  3. nRF5 action!
nRF5 action!
    Thanks! Somehow didn't remember that.
    So, as suggested by @scalz what is some example code that can be used to "disconnect" the pin later?
    rmtuckerR 1 Reply Last reply
      rmtuckerR
      rmtuckerR
      rmtucker
      He has not added that facility yet,i think he asked you if you wanted it adding to the code?
      • rmtuckerR rmtucker
        Definitely!
          #747
          for unused pins, it should be floating, not pullup. set the pin register you need to 0x02.
          Something like that
          NRF_GPIO->PIN_CNF[ulPin] = 0x02;
          that will put pin in same state like it's on reset. Everything disabled/default, floating, with disconnect bit set.
          (see datasheet gpio).
          Should I add a DISCONNECTED mode to hwPinMode()?
          make sense to have it for input too.. i agree :simple_smile:
          d00616D 1 Reply Last reply
            #748
            Maybe add:
            OUTPUT_D0D1 -> Disconnected 0, Disconnected 1
            or similar to your list as another easy way to effectuate the disconnect?
              #749
              It finally makes sense now as to why there were all those "disconnected" choices among the various OUTPUT options. In my case, for controlling whether the solar panel is connected or disconnected, choosing OUTPUT_S0D1 works perfectly. :)
              So, I suppose another way to disconnect an input pin would be to redefine it as an OUTPUT pin with a disconnect state, and then immediately put it into the disconnected state.
              • d00616D d00616
                Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
                The sleep() function is now more precise for sleeping <512s:
                https://github.com/mysensors/MySensors/pull/909
                The PR is waiting for merge.
                rmtuckerR
                rmtuckerR
                rmtucker
                Hmm just tried the latest commit and it is giving me 306ms for sleep(10000).
                Something not quite right.
                  @rmtucker
                  How are you measuring how long it's sleeping?
                    @rmtucker
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    @rmtucker
                    Just using hwMillis() before and after sleep and subtracting one from the other.
                    It was just reading + 250ms until @d00616 commited some changes a few hours ago.
                    rmtuckerR NeverDieN 2 Replies Last reply
                      @rmtucker
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      something wrong in here:-
                      // Calculate sleep time and prescaler
                      		if (ms<512000) {
                      			// prescaler 0, 30.517 μs resolution -> max 512 s sleep
                      			MY_HW_RTC->PRESCALER =  0;
                      			// Set compare register to 1/30.517 µs to garantee event triggering
                      			// A minimum of 2 ticks must be guaranteed
                      			// (1000/32768)<<12 == 125
                      			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);
                      			// 8 Hz -> max 582.542 hours sleep.
                      			MY_HW_RTC->PRESCALER = 4095;
                      			// Set compare register to 1/125ms
                      			MY_HW_RTC->CC[0] = max((ms / 125), 2);
                        @rmtucker
                        #754
                        @rmtucker
                        I thought so. The point being: doesn't millis stop when you're deep sleeping? Well, at least on an Arduino it does. Not sure what it does on the nRF5.
                          @rmtucker
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          wrote on last edited by rmtucker
                          #755
                          No the nrf5 has a rtc.(Real time Counter)
                          It can even keep time while sleeping.(just found this out myself!).
                          That is a great leap forward on the arduino.
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            Try it just print the time out then put it to sleep for a minute then print the time out again.
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              #757
                              The problem must be this line but i don't speak nrf5.:frowning:
                              			MY_HW_RTC->CC[0] = max((ms<<12 / 125), 2);```
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                #758
                                The only other thing it could be is the deletion of this line in the commit.
                                nrf5_rtc_event_triggered = false
                                • d00616D d00616
                                  Thanks! I just now ordered one of your boards so that in the future we can share a common platform for comparing numbers.
                                  Ok. I have measured my Ebyte with the same sketch and in the µA range of my VC165 multimeter. Sleep current is 9.9µA with two ports in INPUT_PULLUP and one Port in OUTPUT_H0H1 mode. (b.t.w. this module costs actually 3,82€)
                                  in that case, you need to set it as a floating input i think, like it's generally at reset.
                                  In datasheet, section 20 (p111), is explained how works the GPIO. You have a Bit for disconnecting it. See the PIN_CNF[n] registers. For instance, p.140, you can see how it looks for the P0.10, and the Bit 1.
                                  This should do the job..
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @d00616
                                  Should be:-
                                  MY_HW_RTC->CC[0] = max(((ms << 12) / 125), 2));
                                  rmtuckerR mfalkviddM d00616D 3 Replies Last reply
                                    @d00616
                                    Should be:-
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    @d00616
                                    Just checked and it now returns 10002 for a sleep(10000).
                                    Much better after the above alteration.
                                      Epilog: I made the changes so that just prior to taking a measurement the sense pin is hwPinMode'd to an input pin, and then immediately after the measurement I disconnect it. Seems to be working, and without the usurious power drain I was experiencing previously. :)
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        Good news
                                        So what is the current usage now when sleeping?
                                          Good news
                                          Good news
                                          About 6ua on this particular Ebyte nRF52832. I'm pretty sure it would be higher on my other Ebyte nRF52832, though I haven't measured it again. Haven't tested any additional ones as of yet.
