  3. Can't load from Codebender :-(
27 Posts 4 Posters 12.1k Views 1 Watching
  • D
    Dean
    I just did what the output suggested. Here is what I get:
    Arduino: 1.0.6 (Mac OS X), Board: "Arduino Uno"
    /Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Users//Desktop/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/standard -I/Users//Desktop/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/*****/Desktop/Arduino.app/Contents/Resources/Java/libraries/Ethernet /var/folders/b6/mgvw5s257pd5pyz73nwwt4_r0000gn/T/build8097901850594856372.tmp/EthernetGateway.cpp -o /var/folders/b6/mgvw5s257pd5pyz73nwwt4_r0000gn/T/build8097901850594856372.tmp/EthernetGateway.cpp.o
    EthernetGateway.ino:41:90: warning: DigitalIO.h: No such file or directory
    EthernetGateway.ino:43:22: warning: MySensor.h: No such file or directory
    EthernetGateway.ino:44:25: warning: MyGateway.h: No such file or directory
    EthernetGateway:75: error: 'MyGateway' does not name a type
    EthernetGateway:81: error: 'MAX_RECEIVE_LENGTH' was not declared in this scope
    EthernetGateway.ino: In function 'void setup()':
    EthernetGateway:87: error: 'gw' was not declared in this scope
    EthernetGateway:87: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
    EthernetGateway:87: error: 'RF24_CHANNEL' was not declared in this scope
    EthernetGateway:87: error: 'RF24_DATARATE' was not declared in this scope
    EthernetGateway.ino: In function 'void loop()':
    EthernetGateway:116: error: 'MAX_RECEIVE_LENGTH' was not declared in this scope
    EthernetGateway:121: error: 'inputString' was not declared in this scope
    EthernetGateway:126: error: 'gw' was not declared in this scope
    EthernetGateway:132: error: 'inputString' was not declared in this scope
    EthernetGateway:141: error: 'gw' was not declared in this scope
    • D
      Dean
      I think I have fixed it!!!
      It tells me that it is done compiling, so I hope that means it worked!! :-)
      • D
        Dean
        Nope, looks like I celebrated too early....Vera can't communicate with the gateway, and I can't ping it. After uploading the sketch again I dug a little more and a find this:
        n file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
        from EthernetGateway.ino:35:
        /Users/
        /Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeScl(bool)':
        /Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:146: warning: no return statement in function returning non-void
        /Users/
        /Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeSda(bool)':
        /Users/*/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:159: warning: no return statement in function returning non-void
        At this stage I have no idea what I need to do to fix this, but I'll look and see what I find. Fingers crossed...
        • D
          Dean
          Nope, can't work out what is wrong..... :-( I have no idea why I am getting this error.
          • D
            Dean
            OK, I am starting to feel really dumb... Many months ago I had the Ethernet Gateway working great, but I left it to pursue other stuff until now. I figure I would update stuff, but I should have left it all alone...
            Anyways, I am tired of trying to do this on my computer and not getting anywhere, so I am trying again using Codebender. For everyones info, this is what Codebender tells me:
            Looks like your project uses header files or libraries that do not exist in our system, in your personal libraries or in your sketch. More info
            In file included from libraries/16221_cb_personal_lib_MySensors/Relay.cpp:12:
            In file included from libraries/16221_cb_personal_lib_MySensors/Relay.h:15:
            In file included from libraries/16221_cb_personal_lib_MySensors/Sensor.h:18:
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:47:3: error: unknown type name 'uint8_t'
            uint8_t ce_pin; /< "Chip Enable" pin, activates the RX or TX role */
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:48:3: error: unknown type name 'uint8_t'
            uint8_t csn_pin; /
            < SPI Chip select /
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:51:3: error: unknown type name 'uint8_t'
            uint8_t payload_size; /< Fixed size of payloads */
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:53:3: error: unknown type name 'uint64_t'
            uint64_t pipe0_reading_address; /
            < Last address set on pipe 0 for reading. /
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:73:8: error: unknown type name 'uint8_t'
            RF24(uint8_t _cepin, uint8_t _cspin);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:73:24: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:139:25: error: unknown type name 'uint8_t'
            void read( void
            buf, uint8_t len );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:162:32: error: unknown type name 'uint8_t'
            bool write( const void
            buf, uint8_t len );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:182:24: error: unknown type name 'uint64_t'
            void openWritingPipe(uint64_t address);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:208:24: error: unknown type name 'uint8_t'
            void openReadingPipe(uint8_t number, uint64_t address);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:208:40: error: unknown type name 'uint64_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:217:26: error: unknown type name 'uint8_t'
            void closeReadingPipe( uint8_t pipe ) ;
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:245:18: error: unknown type name 'uint8_t'
            bool available(uint8_t* pipe_num);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:279:32: error: unknown type name 'uint8_t'
            bool write( const void* buf, uint8_t len, const bool multicast );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:312:36: error: unknown type name 'uint8_t'
            bool writeFast( const void* buf, uint8_t len );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:325:36: error: unknown type name 'uint8_t'
            bool writeFast( const void* buf, uint8_t len, const bool multicast );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:355:40: error: unknown type name 'uint8_t'
            bool writeBlocking( const void* buf, uint8_t len, uint32_t timeout );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:355:53: error: unknown type name 'uint32_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:403:19: error: unknown type name 'uint32_t'
