  3. Can't load from Codebender :-(
27 Posts 4 Posters 12.1k Views 1 Watching
  • D
    Dean
    Time to give up for a while. Already lost a day trying to get this to work....
    • D
      Dean
      It's annoying me that I can't get this to work lol
      As a test, I tried verifying the code using Codebender for the serial gateway, and I get the same result. 62 errors.
      When I hover the mouse over this : #include <stdarg.h> it says "file not detected"
      • D
        Dean
        I don't think there is any point continuing to try and sort this out using Codebender. My guess is that the libraries attached to the sketches don't match anymore or something like that, because I have tried both types of gateways, as well as a couple sensors, and I'm getting errors all the time.
        • D
          Dean
          OK, I am trying again on my computer, and I get a lot further than using Codebender. Again, the message I am getting is this:
          In file included from /Users//Documents/Arduino/libraries/DigitalIO/DigitalIO.h:34,
          from EthernetGateway.ino:34:
          /Users/
          /Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeScl(bool)':
          /Users//Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:143: warning: no return statement in function returning non-void
          /Users/
          /Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h: In member function 'bool SoftI2cMaster::writeSda(bool)':
          /Users/***/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:156: warning: no return statement in function returning non-void
          Can anyone point me in the right direction as to how to fix this?
            This only looks like warnings .. Which IDE version?
            D 1 Reply Last reply
              Dean
              1.0.6.
              • D Dean
                1.0.6.
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @Dean said:
                /Users/*/Documents/Arduino/libraries/DigitalIO/SoftI2cMaster.h:156: warning: no return statement in function returning non-void
                ...and they look to be warnings from the library, not your sketch, which would appear with a line number.
                what does your sketch look like now?
                • D
                  Dean
                  • Copyright (C) 2013 Henrik Ekblad henrik.ekblad@gmail.com
                  • Contribution by a-lurker
                  • This program is free software; you can redistribute it and/or
                  • modify it under the terms of the GNU General Public License
                  • version 2 as published by the Free Software Foundation.
                  • DESCRIPTION
                  • The EthernetGateway sends data received from sensors to the ethernet link.
                  • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
                  • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
                  • COMPILING WIZNET (W5100) ETHERNET MODULE
                  • Edit RF24_config.h in (libraries\MySensors\utility) to enable softspi (remove // before "#define SOFTSPI").
                  • VERA CONFIGURATION:
                  • Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                  • E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                  • LED purposes:
                    • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                    • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                    • ERR (red) - fast blink on error during transmission error or recieve crc error
                  • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
                  #include <DigitalIO.h> // This include can be removed when using UIPEthernet module
                  #include <MyGateway.h>
                  #include <stdarg.h>
                  // Use this if you have attached a Ethernet ENC28J60 shields
                  //#include <UIPEthernet.h>
                  // Use this fo WizNET W5100 module and Arduino Ethernet Shield
                  #include <Ethernet.h>
                  #define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button
                  #define RADIO_CE_PIN 5 // radio chip enable
                  #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
                  #define RADIO_ERROR_LED_PIN 7 // Error led pin
                  #define RADIO_RX_LED_PIN 8 // Receive led pin
                  #define RADIO_TX_LED_PIN 9 // the PCB, on board LED
                  #define IP_PORT 5003 // The port you want to open
                  IPAddress myIp (192, 168, 178, 66); // Configure your static ip-address here COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                  // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                  byte mac[] = { 0xDE, 0xED, 0xBE, 0xEF, 0xFE, 0xED }; // DEED BEEF FEED
                  // a R/W server on the port
                  EthernetServer server = EthernetServer(IP_PORT);
                  // No blink or button functionality. Use the vanilla constructor.
                  MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                  // Uncomment this constructor if you have leds and include button attached to your gateway
                  //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                  char inputString[MAX_RECEIVE_LENGTH] = ""; // A string to hold incoming commands from serial/ethernet interface
                  int inputPos = 0;
                  gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                  Ethernet.begin(mac, myIp);
                  // give the Ethernet interface a second to initialize
                  delay(1000);
                  server.begin();
                  // This will be called when data should be written to ethernet
                  void writeEthernet(char *writeBuffer) {
                  server.write(writeBuffer);
                  // if an incoming client connects, there will be
                  // bytes available to read via the client object
                  EthernetClient client = server.available();
                  if (client) {
                  // if got 1 or more bytes
                  if (client.available()) {
                  // read the bytes incoming from the client
                  char inChar = client.read();
                       if (inputPos<MAX_RECEIVE_LENGTH-1) {
                         // if newline then command is complete
                         if (inChar == '\n') {
                            // a command was issued by the client
                            // we will now try to send it to the actuator
                            inputString[inputPos] = 0;
                            // echo the string to the serial port
                            Serial.print(inputString);
                            gw.parseAndSend(inputString);
                            // clear the string:
                            inputPos = 0;
                           // add it to the inputString:
                           inputString[inputPos] = inChar;
                           inputPos++;
                         inputPos = 0;
                  gw.processRadioMessage();
                  • D
                    Dean
                    Sorry it looks like a mess. It is the same as the example on this site.
                    I will see if I can work out how to post it in a more readable way.
                    • D
                      Dean
                      • D
                        Dean
                        Look like the problem all along was the sketch that I copied from Codebender. In the end it appears that I wasn't the only problem with the issue, and this is where I found the fix : http://forum.mysensors.org/topic/737/uno-w5100-shield-not-pinging
                        12.5k
