              #742
              Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode....
              Ah, maybe that's part of the difference. I was doing just:
              pinMode(ALPHA_PIN, INPUT)
              pinMode(BETA_PIN, OUTPUT)
              because that's how I would have done it on an Arduino. Should we instead always use INPUT_PULLUP and OUTPUT_H0H1 instead?
              rmtuckerR 1 Reply Last reply
                rmtuckerR
                rmtuckerR
                rmtucker
                Should be
                According to NRF5 platform
                  Thanks! Somehow didn't remember that.
                  So, as suggested by @scalz what is some example code that can be used to "disconnect" the pin later?
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    He has not added that facility yet,i think he asked you if you wanted it adding to the code?
                    • rmtuckerR rmtucker
                      Definitely!
                        #747
                        for unused pins, it should be floating, not pullup. set the pin register you need to 0x02.
                        Something like that
                        NRF_GPIO->PIN_CNF[ulPin] = 0x02;
                        that will put pin in same state like it's on reset. Everything disabled/default, floating, with disconnect bit set.
                        (see datasheet gpio).
                        make sense to have it for input too.. i agree :simple_smile:
                          #748
                          Maybe add:
                          OUTPUT_D0D1 -> Disconnected 0, Disconnected 1
                          or similar to your list as another easy way to effectuate the disconnect?
                            #749
                            It finally makes sense now as to why there were all those "disconnected" choices among the various OUTPUT options. In my case, for controlling whether the solar panel is connected or disconnected, choosing OUTPUT_S0D1 works perfectly. :)
                            So, I suppose another way to disconnect an input pin would be to redefine it as an OUTPUT pin with a disconnect state, and then immediately put it into the disconnected state.
                            • d00616D d00616
                              Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
                              The sleep() function is now more precise for sleeping <512s:
                              https://github.com/mysensors/MySensors/pull/909
                              The PR is waiting for merge.
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              Hmm just tried the latest commit and it is giving me 306ms for sleep(10000).
                              Something not quite right.
                                @rmtucker
                                How are you measuring how long it's sleeping?
                                  @rmtucker
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @rmtucker
                                  Just using hwMillis() before and after sleep and subtracting one from the other.
                                  It was just reading + 250ms until @d00616 commited some changes a few hours ago.
                                  rmtuckerR NeverDieN 2 Replies Last reply
                                    @rmtucker
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    something wrong in here:-
                                    // Calculate sleep time and prescaler
                                    		if (ms<512000) {
                                    			// prescaler 0, 30.517 μs resolution -> max 512 s sleep
                                    			MY_HW_RTC->PRESCALER =  0;
                                    			// Set compare register to 1/30.517 µs to garantee event triggering
                                    			// A minimum of 2 ticks must be guaranteed
                                    			// (1000/32768)<<12 == 125
                                    			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);
                                    			// 8 Hz -> max 582.542 hours sleep.
                                    			MY_HW_RTC->PRESCALER = 4095;
                                    			// Set compare register to 1/125ms
                                    			MY_HW_RTC->CC[0] = max((ms / 125), 2);
                                      @rmtucker
                                      #754
                                      @rmtucker
                                      I thought so. The point being: doesn't millis stop when you're deep sleeping? Well, at least on an Arduino it does. Not sure what it does on the nRF5.
                                        @rmtucker
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        wrote on last edited by rmtucker
                                        #755
                                        No the nrf5 has a rtc.(Real time Counter)
                                        It can even keep time while sleeping.(just found this out myself!).
                                        That is a great leap forward on the arduino.
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          Try it just print the time out then put it to sleep for a minute then print the time out again.