            bool txStandBy(uint32_t timeout);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:419:24: error: unknown type name 'uint8_t'
            void writeAckPayload(uint8_t pipe, const void* buf, uint8_t len);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:419:55: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:485:41: error: unknown type name 'uint8_t'
            void startFastWrite( const void* buf, uint8_t len, const bool multicast );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:511:37: error: unknown type name 'uint8_t'
            void startWrite( const void* buf, uint8_t len, const bool multicast );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:537:3: error: unknown type name 'uint8_t'
            uint8_t flush_tx(void);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:607:19: error: unknown type name 'uint8_t'
            void setRetries(uint8_t delay, uint8_t count);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:607:34: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:614:19: error: unknown type name 'uint8_t'
            void setChannel(uint8_t channel);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:628:23: error: unknown type name 'uint8_t'
            void setPayloadSize(uint8_t size);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:637:3: error: unknown type name 'uint8_t'
            uint8_t getPayloadSize(void);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:650:3: error: unknown type name 'uint8_t'
            uint8_t getDynamicPayloadSize(void);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:699:20: error: unknown type name 'uint8_t'
            void setAutoAck( uint8_t pipe, bool enable ) ;
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:712:21: error: unknown type name 'uint8_t'
            void setPALevel ( uint8_t level );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:722:4: error: unknown type name 'uint8_t'
            uint8_t getPALevel( void );
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:3: error: unknown type name 'uint8_t'
            uint8_t read_register(uint8_t reg, uint8_t* buf, uint8_t len);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:25: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:38: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:802:52: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:810:3: error: unknown type name 'uint8_t'
            uint8_t read_register(uint8_t reg);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:810:25: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:3: error: unknown type name 'uint8_t'
            uint8_t write_register(uint8_t reg, const uint8_t* buf, uint8_t len);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:26: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:45: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:820:59: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:3: error: unknown type name 'uint8_t'
            uint8_t write_register(uint8_t reg, uint8_t value);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:26: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:829:39: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:3: error: unknown type name 'uint8_t'
            uint8_t write_payload(const void* buf, uint8_t len, const uint8_t writeType);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:42: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:840:61: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:851:3: error: unknown type name 'uint8_t'
            uint8_t read_payload(void* buf, uint8_t len);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:851:35: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:858:3: error: unknown type name 'uint8_t'
            uint8_t flush_rx(void);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:865:3: error: unknown type name 'uint8_t'
            uint8_t get_status(void);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:874:21: error: unknown type name 'uint8_t'
            void print_status(uint8_t status);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:883:25: error: unknown type name 'uint8_t'
            void print_observe_tx(uint8_t value);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:896:46: error: unknown type name 'uint8_t'
            void print_byte_register(const char* name, uint8_t reg, uint8_t qty = 1);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:896:59: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:909:49: error: unknown type name 'uint8_t'
            void print_address_register(const char* name, uint8_t reg, uint8_t qty = 1);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:909:62: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:923:3: error: unknown type name 'uint8_t'
            uint8_t spiTrans(uint8_t cmd);
            libraries/16221_cb_personal_lib_MySensors/utility/RF24.h:923:20: error: unknown type name 'uint8_t'
            libraries/16221_cb_personal_lib_MySensors/Sensor.h:23:10: fatal error: 'EEPROM.h' file not found
            #include <EEPROM.h>
            62 errors generated.
            Looks to me like the issue is maybe the linked libraries aren't accessable to everyone, which is why it repports that they are missing??
            • D
              Dean
              This is funny..... when I posted the screenshot of the error in my first post, there was only one error; now it looks like there are 62, and I didn't change a thing... Anyone know what's going on?
              • D
                Dean
                OK, I think there is a fault, because I even tried to verify an old sketch that did once work, and I get the same number of errors and it tells me there are missing libraries. :-( :-(
                • D
                  Dean
                  OK I really am going mad..... still trying to get this to work, and now I am getting the same error as I did in the first post. What's going on????
                  • D
                    Dean
                    I'm still trying.... Now I am using Firefox and the errors have gone back up to a total of 62 errors. I just tried it again with Chrome, and it too is reporting the same number of errors.
                    • D
                      Dean
                      Time to give up for a while. Already lost a day trying to get this to work....
                      • D
                        Dean
                        It's annoying me that I can't get this to work lol
                        As a test, I tried verifying the code using Codebender for the serial gateway, and I get the same result. 62 errors.
                        When I hover the mouse over this : #include <stdarg.h> it says "file not detected"
                        • D
                          Dean
                          I don't think there is any point continuing to try and sort this out using Codebender. My guess is that the libraries attached to the sketches don't match anymore or something like that, because I have tried both types of gateways, as well as a couple sensors, and I'm getting errors all the time.
                          • D
                            Dean
                            OK, I am trying again on my computer, and I get a lot further than using Codebender. Again, the message I am getting is this:
                            In file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
                            from EthernetGateway.ino:34:
                            /Users/
                            /Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:143: warning: no return statement in function returning non-void
                            /Users/
                            /Users/***/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:156: warning: no return statement in function returning non-void
                            Can anyone point me in the right direction as to how to fix this?
                              This only looks like warnings .. Which IDE version?
                              D 1 Reply Last reply
                                Dean
                                1.0.6.
                                • D Dean
                                  1.0.6.
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @Dean said:
                                  /Users/*/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:156: warning: no return statement in function returning non-void
                                  ...and they look to be warnings from the library, not your sketch, which would appear with a line number.
                                  what does your sketch look like now?
                                  • D
                                    Dean
                                    • Copyright (C) 2013 Henrik Ekblad henrik.ekblad@gmail.com
                                    • Contribution by a-lurker
                                    • This program is free software; you can redistribute it and/or
                                    • modify it under the terms of the GNU General Public License
                                    • version 2 as published by the Free Software Foundation.
                                    • DESCRIPTION
                                    • The EthernetGateway sends data received from sensors to the ethernet link.
                                    • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
                                    • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
                                    • COMPILING WIZNET (W5100) ETHERNET MODULE
                                    • Edit RF24_config.h in (libraries\MySensors\utility) to enable softspi (remove // before "#define SOFTSPI").
                                    • VERA CONFIGURATION:
                                    • Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                                    • E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                                    • LED purposes:
                                      • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                                      • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                                      • ERR (red) - fast blink on error during transmission error or recieve crc error
                                    • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
                                    #include <DigitalIO.h> // This include can be removed when using UIPEthernet module
                                    #include <MyGateway.h>
                                    #include <stdarg.h>
                                    // Use this if you have attached a Ethernet ENC28J60 shields
                                    //#include <UIPEthernet.h>
                                    // Use this fo WizNET W5100 module and Arduino Ethernet Shield
                                    #include <Ethernet.h>
                                    #define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button
                                    #define RADIO_CE_PIN 5 // radio chip enable
                                    #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
                                    #define RADIO_ERROR_LED_PIN 7 // Error led pin
                                    #define RADIO_RX_LED_PIN 8 // Receive led pin
                                    #define RADIO_TX_LED_PIN 9 // the PCB, on board LED
                                    #define IP_PORT 5003 // The port you want to open
                                    IPAddress myIp (192, 168, 178, 66); // Configure your static ip-address here COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                                    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                                    byte mac[] = { 0xDE, 0xED, 0xBE, 0xEF, 0xFE, 0xED }; // DEED BEEF FEED
                                    // a R/W server on the port
                                    EthernetServer server = EthernetServer(IP_PORT);
                                    // No blink or button functionality. Use the vanilla constructor.
                                    MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                                    // Uncomment this constructor if you have leds and include button attached to your gateway
                                    //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                                    char inputString[MAX_RECEIVE_LENGTH] = ""; // A string to hold incoming commands from serial/ethernet interface
                                    int inputPos = 0;
                                    gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                                    Ethernet.begin(mac, myIp);
                                    // give the Ethernet interface a second to initialize
                                    delay(1000);
                                    server.begin();
                                    // This will be called when data should be written to ethernet
                                    void writeEthernet(char *writeBuffer) {
                                    server.write(writeBuffer);
                                    // if an incoming client connects, there will be
                                    // bytes available to read via the client object
                                    EthernetClient client = server.available();
                                    if (client) {
                                    // if got 1 or more bytes
                                    if (client.available()) {
                                    // read the bytes incoming from the client
                                    char inChar = client.read();
                                         if (inputPos<MAX_RECEIVE_LENGTH-1) {
                                           // if newline then command is complete
                                           if (inChar == '\n') {
                                              // a command was issued by the client
                                              // we will now try to send it to the actuator
                                              inputString[inputPos] = 0;
                                              // echo the string to the serial port
                                              Serial.print(inputString);
                                              gw.parseAndSend(inputString);
                                              // clear the string:
                                              inputPos = 0;
                                             // add it to the inputString:
                                             inputString[inputPos] = inChar;
                                             inputPos++;
                                           inputPos = 0;
                                    gw.processRadioMessage();
                                    • D
                                      Dean
                                      Sorry it looks like a mess. It is the same as the example on this site.
                                      I will see if I can work out how to post it in a more readable way.
                                      • D
                                        Dean
                                        • D
                                          Dean
                                          Look like the problem all along was the sketch that I copied from Codebender. In the end it appears that I wasn't the only problem with the issue, and this is where I found the fix : http://forum.mysensors.org/topic/737/uno-w5100-shield-not-pinging
                                          12.5k
